Synthetic rear end oil....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bill in Ky, Aug 14, 2008.
  1. Aug 14, 2008 at 3:17 PM
    Bill in Ky
    Bill in Ky [OP] Well-Known Member
    Bright White 08 Reg 4X4 2.7 5spd SR5
    I got my first 4x4 in 1972...haven't been without one! I still like Chrome!
    I have replaced the oil in the front axle, tranismission and transfer case with
    synthetic gear oil.
    The rear axle calls for a straight 90W weight, not the 75W-90W like the others.
    I can's find any 90W synthetic. Those of you that have replaced the rear end oil, what did you use?
    Thanks, Bill
  2. Aug 14, 2008 at 3:49 PM
    allrsdup
    allrsdup Well-Known Member
    Sahuarita AZ.
    2018 dcsb trd offroad 4x4 Inferno
    i believe royal purple makes it. and with rp it already has friction modifier in it for the lsd.
  3. Aug 14, 2008 at 3:55 PM
    Cavender76
    Cavender76 Well-Known Member
    Clint Cavender
    Mobile, Alabama
    2020 SR5
    Removed Window Sticker
    I used 85W90 mobile 1 I have had no problem.
  4. Aug 14, 2008 at 7:05 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    on my 06 trd offroad prerunner, with the rear locker, i used mobil1 75w90, no problems at all.
  5. Aug 14, 2008 at 7:15 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Do you have the LSD? (non-Auto LSD)
    If Yes - you need oil + friction modifier. The manual should say how much it needs. Or - you can try getting gear lube that already had the friction modifier in it. Like mentioned earlier - Royal Purple and Amsoil Severe Gear also had the friction modifier in it.
    If you don't have the LSD, you don't need friction modifier.
