Synthetic Oil?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SirGawain, Oct 3, 2015.
  1. Oct 3, 2015 at 9:38 AM
    SirGawain
    SirGawain [OP] The One from the Woods
    Central Texas
    2014 Tacoma Regular-Cab V4
    Hey all,
    So, I'm hoping you guys can help me figure something out: I've been getting conventional oil changes in my 2014 V4 Tacoma Single cab, and recently I was informed by a mega dealership that I needed to get full-synthetic oil changes for that engine. He also told me that I'd need to get it changed every 5000 miles.
    My questions are:
    A) Do I need to use full synthetic oil in my engine?
    B) How frequently should I change the oil if it's full-synthetic for my engine?
  2. Oct 3, 2015 at 9:43 AM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    You don't absolutely need it, but it will help prolong your engine life. I've been using Mobil 1 since about the second change, and I do drop it every 5000. It's running great.
    techbill likes this.
  3. Oct 3, 2015 at 9:50 AM
    blackradon
    blackradon Well-Known Member
    james
    YEG, Canada
    2014 sky silver metallic
    Good question OP, when I bought my truck, they offered a 'free oil change for life' when I bring my truck to the dealership but I have to bring it there or one of there sister dealers. They don't offer it for synthic oil and if I do want it I pay the difference which I think was 58 dollars CAN. Now, I've asked a few times, two doffernce people at the dealership about switching to synthic and they say it's not need if you keep up with doing it every 5000km( not miles).
    So I'm interestes in see what people think also!
  4. Oct 3, 2015 at 9:51 AM
    Mad Man Marty
    Mad Man Marty Well-Known Member
    Marty
    PA
    2007 Tacoma SR5 TRD Sport
    6speed, TRD intake, bed tie downs, weathertech rear,Tint
    A)no
    B)5k with shell t6 full synthetic.
  5. Oct 3, 2015 at 10:38 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    '12+ 2.7 engines call for 0w-20 synthetic.....comes with it from the factory. Even with synthetic, Toyots calls for a 5K OCI. All in the manual. :thumbsup:
    0uTkAsT likes this.
  6. Oct 3, 2015 at 10:42 AM
    NotRed
    NotRed Well-Known Member
    As stated, the 2.7 liter 4 cylinder engine in the newer Tacoma's calls for 0W20 oil, and that is not available in non-synthetic oil. They even tell you that if you can't get 0W20, it is "okay" to use 5W20 but to switch back to 0W20 at first opportunity.
    As to oil change interval, while synthetic oil may keep its lubricity properties longer, one of the main reasons for changing your oil is to replace the additives that get used up and to get rid of the combustion by-products that are what causes your oil to look dirty and dark after time. You don't want that crap floating around in your engine over a prolonged period and building up on parts.
  7. Oct 3, 2015 at 10:44 AM
    Yoda's TRD
    Yoda's TRD Well-Known Member
    David
    Haslett, MI
    2025 TRD Sport Hybrid
    I've used Royal Purple in the past - always loved it
  8. Oct 3, 2015 at 10:46 AM
    Plain Jane Taco
    USA
    :pray: Please, please don't let this one turn into a shithole......like all oil threads. :(
    Pick any flavor of 0w-20 synthetic oil and a filter of your choice. Change it every 5K miles. You're all set....enjoy life. :thumbsup:
    Lock it up boys! :locked:
    luchin and techbill like this.
  9. Oct 3, 2015 at 10:55 AM
    Green Jeans
    Green Jeans 6MT AC TRD OR 1GR-FE FTMFW
    Oregone
    '13 TRD Off-Road
    Welcome to TW @SirGawain
    I run Mobil 1 full synthetic in my motor. For oil filters I stick with OEM. I do oil changes every 5,000 miles.
    Here's a great post on why you should run OEM filters by @chris4x4
    Toyota Oil Filter (Made in Thailand) vs. the competition........
    https://www.tacomaworld.com/threads/toyota-oil-filter-made-in-thailand-vs-the-competition.123608/
    Cheers!
  10. Oct 3, 2015 at 10:59 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I had a 98 Tacoma, I also had free oil changes with conventional as long as I owned the vehicle, I owned the vehicle for 18 yrs and the dealer did every oil change. About yr 9 they switched to a synthic blend and I got that also. Truck ran fine, oil always clean and never burned a drop.
    Plus my dealer also had chocolate chip cookies while you wait. So I looked forward to getting my oil changed for free and getting free cookies.
  11. Oct 3, 2015 at 11:01 AM
    Conumdrum
    Conumdrum Well-Known Member
    Las Vegas
    2014 Tacoma
    2WD Sport Nav SC V-6 Mall crawler Home Depot truck
    He has a V-4 (hehe) not a V6.
  12. Oct 3, 2015 at 11:04 AM
    Green Jeans
    Oregone
    '13 TRD Off-Road
    Disregard my previous post @SirGawain and promptly buy yourself a 4.0 liter!
  13. Oct 3, 2015 at 11:04 AM
    Yota64
    Yota64 Professional Threadjacker
    I use the best oil and change it as if it were the worst. That should keep the truck healthy.
    Pennzoil Ultra Platinum every 5K. Oil Analysis recommended 8K but I'm gonna stick with 5 :)
    Shelf Life likes this.
  14. Oct 3, 2015 at 11:37 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    80's F1? o_O 120°. Mmmm
  15. Oct 3, 2015 at 11:49 AM
    Plain Jane Taco
    USA
    Or an old Saab.....or outboard motor perhaps.
  16. Oct 3, 2015 at 12:19 PM
    Plain Jane Taco
    USA
    Warranty
  17. Oct 3, 2015 at 12:48 PM
    trexTRD
    trexTRD Well-Known Member
    California
    Fox All Around, MaxTracs, Black & Red Leather Seats, Straight Pipe, and other crap...
    the purple stuff for sure :)
    I still do it every 5k not what its suppose to run for
  18. Oct 3, 2015 at 12:49 PM
    Plain Jane Taco
    USA
    Toyota recommends 10K OCI in all it's cars and some SUV's that use 0w-20. But not trucks. My guess is that Toyota understands that there's a good chance a truck will be used under "severe duty conditions" and recommends the 5K OCI as a precaution.
    NotRed likes this.
  19. Oct 4, 2015 at 10:48 AM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    I would highly recommend sticking with synthetic in the 2.7 of the 0w20 flavor. As someone who works in the oil industry, there's no real point in arguing over what oil is best. Out of all the name brands of oil you see on the shelf, only about 3 companies make it all. Pick whatever color bottle makes you sleep good at night and run it.
    That said, I prefer to run Pennzoil Ultra Platinum in my 3.4 V6 at 7.5k OCI's. It has returned the best results for me, quieter engine, and zero oil consumption. I used to religiously use Mobil 1 and burned through about half a quart every 3k. Now my engine doesn't use a drop of Ultra in 7500 mile intervals. If you really want to get in depth about oil, head over to bob is the oil guy (BITOG) forums and read. There are several rainy days worth of reading that can be done there on oil including test results from people that send used oil samples off to Blackstone labs to see how well the oil is performing in their engines. Lots of great information over there.
    Soul Surfer, spitdog and DoorDing like this.
  20. Oct 5, 2015 at 5:20 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    What makes good oil are the additive packages, and the base stocks. You want a good oil that can resist heat break-down better? Use a synthetic. You want a good oil which can protect your rotating components from contact and wear? Look up which ones have high antiwear additive packages.
