Taco camper shell that could fit Motorcycle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Omosha, Oct 20, 2017.
  1. Oct 21, 2017 at 10:28 AM
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    Welp, no motorcycle for me
    fatfurious2[QUOTED] likes this.
  2. Oct 21, 2017 at 11:10 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    I have a bedslide too. That raised the floor of the bed by 4 inches. My Z125 would not fit under my cap (when I had it)
  3. Oct 21, 2017 at 7:41 PM
    Exracer2
    Exracer2 Well-Known Member
    Colchester Ontario
    2017 TRD Off-Road Alpine White ACLB
    BRO grille, KICKER speakers, Key amp, Hideaway sub
    There can be catastrophic damage to your motorcycle on some models using this type of “dolly”. The rear wheel spins and so does the output shaft via the front sprocket. Due to how the oil pump is driven off the crank there is no oil pressure or lubrication unless the motor is running. There is no lubrication to the output shaft bearings or the bearings on the related transmission shafts. Depending on the sump type and the transmission design there may be no oil to even splash lubricate.
    Can’t say there is 100% guaranteed damage but the risk is enough for me to avoid these types of dolly’s.
  4. Oct 21, 2017 at 7:51 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    I have the Bak flip G2 tonneau cover and I found a pup tent that fits the bed with the tailgate down and the entry to the tent is at the narrow end. So you have a place to stow your gear, haul your dirt bike, and sleep at night. I do the mountain bike riding and this is the plan I have come up with.
