Tack Weld Mod for 96 Non-Tilt Column
Discussion in '1st Gen. Tacomas (1995-2004)' started by JADF, Jul 10, 2020.
  1. Jul 10, 2020 at 3:00 PM
    JADF
    JADF [OP] Well-Known Member
    Los Angeles, CA
    1996 Tacoma - 3RZ/A340F
    Has anyone done this on a non tilt column? I'm not able to find any info and would hate to rip everything apart just to find that its not possible.
  2. Jul 10, 2020 at 5:56 PM
    LearningToFly
    LearningToFly Well-Known Member
    Northeast Alabama
    2004 Double Cab
    Copied from this thread Non-tilt columns.
    The entire assembly, tube and shaft needs to come out. The steering wheel needs to come off to expose a single snap ring holding the main shaft in the tube. With the snap ring removed the main shaft should come out the bottom end of the tube. Hence the need to have the entire thing removed.
