t-100 fuse problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by dmc1981, Dec 4, 2010.
  1. Dec 4, 2010 at 3:53 PM
    dmc1981
    dmc1981 [OP] New Member
    93 t-100
    1993 t-100
    all the accesories thats linked to the fuse box under the dash dont work. tail lights , flashers, radio,ign etc
    i replaced the relay and still nothing
    any ideas on where , what to look for??
    i must add the battery was replaced and the wires where crossed pos to neg neg to pos
  2. Dec 5, 2010 at 3:24 AM
    dmc1981
    93 t-100
  3. Dec 5, 2010 at 3:27 AM
    dmc1981
    93 t-100
  4. Dec 5, 2010 at 3:44 AM
    Trap
    Trap Well-Known Member
    Indego Ink TRD OR
    Electric Tail Gate Lock, EZ Down + Cable Mod, Galvanized Underbody, DK 9000, CloudRider SS Grill insert. BakFlip HD, Cabin Air Filter mod, Alarm, Zero Rust !
    Yes in under the hood the other fuse box check the bigger fuses there. Chances are one of the bigger ones is now dead. One at a time with a meter. Anway notes from the wise. Don't get the cables mixed up. There is diodes everywhere on autos now. You get them backwards and those diodes that should be blocking current will conduct till they evaporate. You could do some serious damage man. It's negative ground, look where the wires go before you connect them up.
    You may need to get some help if you cannot find a dead fuse is the cause. If you now have a bad diode you kind of sort of have to know how to trouble shoot to find them and test them.
    There is no polarity protection on Autos. There is also a fusible link somewhere near the battery on the main battery wire. It could be that to. It's blue.
    Actually it's near or inside the fuse box apparently and that is what is blown. Confirm with a meter. The blue fusible link. It will show open with a meter. It's blown if that is the case.
