T100 or similar engine 3.4V6 5VZ-FE
Discussion in 'Toyota Trucks & SUVs' started by TXRailroads73, Oct 2, 2018.
  1. Oct 2, 2018 at 6:43 PM
    TXRailroads73
    TXRailroads73 [OP] RUNNIN' WITH THE DEVIL AND MY ROAD DOG T100
    Adam
    The Lone Star State, RGV, TEXAS
    1997 Toyota T100 3.4V6 4WD
    None all stock
    As title says, Just wanted know if anyone out here has the same as I do...
    1997 Toyota T100 3.4 V6 DLX 4WD 5VZ-FE , either T100 or Taco that runs same engine
    Running Board Man likes this.
  2. Oct 2, 2018 at 6:51 PM
    TXRailroads73
    Adam
    None all stock
    Hola!
  3. Oct 2, 2018 at 7:12 PM
    TXRailroads73
    Adam
    None all stock
    In Houston now, but I go down a lot to visit family
  4. Oct 2, 2018 at 7:49 PM
    TXRailroads73
    Adam
    None all stock
    Been RGV all my life, been up here since 2010
  5. Oct 8, 2018 at 4:26 PM
    TXRailroads73
    Adam
    None all stock
    Anyone else a T100 owner?
  6. Oct 27, 2018 at 3:04 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Not a T100 but I have a 04 DCSB with a 3.4, what do you need to know?
  7. Oct 28, 2018 at 12:15 PM
    TXRailroads73
    Adam
    None all stock
    Happen to know correct spark plug wire set brand to use? I'd like to have OEM, what I have on now are SUMITOMO 2009 5Z-16 X-E, currently have 345305 miles on it, fixing to do valve cover gaskets, New plugs with wires, new coils coming from Denso
  8. Oct 28, 2018 at 5:20 PM
    TXRailroads73
    Adam
    None all stock
    Superdave1.0 likes this.
  9. Oct 28, 2018 at 5:21 PM
    TXRailroads73
    Adam
    None all stock
    These better than Denso?
  10. Oct 28, 2018 at 6:16 PM
    TXRailroads73
    Adam
    None all stock
    My bad, when I quoted your post, I assumed you meant plugs too, yeah I know Denso don't have wires, just wondering if I go with OEM wires or what you suggested, as for SP I want Denso with Denso coils, just wanted to know what wires to use, sorry for mix up
  11. Oct 28, 2018 at 8:01 PM
    2004TacomaSR5
    Jon
    Montana
    Denso or NGK plugs and wires are fine. A lot of Tacoma V6's have NGK plugs in one side and Denso on the other from the factory. When I did my plugs and wires I got Denso plugs from the dealer for $20 and a NGK harness for $50 and about 20k miles later and no problems to report.
  12. Oct 28, 2018 at 8:02 PM
    2004TacomaSR5
    Jon
    Montana
    Make sure to gap your plugs too, they claim to be gapped correctly from the dealer but they aren't.
  13. Oct 28, 2018 at 8:10 PM
    Tallgrass05
    Tallgrass05 Well-Known Member
    I got my 1998 T100 SR5 in 2001, it had come off a 3-year lease. It's been fantastically reliable, everything under the hood is original, except for the radiator and expendables like battery, hoses, belts, and plugs. It gets posted for sale tomorrow. I will miss her.
  14. Oct 28, 2018 at 8:32 PM
    TXRailroads73
    Adam
    None all stock
    You have the dual electrode plugs?
  15. Oct 28, 2018 at 8:35 PM
    TXRailroads73
    Adam
    None all stock
    That's one sweet T100!
  16. Oct 28, 2018 at 8:36 PM
    TXRailroads73
    Adam
    None all stock
    How many miles?
  17. Oct 28, 2018 at 8:50 PM
    Tallgrass05
    Photo taken today.
    TXRailroads73[OP] likes this.
  18. Oct 28, 2018 at 8:58 PM
    TXRailroads73
    Adam
    None all stock
    Fixing to do valve cover gaskets, CV axles, brakes, and looiloo for fuel pressure sensor got a CEL had for a while
  19. Oct 28, 2018 at 9:00 PM
    02hilux
    Planet: EARTH
    All 3.4 are dual
  20. Oct 28, 2018 at 10:40 PM
    2004TacomaSR5
    Jon
    Montana
    Yes
