synthetic 75w 90 manual tran oil awesome!!!
Discussion in '4 Cylinder' started by emacpgh, Aug 8, 2009.
  1. Aug 8, 2009 at 8:34 AM
    emacpgh
    emacpgh [OP] Well-Known Member
    eric
    pittsburgh
    silver streak mica sr5 sport
    Aries stainless steel bull bar , afe pro dry s filter , secondary air filter removal, scangauge II
    just changed to mobil 1 manual tran oil yesterday. highly recomend this upgrade!!! easy as pie with the fantastic 30k maintenance write up. 3 quarts 75w 90 , 15/16 inch (22 mm i believe) socket , and about 15 to 20 min. very noticeably smoother shifting, supposed mpg boost. this is the first manual that i have owned, and i love it!! ( learned to drive stick the hard way, on a ford f 450? 550? dumptruck.) now when i drive my gf's auto v6 suv it feels so sluggish, compaired to my 4cyl manual. on my way to work today i saw an old lady slip and fall. my first reaction was to laugh, but then ithought, what if i was an ant and she fell on top of me? then it didn't seem so funny. - jack handy
    Casper66 likes this.
  2. Aug 8, 2009 at 8:41 AM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    I agree completely. However it took a week or two for my shitfing to get smoother, but definietely got a nice MPG boost after my 30 K maintenance. also I think it is a 24 mm, but I am not positive
  3. Aug 8, 2009 at 8:51 AM
    emacpgh
    eric
    pittsburgh
    thanks, couldn't remember 22 or 24. so , yours got better over time? thats great. before i did the change i called the dealership to make sure it wasn't synth in already. they told me it was dyno. have you done the front and rear differentials or the transfer case yet? if so any noticeable difference?
  4. Aug 8, 2009 at 8:53 AM
    vtragweed
    vtragweed Beef Slut
    Willie
    VA
    08 2.7 SR5 Debadged
    afe pro-dry s filter, LCE headers, painted black steelies,color matched grill surround, URD short shifter, UWS black tool box
    i highly recommend doing the rest of the oils now did all of mine overall much smoother and a little less vibration
  5. Aug 8, 2009 at 8:56 AM
    DanGer
    I have switched EVERYTHING over to synthetic, both diffs, manual tranny, transfer case, and engine. I average around 24 mpg when my truck is rated for 22 highway :)
  6. Aug 8, 2009 at 8:56 AM
    emacpgh
    eric
    pittsburgh
    just noticed that you are the guy who did the 30k maintenance write up. awesome job!! imo best thread/post/write up on this site!!
  7. Aug 8, 2009 at 8:58 AM
    emacpgh
    eric
    pittsburgh
    hate to pester you ,but will my 09 access cab 4x4 need the additive when ido the diffs?
  8. Aug 8, 2009 at 8:59 AM
    DanGer
    Thank you very much! I did it with a lot of help from chris4x4 and will, (tacomaman06)
  9. Aug 8, 2009 at 9:00 AM
    DanGer
    Don't worry about pestering, questions are how we learn! But no you only need some quality gear oil. The only diffs that need additive is the TRD sport models with the limited slip
  10. Aug 8, 2009 at 9:06 AM
    emacpgh
    eric
    pittsburgh
    thanks a bunch, plan on doing the rest of the oils tomorrow. this is my first new vehicle and i am getting bit hard by the gear head bug!! absolutly love this truck, 5k on it .wanna get 300k more lol.
  11. Aug 8, 2009 at 9:10 AM
    DanGer
    Yup I have you exact model in '07 and without SR5 :)
  12. Aug 8, 2009 at 9:30 AM
    emacpgh
    eric
    pittsburgh
    looked at your 'my build' nice truck. we have pretty much the same goals for getting max mpgs while still having rough road capability . i drove 20,000 miles last year for work, so mpg is huge for me. iam a millwright, we basically do precision tuning of large equipment ie. turbin engines at powerplants and different machines at steel mills. great job if you like wrenching onstuff and dont mind being covered in grease. iam also getting the afe pro dry and the dynomax eventually . already removed secondary filter.
  13. Aug 8, 2009 at 9:36 AM
    DanGer
    Ya I have accepted the fact that it is a 4 banger and realized I got it for a reason. Most mufflers make it sound like a civic with a fart can and the ones that might sound powerful actually lose power (example: flowmaster). So I am getting the dynomax because it is the only muffler I have confidence in performance gains. My headers should be on by the middle of next week thanks greatly to another member on here. My theory is with a handful of extra ponies with the headers and muffler, my engine wont have to work as hard.
    As long as I don't get the "More power heavier foot syndrome" :D
    Btw that jbs sounds pretty awesome!
  14. Aug 8, 2009 at 11:17 AM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    I may be wrong but i heard 09 models have no lsd in the axle, they are traction control lsd(brakes), I'd check it out before u add additive
  15. Aug 9, 2009 at 8:11 AM
    Hootbro
    Hootbro Omnipotent
    Delaware
    2019 SR/SX Tacoma Access Cab 4x4 3.5L
    Correct! No LSD additive in 09's. Not even mentioned in the maintenance section of the owners manual.
  16. Aug 9, 2009 at 6:52 PM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    X2! I switched all that I could to synthetic - engine, transmission, and rear differential. Everything rides smooth.
  17. Aug 9, 2009 at 7:06 PM
    motoretro
    motoretro Well-Known Member
    Michigan
    09 Reg, Cab, 2.7 Four Cyl. manual trans
    Are you talking about a Mobil Manual Trans "specific oil"? I did not know Mobil manufactured such a fluid, or is it Mobil 1 Gear lube? I understand your enthusiasm although you might want to hold off until Winter gets here. I changed my 09's last winter with Amsoil MTG and had to drain it due to inability to shift from 1st to second in cold weather. Ended up putting original fluid back in and topping off with Valvoline 75w90 Dino. I was hoping to minimize the gear rattle & whine, no dice.
    Motoretro
  18. Aug 9, 2009 at 7:22 PM
    Tacoyota
    08 4wd
    c'mon nuthin lubes a tranny better than a million year old brontosoreass fart....
  19. Sep 20, 2017 at 7:28 PM
    Greenbean
    Greenbean B.S. Goodwrench
    Zack
    Western NC
    2015 AC 2.7L 5-spd 4x4 Utility Package
    I want to BUMP this thread and get updates on diff oils and trans fluids.
    Searched 4-cyl Forum by topic and lots of stuff on oil but limited info on M/T and diff fluids.
    I am about to do the trans and diffs on my 2015 w/@33K on them and am thinking about doing synthetics.
    Is Mobil1 the way to go still?
    I don't have my owners manual in front of me but can the diffs and trans use the same grade/visco?
  20. Sep 20, 2017 at 8:55 PM
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    I recently discovered that a 15/16 is the same as a 24 mm. My rear fill plug was rounded off and a buddy of mine whipped out a 15/16 and got it out in about a minute where a 24 mm wouldn't. Once you get into the larger sized metrics standards start working more often. A 10mm is just a 3/8". They both work. 9/16" and 14 mm are very close as well if I remember correctly. Since I got this Taco 3+ years ago I don't wrench on my DD regularly anymore so I'm starting to forget what I once knew.
