Synthetic Oil?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SirGawain, Oct 3, 2015.
  1. Oct 5, 2015 at 5:30 AM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2009 Prerunner TRD AccessCab
    New Navigation DVD/CD/TV/AV/Bluetooth Stereo and seat mod spacers, 1" hubcentric spacers, seat heaters....
    Don't fret over 0w-20w and 5w-20w, really really doesn't make a spit of difference, OMG, you could even run 5w-30w and there would be no consequences, obviously, if you live in a harsh winter environment, the lower weight oil would be prudent to run during the cold months....I switched to full syn at 141,000, have 287,000 give or take now, 7,500 change interval, 5w-20w, Toyota filters only, doesn't burn any oil. There is way too much put into these slight variances of weight ratings, way too much.....there are those that will go anal on this post, but, in reality, your truck will not know the difference as long as you stick to a regular change interval with new filter...onward....
  2. Oct 5, 2015 at 3:18 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    A lot of people say that synthetic oil prolongs engine life.
    I've put over 300K on several cars and over 400K on one using conventional oil.
    Some newer Toyota's call for 0W-20. I own one and abide by that, but on all of my other vehicles it's plain-Jane conventional oil for me.
    Bottom line - use what you feel comfortable with. Just be sure you do-it and use a good filter and above all else - change it yourself. That will really make it last longer.
    Plain Jane Taco likes this.
  3. Oct 5, 2015 at 6:37 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Yep, the only things synthetic does best is protect during extreme cold starts, extreme heat and holds up better to longer OCI's.
  4. Oct 5, 2015 at 9:52 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    if you do go synthetic on the v6 use 0w-30 REGARDLESS OF YOUR CLIMATE!
    Even HOT climates where ambients are 110+, 0w-X oil is still too thick to properly lubricate before operating temps, BUT its MUCH thinner than 5w-X / 10w-X on cold starts which will help with wear.
    Torspd and NAAC3TACO like this.
  5. Oct 6, 2015 at 12:25 AM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    What you are saying regarding viscosity doesn't make sense...
    The viscosity grade (for example, 5W-30) tells you the oil's thickness, or viscosity. A thin oil has a lower number and flows more easily, while thick oils have a higher number and are more resistant to flow.
    General rule of thumb, if your engine has high miles, then you would go to the thicker oil (0w-30w or higher). The dual viscosity just means it will flow better at cold temperatures (the 0w) and have thicker characteristics at operating temps (the 20w/30w or whatever), 30w being thicker than 20w.
  6. Oct 6, 2015 at 12:45 AM
    luchin
    luchin living the Canadian dream
    Vancouver Island
    15 6MT DCSB SR5
    OME 885 coils, Dakar leaf pack, Bilstein 5100 struts, SCS Matte Jet Black SR8 wheels, 265/75/16 Toyo Open Country AT II, Arrow cap, Truxedo Truxsport Tonneau cover, TRD Exhaust, colour matched grill.
    I think that's what nd4spdbh just said. When the engine is cold like at start up the 0 viscosity is still too thick to properly lubricate until the oil reaches operating temps. So not to go any higher in the lower viscosity number then 0.
  7. Oct 6, 2015 at 12:55 AM
    luchin
    Vancouver Island
    15 6MT DCSB SR5
    OP, there are a lot of threads on here about oil. At the end of the day the flavor of oil you use is up to you. The 4 cyl does require synthetic but the 4.0L V6 does not. I run 5/30 Mobil 1 synthetic oil and change every 5K kilometers or for you folks South of the border, 3K miles. Why? Because I don't do a lot of highway driving and I do mostly short trips. By short I mean less then 30 kilometers/18 miles one way.
    I have a V6 which calls for 5/30 dyno oil but I believe the 'hype' so I use Synthetic oil.
    Use the oil the manual recommends and for warranty purposes don't go beyond the recommended OCI. (oil change interval)
    As far as flavor, Mobil 1 and Penzoil Platinum seem to be popular.
  8. Oct 6, 2015 at 1:04 AM
    luchin
    Vancouver Island
    15 6MT DCSB SR5
  9. Oct 6, 2015 at 1:11 AM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    No, you got it wrong again...0w means the oil is thin at lower temps (winter) and will flow better when cold, it is not thick, the second number, IE: 20w/30w is the thickness of the oil as it reaches operating temperature. I am out of here, it is a madhouse...
  10. Oct 6, 2015 at 1:12 AM
    luchin
    Vancouver Island
    15 6MT DCSB SR5
    lol. That's what I said brother, nd4spd is simply saying that even 0 viscosity is still TOO thick to properly lubricate the engine at start up....how to explain...if they made -20Wxx, nd4spd would use it instead of 0Wxx for better protection at start up.
    You smoking what I'm rollin?
  11. Oct 6, 2015 at 3:11 AM
    sgtnewundies
    sgtnewundies Well-Known Member
    Eric
    Florida, Citrus County
    14 trd sport red
    Working on it now....UNDER CONSTRUCTION
    If you are going to change the oil at 5000 miles just use a regular oil and a good filter. I run 10000 miles on Mobil 1 full synthetics before changing and have been doing that for many years. All three of my trucks get that same interval. If you research OCI you will find increased wear metals with shorter intervals. It is not known why, it could be that the new oil pulls contaminants into suspension, or it could be that the new oil increases wear. Nevertheless, I researched oils for about 5 years before settling on my program.
    Lester Lugnut and luchin like this.
  12. Oct 6, 2015 at 3:17 AM
    luchin
    Vancouver Island
    15 6MT DCSB SR5
    Thanks for the heads up sgtnewundies. Noted.
  13. Oct 6, 2015 at 8:45 AM
    nd4spdbh
    SoCal
    this.
    0w-XX is still thicker at ambient temps of 110* compared to 30W at operating temps (220ish) So there is simply no point to run a 5w-30 syn when you can get a 0w-30 which will offer better startup protection and get to operating thickness quicker.
    TRDMountaineer likes this.
  14. Oct 6, 2015 at 10:37 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Crisco shortening is better than petroleum or synthetic based lubricant, plus it all comes back except for 1 table spoon...
  15. Oct 6, 2015 at 10:48 AM
    #35
    luchin
    Vancouver Island
    15 6MT DCSB SR5
    ...We're still talking about oil changes right.......:D
  16. Oct 6, 2015 at 10:49 AM
    #36
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Or baking, your choice haha....
    luchin[QUOTED] likes this.
  17. Oct 6, 2015 at 12:56 PM
    #37
    cheech1
    cheech1 Well-Known Member
    Kaneohe, HI
    08 PreRunner Off Road
    On most car forums, there's always numerous threads on oil, and always have differing opinions.
    Just run what the manufacturer recommends. I used to use 20w50 in my old BMW, friends were like, WTF??? That's what the manual called for.
    Lester Lugnut likes this.
  18. Oct 6, 2015 at 1:05 PM
    #38
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    Note: Conventional does not come in a 0w-20
  19. Oct 6, 2015 at 1:34 PM
    #39
    nd4spdbh
    SoCal
    This was a good read, and the reason i switched to 0w-30
    http://www.bobistheoilguy.com/motor-oil-101/
  20. Oct 6, 2015 at 1:40 PM
    #40
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    If you are comparing 0w20 to 5w20 the oils a basically the same at operating temp, but the 0w20 will thicken less as it cools so it's thinner at start up where most engine wear occurs. Oil flow is important during start up especially in cold temps.
