system build in my 07 access cab
Discussion in 'Audio & Video' started by dubbedSinner, Jul 15, 2010.
  1. Mar 18, 2012 at 8:07 AM
    #381
    dubbedSinner
    dubbedSinner [OP] blisters
    Lowered 3/4, debadged, led tails, projector headlights with hids, billet grill, blacked out windows, painted front and rear bumper and grill shell. Inside, 4 crappy 15's, suede wrapped headliner and door panel inserts, alpine double din, few painted pieces inside, and every led is either blue or white.
    Got my second NINe.1 yesterday and started making an amp rack for both the mono blocks. The plan is to put the NINe.4 under the driver seat and I'm still debating where to put the crossovers. Also I lucked out and found the strapping cable for these amps that I forgot I got when I bought the first one. So now I'm just waiting on another rca and some black carpet to wrap the rack with.
    Once I get both NINe.1's in they will be strapped together and should do roughly 3000 watts rms at 2ohms with the voltage my truck runs at.
  2. Mar 18, 2012 at 11:49 AM
    #382
    dubbedSinner
    Got more work done on the rack. I got all the holes drilled for the wires, decided where I am going to be mounting the crossovers, and rounded over the edges. Now I just have to wait for the black carpet that I ordered to get here so that I can wrap it and wire everything up.
  3. Mar 18, 2012 at 11:52 AM
    #383
    dubbedSinner
    Just for the fun, what 3000+ real world rms power looks like
  4. Mar 18, 2012 at 12:56 PM
    #384
    07TacoRidah
    07TacoRidah SHHHH, this is interesting
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit OReiley battery terminals Big 3 upgrade (0g wiring) 2012 Headlight swap HID kit (headlight 6k/fog light 3k) Sylvania Zevo LED turn signals w/hyper flash resistors Rear back up light GY6 bulb Bullz Audio 0g wire Exterior: Dynamik Retro Projector style headlight housing Depo Euro Black Altezza LED tails 2012 front grill/bumper cover w/ fog light and hood swap Rear bumper swap (to chrome, painted w/bedliner paint) 99 Cents Store tailgate lock Suspension: XR Bilsteins Universal Air Suspension strut bag Custom UCA's DJM 4" rear drop kit 1" spindle spacer kit 4x4 leaf pack swap (middle leaf removed) Air Lift rear helper springs 4 Siria (Asco) 3/8" air valves 3 gallon air tank 1/4' air lines 90's Acura Integra door switches to air valves ViAir 450 air compressor Rims: 18x10 Work VS-KF front w/5" lip 18x11 Work VS-KF rear w/6" lip 225/40/18 tires all around Sick Speed 3 piece spike lug nuts Pepboys valve stem caps 1" wheel spacers all around Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Kenwood bluetooth headunit Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" single Hifonics subwoofer 10" sealed angled box Katana shift knob
    :eek::eek: just got inspired to put in more work on my int. modding ;):D
  5. Mar 18, 2012 at 1:26 PM
    #385
    dubbedSinner
    Ha, glad I could help out
  6. Mar 18, 2012 at 9:36 PM
    #386
    pinktaco808
    pinktaco808 Hot Steppa
    2 extrA batteries and a bigger alt?
  7. Mar 19, 2012 at 10:22 AM
    #387
    HighTQCummins
    HighTQCummins Instagram: stormtrooptaco
    Hank
    SE PA
    '12 SW DCSB Sport
    5% all around, derp'd wheels, FMS40, 30" E-Series, 55w 6k bi's, 35w 5k fogs
    damn that's a clean install, really like how that wall turned out w/ the E's in there.
    as a side note, depending on what you're tuned at, and given your cone area, you should be able to get a little hairtrick goin. I'm feedin my SA12's about 1200wrms maybe less and i can get some hair movin pretty good
  8. Mar 19, 2012 at 12:25 PM
    #388
    dubbedSinner
    When I get the cash that is the next step audio wise.
    I did try a shirt trick last week and it wasn't that impressive. It moved the shirt but not much. I'm hoping the second amp will change that. I would like to build a new enclosure and tune lower with more port area. I know that right now I'm only at a little under 10in per cube with this box.
  9. Apr 6, 2012 at 6:31 PM
    #389
    dubbedSinner
    Finished the amp rack a couple weeks ago but I had to send in my lap top for repair and couldn't post up pictures. I rewired the subs with some audiopipe 8 gauge that I got on ebay for real cheap which is good since it is more like 10 gauge. Soldered every end that goes into the push terminals.
  10. Apr 6, 2012 at 6:32 PM
    #390
    dubbedSinner
  11. Apr 6, 2012 at 6:32 PM
    #391
    dubbedSinner
    I did mount the crossovers but don't have any pictures of that. I'm still waiting for the toolmaker jig to be available again to start the door pods and then wire up the four channel and install all the speakers. And I am saving up for some batteries.
  12. Apr 21, 2012 at 5:01 PM
    #392
    Aw9d
    Aw9d That one guy
    Amazing build! Very clean work, good job.. I'd LOVE to hear it one day.
  13. Apr 21, 2012 at 9:34 PM
    #393
    dubbedSinner
    Thanks man, just got to get my electrical set and I'll be good.
  14. Oct 17, 2012 at 10:15 PM
    #394
    pinktaco808
    what happened with this man
  15. Oct 22, 2012 at 9:40 AM
    #395
    dubbedSinner
    Everything is ripped out and a new system has been in the plans for months now but I've been low on funds so I haven't been able to make any progress on anything with it.
  16. Oct 22, 2012 at 4:55 PM
    #396
    pinktaco808
    cheapmod =)
  17. Nov 3, 2012 at 8:49 PM
    #397
    96Taco
    96Taco Well-Known Member
    Alberta
    2014 DBL CAB Tacoma
    haha far out man thats like the 4th start again since this thread started! Will be nice once you get a finished product you can sit back and enjoy your hard work. Im sure this project will never be finished tho =)
  18. Nov 5, 2012 at 10:52 AM
    #398
    dubbedSinner
    Thanks, the 4th time is probably accurate haha. Here is a preview of whats to come. Keep in mind it is going to be months before any real progress begins though.
  19. Jul 17, 2013 at 1:02 PM
    #399
    HighTQCummins
    Hank
    SE PA
    '12 SW DCSB Sport
    i know this is a thread resurrection, but you got any updates on this?
  20. Jul 21, 2013 at 3:02 PM
    #400
    dubbedSinner
    Sadly there isn't much work done on it. I have deadned the whole truck, stripped out the back and started the floor of the new box. Still planning out everything and trying to make up my mind on how to build the box and also trying to find the time for it. Oh, and trying to find motivation.
