T4R is down! T4R Check In Here
Discussion in '4Runners' started by 4Running Daily, Mar 5, 2013.
  1. Jul 6, 2013 at 10:57 PM
    #1381
    NJshadow93
    NJshadow93 Well-Known Member
    2019 White Tacoma TRD OR
    I'm still deciding on a set of sliders for mine. I hate to have to pay for shipping them from a big name brand, and the fabricator that has agreed to make them hasn't gotten back to me in over 2 weeks.:mad:
  2. Jul 6, 2013 at 11:17 PM
    #1382
    downpour11
    downpour11 Well-Known Member
    Rob
    Chico, CA
    96 4runner
    1996 4runner SR5 4x4 - 419,000 miles, 14" Spacer Lift
    I just got home and tried to load t4r... I instantly knew this thread would be back up lol
  3. Jul 6, 2013 at 11:21 PM
    #1383
    downpour11
    Rob
    Chico, CA
    96 4runner
    x2 pics. Right meow.
  4. Jul 6, 2013 at 11:33 PM
    #1384
    NJshadow93
    And no explanations as to why, even on Facebook :notsure:
  5. Jul 6, 2013 at 11:44 PM
    #1385
    downpour11
    Rob
    Chico, CA
    96 4runner
  6. Jul 7, 2013 at 12:46 AM
    #1386
    smkd13
    smkd13 Professional Idiot
    Ben
    Provo, UT
    19 DCSB OR
    Stock… for now
    Ha ha it didn't load and I can right here. DIRECTLY!!! Lol
    Or it didn't happen lol ;)
  7. Jul 7, 2013 at 4:25 AM
    #1387
    4Running Daily
    4Running Daily [OP] Long Live ZS
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
  8. Jul 7, 2013 at 11:25 AM
    #1388
    downpour11
    Rob
    Chico, CA
    96 4runner
    Who's bad ass SA 3rd gen? Is there a build thread for it?
  9. Jul 7, 2013 at 12:09 PM
    #1389
    4Running Daily
    Connor
    Tempe/San Diego
    1996 Toyota 4Runner
    His name is Nick. I don't know if he has a build thread, I'll check when I get home.
  10. Jul 7, 2013 at 3:20 PM
    #1390
    t4r4life
    t4r4life poptard and protein farts
    Eric
    East Bay Area
    1998 Toyota 4runner
    panty dropping mod
    i got led fever
  11. Jul 7, 2013 at 3:54 PM
    #1391
    downpour11
    Rob
    Chico, CA
    96 4runner
    Did you stumble across the heart of all LED manufacturing during your stay in China? :D
  12. Jul 13, 2013 at 1:07 PM
    #1392
    stmpjmpr
    stmpjmpr Well-Known Member
    Jimmy
    So Orange County, Ca
    2014 Tacoma Sport MGM 4X4
    Hello 4 runners, I will be changing the radiator fluid on my 2002 $runner, what do u suggest for anti-freeze, how difficult is it to change the water pump?
  13. Jul 13, 2013 at 2:06 PM
    #1393
    smkd13
    Ben
    Provo, UT
    19 DCSB OR
    Stock… for now
    Well you can run any of them honestly. The Toyota stuff is long lasting and less corrosive than green. I am using O'reillys gold universal and have been happy with it. You will want to flush if you swap though. Basically the question you have to ask yourself is "will I be able to get Toyota Antifreeze when I need it?"
    Any auto parts store carries the the normals: Green, orange, gold. Toyota is the only one to carry pink and red.
    And the water pump is a pretty good little job. Might as well do the timing belt too while your at it. Cause you have to tear into it when you do the pump. Why do the work twice.
    If your going to swap fluids though, then do this:
    Drain old fluid, fill with distilled water (must be distilled), run for ten min after warm, let cool, drain, refill with distilled, run for another ten min, let cool, drain, refill with new fluid
    Best process to do it.
  14. Jul 13, 2013 at 2:09 PM
    #1394
    stmpjmpr
    Jimmy
    Thanks smkd13 will give it a go, minus water pump. will let pros do that. prob do pump 1st. how much distilled water will i need?
  15. Jul 13, 2013 at 2:23 PM
    #1395
    emelianenkov
    emelianenkov Santa/Alex Emeliahoweveryouspellhislastname
    Alex
    NORTH POLE
    Alex's Shitbox Emporium
    NE Special Rust Edition
    I just got Toyota koolaid lol
  16. Jul 13, 2013 at 2:31 PM
    #1396
    smkd13
    Ben
    Provo, UT
    19 DCSB OR
    Stock… for now
    I used about 4 gallons when I did min. Just ran it until it came out clear. They are like $1 / gal at wallyworld.
  17. Jul 13, 2013 at 2:31 PM
    #1397
    smkd13
    Ben
    Provo, UT
    19 DCSB OR
    Stock… for now
    I can't remember does yours run off fruit punch or pink lemonade?
  18. Jul 13, 2013 at 3:03 PM
    #1398
    PMK
    PMK Well-Known Member
    Florida
    10 DCLB TRD Sport
    White, debadged, Mudflaps removed, ICON 2.5 in front, 2.0 in rear, all 4 corners have reservoirs, Spidertrax wheel spacers all around, BAMF bolt on sliders, Avid lightbar, oem transmission cooler converted to power steering cooler, aftermarket transmission cooler eliminating all oem transmission cooler stuff, remote mounted spin on transmission fluid filter TrueTrac rear differential, rear diff housing vented and filtered into left side bed box, URD MAF calibrator, Volant intake scoop into oem airbox, second filter removed, airbox internals smoothed, blended and polished throttle body, NST intake manifold spacer, Wet Okolee set covers, WeatherTech Digital Fit mats, inexpensive JVC single DIN, Scangage, AVS Stepshield door sill protectors, Doug Thorley Long Tube Headers, URD Y pipe with O2 sims.
    If it wasn't mentioned earlier, open the heater control to full hot to flush it also.
    PK
  19. Jul 13, 2013 at 3:27 PM
    #1399
    smkd13
    Ben
    Provo, UT
    19 DCSB OR
    Stock… for now
    ^^^^ yep that too. Slipped my mind when I was writing it all down.
  20. Jul 13, 2013 at 6:58 PM
    #1400
    emelianenkov
    Alex
    NORTH POLE
    Fruit punch of course
