Synth question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RememberMorrison, May 11, 2008.
  1. May 11, 2008 at 1:35 PM
    RememberMorrison
    RememberMorrison [OP] Yeah, I'm that Guy
    Atlanta
    08 Silver DC SB TRD OR TOW PKG
    Should I replace all of my fluids with synthetic? My Taco has 700 miles on it.
    Could I do the work myself, using standard tools with no jacks/ lifts, except for a wheel ramps.
    Changing the engine oil is simple, but can I do the others like the differential fluid?
    Basically I am asking if I can do the work myself...
    I am not asking about the benefits, just trying to avoid the labor charges.
  2. May 11, 2008 at 2:26 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    You can change to synthetics anytime you want.
    You can do all the work yourself, and you don't have to jack up the truck at all.
    Yes, you can do all the other oils yourself. Lots of people do it themselves, including myself.
  3. May 11, 2008 at 3:41 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    Janster's really smart w/her vehicles-go ahead and treat your truck to the good stuff-it'llpay you back:)
  4. May 11, 2008 at 3:55 PM
    RememberMorrison
    Atlanta
    Yup, are there any stickeys or write ups on changing fluids, besides engine oil?
  5. May 11, 2008 at 4:15 PM
    45longcolt
    45longcolt Well-Known Member
    DFW Area
    2020 Off Road
  6. May 11, 2008 at 5:48 PM
    RememberMorrison
    Atlanta
  7. May 11, 2008 at 6:23 PM
    ChrisDeSoup
    ChrisDeSoup Come on, Touch it......
    Up in ya
    08 Tacoma Double Cab PreRunner Sport
    Seatbelt Ding Mod All Weather Mats Gate Lock MOD Rear Spring TSB
    I have 1200 miles on mine, Just waiting forthe first oil change to go over to synth.
  8. May 11, 2008 at 10:24 PM
    RememberMorrison
    Atlanta
    Yeah thats what I am going to do. When are you going to make the switch. My brother said wait till 5,000 miles as well as Toyota.
    I was going to switch at 3,000, but I am not sure that the engine will be broken in enough then.
  9. May 12, 2008 at 2:39 PM
    ChrisDeSoup
    Up in ya
    I didn't know we needed to wait till 5k! I was going to do it myself at 3000 to 4000. I don't do a-lot of hard driving, mostly non commute times but Im just eager to make the switch and will probably hit 6 m0nths before 5k. I guess I will make the change at 5k or 6 months what ever comes first.
  10. May 12, 2008 at 3:24 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    you can switch then.....motor is broken in after around a thousand miles or so. after around 10 to 15k.....its really broken in, then you'll start seeing mileage increase, just a little, but every bit counts.
