Synthetic or real oil
Discussion in '1st Gen. Tacomas (1995-2004)' started by 4421.frank, Mar 23, 2008.
  1. Mar 23, 2008 at 11:26 AM
    4421.frank
    4421.frank [OP] Well-Known Member
    Southside chicago
    02 double cab prerunner supercharged
    nasty dent on driver's side bed panel, shabby seats, cigarette burned interior roof, missing berf bar pad, cracked rain visor, removed hood scoop, unmentionable stain on back bench?
    Don't have the manual for my taco and I have to change the oil again. Is it better to use real or synthetic oil?
  2. Mar 23, 2008 at 3:09 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Ohh boy.... this subject has been run through the ringer.
    Are you saying synthetic isnt' real oil?
    (laugh - conventional versus synthetic)
    I run synthetic. Always have in all my vehicles. It's just something I personally like to do and don't mind spending the extra $$. It's a personal preference....
  3. Mar 23, 2008 at 3:26 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    I switche over to synthetic a while ago, and I just like the fact of something being created by scientist, and improves engine life and performance... But thats just me :D
  4. Mar 23, 2008 at 5:25 PM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    ARE Topper, Icon aal, OEM Audio+
    Get cold there in Southside Chicago? Go for it. Take a quart of each and put them in the freezer a day. Notice the difference in how they pour when extremely cold.
  5. Mar 23, 2008 at 5:31 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    go synthetic.......unless you have a ton of miles, which CAN lead to cleaning the engine too much and causing leaks......., if you have relatively low miles(under 100k)......definitely go for it!!! good improvements as far as im concerned.
  6. Mar 23, 2008 at 8:12 PM
    747 function > form
    1st Gen.
    I use Mobil 1 religiously: 240,000+ miles on a 91 accord I owned for 10+ years with zero engine work. I continue to use Mobil 1 with my 03 tacoma. However, I think that so long as I change the oil every 3k-5k miles, any oil, pure or synthetic, will do...just keep it clean.
  7. Apr 7, 2008 at 10:41 PM
    scard
    scard Active Member
    El Centro, CA
    2001 Toyota Tacoma PreRunner Total Chaos UCA's with Donahue Racing Coilovers
    Magnaflow Exhaust, Total Chaos Upper Control Arms with Donahue Racing Coilovers, Bilstien Shocks in the rear.
    so you're saying that if my tacoma has more than 100k it does more bad than good. I was about to some fake oil in my taco is there any proof in that theory.
  8. Apr 8, 2008 at 3:17 AM
    RoadKill
    RoadKill Northern Alliance: padawan
    North of the border
    First gen 4x4
    285x70x17 offset rims+ 1.5 spacers, rear Timbrens + 3 inch lift add a leaf, Sway-a-way coilovers + camburg control arms, Fender flares (2.5 inch), clear lights, headers, sliders, roll bar
    My religion as well, 250,000 clicks, no leaks, no mess, clean oil
  9. Apr 8, 2008 at 4:29 AM
    97YoterS
    97YoterS Well-Known Member
    North Carolina
    Chevrolet 2500HD Duramax 4x4
    None of your business
    I run synthetic in mine, its runs way better than regular oil, i think its synthetic that Tacoma's need
  10. Apr 8, 2008 at 1:59 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    not necessarily more bad than good......it may not cause any leaks with that many miles, and you may see improvements.....but it can clean too much and clean off the seals, maybe kind of rare or whatever....but it can happen. if you use synthetic....just watch for leaks........and if you do notice a leak, you can switch to mobil 1 high mileage.....good oil and may take care of the leak if it happens.
  11. Aug 15, 2009 at 3:32 PM
    Phisherman162
    Phisherman162 Active Member
    Portland, Oregon
    1998 2.7 4X4 & 2017 TRD OR
    1998: Body lift, debadged, ARB Bumper, Bilstein 5100 Shocks 2017: Leitner ACS rack, Treeline Rooftop tent
    I run Mobil 1 synthetic 15,000 mile in my rig. I wouldn't use it in a rig that eats oil. The molecules are small and will slide past the rings if there is too much play. My 98 taco has 198,000 and has no leaks. Mobil 1 is the way to go.
  12. Aug 15, 2009 at 3:54 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Synth or dino is fine as long as you keep your truck maintained at the specified intervals.
  13. Aug 15, 2009 at 4:00 PM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    :deadhorse:
    Definitely synthetic.
  14. Aug 16, 2009 at 5:07 AM
    ChrisYoTaCoMa
    ChrisYoTaCoMa Chrome's for Harleys and old farts
    Estero, Floriduh
    00 Taco 4x4 Ex cab 2.7 sr5 AT
    New Pioneer stereo, and all 4 speakers with Infinity components. Sirius satellite radio. Deckplate mod done. Door buzzer silenced forever thank God, tinted windows, vent visors, hood protector(bug guard), ceramic pads and new rotors, dechromed EVERYTHING. 2" Lift front 3" rear. Skyjacker AAL's and replacement leafs(and front spacers) from Fatbobsgarage.com. Skyjacker 7000 Hydro rear shocks, those Bilstein 5100 fronts are coming soon!
    I went from regular oil to Valvoline high mileage blend, then I am going full synthetic. It's kinda like weening it to the good stuff. 140K, no leaks, doesn't burn a drop between.
  15. Aug 16, 2009 at 8:45 AM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    do you know the difference between the two?
    read up about what synthetic vs "real" oil
    synthetic makes so much more sense
