T56 Transmission Swap
Discussion in 'X-Runners' started by Coupe, Aug 23, 2010.
  1. Feb 17, 2012 at 7:00 AM
    crazyengineer
    crazyengineer Well-Known Member
    patrick
    Bristol, TN
    05 Tacoma SR5 TRD Offroad
    K&N Cold Air Intake, Warn Winch and Bumper Guard, Wet Okole Seat Covers, Undercover Bed Cover, TRD Kenwood Head Unit, Infiniti Speakers, JL 13.5 inch pancake sub
    ha, i ruined a transmission a while back.....was thinking about putting one of these in. I wish I had. does anyone know about towing with these things?
    if i drop it into a 4wd?
    or if its even possible for the 4WD
  2. Mar 5, 2012 at 6:43 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    All that you will need, to tow with it, is a proper ring and pinion ratio. 4.10 - 4.30. To be most accurate, you would need ti use a RPM/ gear ratio calculator.
    I have a 4x4, and have the T56 installed. Had to modify the cross member a little as well.
    Mine is currently only two wheel drive. To make it 4x4 will cost another small chunk of change. You will have to talk with Rockland Standard Gear, to be able to get the proper transfercase and adapter plates.
    That is my eventual goal. Having the transfer case that I am thinking of , will make it selectable between 2wd, and AWD. Not 4 wheel drive. I like AWD. :D
  3. Apr 28, 2012 at 5:24 PM
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    i would love to see this. DOOO ITTTTT!
  4. Apr 30, 2012 at 6:24 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Had I not had to get my engine sleeved, this would already have been started. Lol. Still part of the plan though.
  5. Apr 30, 2012 at 9:56 AM
    Kelson
    Kelson
    Honolulu, Hawaii
    lol at least you know you'll be safe now. vrrrmmmpsshhh!!!!!
  6. May 1, 2012 at 3:09 PM
    crazyengineer
    patrick
    Bristol, TN
    Yep
    2nd gen 2005
  7. May 1, 2012 at 4:37 PM
    crazyengineer
    patrick
    Bristol, TN
    already have a 6 speed manual
    though, I got my transmission fixed already, I will swap whenever I mess the transmission up again (if i do that is)
  8. Sep 28, 2013 at 8:18 PM
    HumboldtTaco707
    HumboldtTaco707 Well-Known Member
    Humboldt
    2006 4x4 Blackout
    Dynomax cat-back with super turbo muffler dumped before axle, JBA LT headers, rear fox shocks w/ piggyback, wet okoles, 1 10" square kicker, husky liners, URD short throw, URD maf calibrator
    Anyone know of a shop in cali that does this or is the only place in Texas??
  9. Sep 29, 2013 at 12:43 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  10. Jun 6, 2014 at 4:45 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Thread revival, did you ever get the T-case adapter in?
    What T-case did you use?
    I'm looking at parts to restore a 60's chevy c10 and want to put a vortex 5.3 in with the t56 and I'd be happy if it was 4x4.
  11. Jun 7, 2014 at 6:11 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    www.urdusa.com is now making the T56 adapter kits. I started a thread in the 2nd Gen Tacoma forum.
    I have not yet started that portion if my build. What needs to be done to make that happen though, is that you would need to contact www.RSGear.com They have made the adapters for T56s. The transfer case is a Borg Warner ______ #. I would have to go back into my build thread and find out the exact #, but it is also listed on their website.
    It works by vacuum, to disengage the system, or if no vacuum it is always in AWD. Not 4wd.
    Edit***** Here is the 2nd Gen thread. http://www.tacomaworld.com/forum/2nd-gen-tacomas/329958-t56-transmission-swap-kit.html
    I wonder if the SS Trailblazer transmission would work with that engine? Since it is AWD. Except I don't know if they come in a manual?
