Synthetic for low mileage
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JakeF, Dec 7, 2019.
  1. Dec 7, 2019 at 10:58 AM
    JakeF
    JakeF [OP] Active Member
    Hi,
    I’ve been using regular oil on my 2013 v6 Double Cab Tacoma. I’m at 50,600 miles right now and wondering if I should switch to synthetic? I’ve read even with synthetic you should change it when you get to the date and then I’ve read you can wait a year to change it?
    Is it worth going to synthetic?
  2. Dec 7, 2019 at 11:04 AM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    Yeah man, no problem switching to synthetic. If you can afford it and feel better using synthetic go for it. I have a 2010 and have been using synthetic since 2012 and no issues with the engine. I change it every 6 months or 7,000 miles. That's just my preference though.
  3. Dec 7, 2019 at 11:08 AM
    Clearwater Bill
    Billy
    Largo Florida
    Synthetic, 10k changes assuming 'regular' driving (as opposed to severe duty).
    And lab tests will show it doesn't matter if you go over a specific time period.
    And no, there is no issue changing to syn or even back and forth. That's 80's mythology, along with 3k 3 month changes.
    However, if you are a short cycle believer, doing regular duty, don't bother spending your $ for syn. Modern dino oils are quite good, especically for those changing them under 7.5k.
  4. Dec 7, 2019 at 11:51 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Yes, change it to syn. As for what mileage to change it at ... Most syn oil manufacturers will state to follow your vehicle's oil change recommendations. Only a few syn oil manufacturers will list a max mileage - Amsoil states their syn oil Signature Line can go up to 25K. Mobil1 Extended is rated up to 15K; their Annual Protection is rated up to 20K.
    To best determine the oil change interval for any motor oil, submit an oil sample for analysis. A popular one is Blackstone. I use ALS Tribology; the company that tests the oil sample submitted via the Wix kit - which can some times be found on Amazon for under $15.
    Check out this thread for member results: https://www.tacomaworld.com/threads/used-oil-analysis-reports-2nd-generation-tacoma.182294/
    Looking at the various oil sample results, you can safely go to 7K on any reputable syn oil brand. Most of my results show I can go a little past 10K on Mobil1 High Mileage. I've changed to Pennzoil full syn and have not yet submitted an oil sample for that brand to determine the best oil change interval for me.
    Too Stroked likes this.
  5. Dec 8, 2019 at 8:04 AM
    Greenedmc
    Greenedmc Well-Known Member
    Daniel
    Elizabethton TN
    2014 Silver Tacoma Trd Off Road Access cab
    I switched to synthetic at around 40k and I’m about to roll over 100k with no problems but I stay with the 5k intervals. I did get a used oil analysis kit from blackstone for my next oil change tho.
  6. Dec 8, 2019 at 8:11 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    synthetic
    10,000 mile changes
  7. Dec 8, 2019 at 8:24 AM
    TacoBreaker
    TacoBreaker Well-Known Member
    08 Rust Bucket
    OME 885, 5100s
    go home.
    Switched mine to full syn at 1k, been changing about every 7.5k (should look back at log, think I started at 5k then backed off) either way over 180k now. No engine issues.
  8. Dec 8, 2019 at 8:30 AM
    Armed in Utah
    Armed in Utah Well-Known Member
    Utah's High Desert.......
    2003 Lexus LX 470
    Currently....my '14 has 84K on it.......sleeps a lot in the garage....
    having other vehicles to drive...I change the oil once a year...about 7K miles
    Use Wix# 51516XP synthetic rated filter....Walmart's Super Tech 5w30 syn oil
    Why use dino oil for 3K miles.....some guys may wear out the drain plug....:rofl:
    Pic.......'Gilbert' napping..........:)
    Minerva09 likes this.
  9. Dec 8, 2019 at 9:16 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    You were at 32,000 miles near the end of March, 2017: https://www.tacomaworld.com/threads/30k-service-maint-in-general-dealer-or-other-shop.482610/
    At 50,600 miles now, that averages to 3400 miles in 6 mo., or 6900 miles in a year. Yearly oil changes will be fine with synthetic. OE filters are recommended - they are designed well and priced cheap at your local Toyota dealer.
  10. Dec 8, 2019 at 9:20 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Stick to dino oil. Less $ same result. Change oil every 5K.
  11. Dec 8, 2019 at 9:23 AM
    Dagosa
    Dagosa Well-Known Member
    New England
    2015 Taco TRD OR
    Debaged
    I don’t think you’ll notice a difference if you change your oil every 5k. Toyota has been making 2-300 k engines running on mineral oil for decades. It might be better off to use low viscosity synthetic for differentials and transfer case in colder climates. I have no plans to switch from mineral and 5 k oil changes as the factory recommends. We moved a
    Corolla with 150 k over to our son who ran it well over 200k on regular oil and changes and it still ran like a top. This synthetic fetish is worthwhile if you want to extend oil change intervals, live in cold climates or have newer engines that require it.
    Otherwise, save your money.
  12. Dec 8, 2019 at 9:40 AM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    Walmart Supertech Synthetic oil is $14 gallon..
    Armed in Utah likes this.
  13. Dec 8, 2019 at 10:09 AM
    Armed in Utah
    2003 Lexus LX 470
    yep.......buy it online at Walmart in a three pack......$14/jug & free shipping
