system build in my 07 access cab
Discussion in 'Audio & Video' started by dubbedSinner, Jul 15, 2010.
  1. Aug 9, 2011 at 9:44 AM
    #301
    dubbedSinner
    dubbedSinner [OP] blisters
    Lowered 3/4, debadged, led tails, projector headlights with hids, billet grill, blacked out windows, painted front and rear bumper and grill shell. Inside, 4 crappy 15's, suede wrapped headliner and door panel inserts, alpine double din, few painted pieces inside, and every led is either blue or white.
    ^ correct, each manufacture is different in how they do the parking brake saftey. I've noticed so far that panasonic's allow you to just ground the wire and it works fine, Kenwood's you have to wire up a relay so that the wire sees ground after the unit turns on, and Alpines have to have the pactr7 to get it to work.
  2. Aug 9, 2011 at 10:12 AM
    #302
    Namyo
    Namyo -
    Good lord! Haven't been in here for bout ten pages :eek: Lookin good! Wish I could hear it :thumbsup:
  3. Aug 9, 2011 at 11:35 AM
    #303
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    Is that baffle a single or double thick? It looks to be single from the pictures. You may want to consider adding a few more of those braces to the enclosure. With that much air pressure you'll need it.
  4. Aug 9, 2011 at 1:36 PM
    #304
    pinktaco808
    pinktaco808 Hot Steppa
    how big of a amp you gonna get for the sub and the mids? gonna need more batteries and maybe a big alt. Also is that safe charging at so high for the amps at 15.5
  5. Aug 9, 2011 at 2:02 PM
    #305
    mattg43
    mattg43 Well-Known Member
    Texas
    08 Prerunner SR5 DC
    SwingCase, driver side. PVC Bike rack. Aftermarket stereo.
    A 1000w(at 1 ohm) amp, even an A/B amp, will not need extra anything.
  6. Aug 9, 2011 at 2:28 PM
    #306
    ItalynStylion
    Steven
    DFW, Tx.
    I run a 900/5 and I'm on the stock battery and alt. I think I have 4 gauge running to the amp too ;)
  7. Aug 9, 2011 at 3:22 PM
    #307
    pinktaco808
    when he upgrade to a bigger amp. to power the 15
  8. Aug 9, 2011 at 8:35 PM
    #308
    dubbedSinner
    Yep, I'm constantly making changes on this haha
    It's just a single baffle. There is no need for any extra bracing or another baffle with these subs.
    I have an elemental designs NINe.1 amp for the subs coming in that can do 1200 rms, real world power at 12.2 volts. And an elemental designs NINe.4 4 channel for the mids/highs that will be doing 100x4@2ohms. I really do need a better battery and that would be enough for my application. If there was ever a time where both amps were pulling max current it would be about 100 amps. If the factory alt on my truck is a 100 amp alt (I have no clue what size it is) I really am only safe to be pulling 120 amps for everything, not just the audio. But if I got a big battery I should theoretically be alright. That is next on the list though, probably an xsd3400. Also most amps are stable up to 16volts so it wont hurt them at all.
    That can be true and cannot be true at the same time. There are so many factors that go into it. But really it's better to play it safe and be on the overkill side of things for the electrical.
    Like I said above, it depends on many things. You could have a 4000 watt amp and be fine on the stock electrical if you never turned the volume above two.
    To answer your question pinktaco I am planning on upgrading the electrical next because it is necessary imo.
  9. Aug 11, 2011 at 10:52 AM
    #309
    pinktaco808
    When he upgrade to bigger amps to power his subs. Idk how big amps he gonna upgrade to....
  10. Aug 12, 2011 at 11:54 PM
    #310
    shaneckc
    shaneckc Fyntünd Designs Vendor
    Shane
    Thousand Oaks, CA
    2014 SR Package DCLB 4x4
    Kenwoods (at least the newer ones) only need the parking brake wire grounded. No relay necessary.
  11. Aug 13, 2011 at 9:16 AM
    #311
    dubbedSinner
    ^ good to know
  12. Aug 16, 2011 at 9:28 PM
    #312
    dubbedSinner
    I've started the door pods for the kappa speakers that I have. Two 6.5's, one 4", and two tweeters will be in each door. Two 4" speakers will be in a pod where the sunvisers are, and a single 4" will be in the back on either side of the wall.
    Here are the baffles for all the pods with the holes cut out and the edges rounded over and rabbetted.
  13. Aug 16, 2011 at 9:30 PM
    #313
    dubbedSinner
    Fiberglass materials from us composites.
    Panels tapped up and ready to make the molds of.
  14. Aug 16, 2011 at 9:32 PM
    #314
    dubbedSinner
    Also got a couple new (to me) amps. An Elemental Designs NINe.1 for the subs and an Elemental Designs NINe.4 for the mids/highs.
  15. Aug 16, 2011 at 9:33 PM
    #315
    dubbedSinner
  16. Aug 16, 2011 at 9:35 PM
    #316
    dubbedSinner
    NINe.1 gut shots
  17. Aug 16, 2011 at 9:36 PM
    #317
    dubbedSinner
    NINe.4 gut shots
  18. Aug 16, 2011 at 11:29 PM
    #318
    pinktaco808
    where is the tweeter gonna be exact area?
  19. Aug 17, 2011 at 9:30 AM
    #319
    dubbedSinner
    They will be in the two small holes on the baffles in the doors
  20. Aug 18, 2011 at 6:41 PM
    #320
    dubbedSinner
    I got two layers of glass down on each panel and also got the baffle mounted on the passanger side. Added a new fuse block that has two outputs for both my amps and will start running new wires for the amps soon.
