Taco down, wheel fell off...
Discussion in 'Technical Chat' started by drifter, Jun 14, 2012.
  1. Jun 14, 2012 at 9:45 PM
    drifter
    drifter [OP] moderately modded
    Sam
    Oregon
    good stuff
    OME 880's/Nitrochargers, Rebuilt leaf packs, diff breather extension, hole in air box, truck toolbox, panasonic stereo, Mag light mount, Glasstite canopy, Custom designed/built light bar, Hella 500's.
    So the other day the wheel fell off on a buddy of mine's truck...make that the wheel and the spindle etc. (see pics)
    The truck driving through town at maybe 30 mph when it happened.
    Does anyone have an idea of why this happened? My thought was that one of the ball joints failed, thus causing the the other to fail, the CV to pull out, the steering rack shaft to break, etc.
    Any input on the cost to fix etc would be appreciated.
    Sam S.
  2. Jun 14, 2012 at 9:54 PM
    Maverick904
    Maverick904 Resident Fishing Expert
    Kameron
    Northeast Florida
    08 TRD Rugged Trail 4x4
    3" Procomp Lift, BDF Light Bar, Borla Stainless Cat-Back System, 2 10" Polk MM Subs, LED Interior Lighting, Pioneer Touch Screen, Kicker Speakers up front, Sonys in the back, Grillcraft grill, 20% tint, Weathertechs, Projector Retrofit Headlights. BHLM
    had he done any suspension work or had any done? anything under torqued or not checked after break in period could work its way loose and eventually cause wear to cause something else to break etc.
  3. Jun 14, 2012 at 9:59 PM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    probably the lower ball joint separating from its cup.
  4. Jun 14, 2012 at 10:13 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
  5. Jun 14, 2012 at 10:14 PM
    Ripcord
    Ripcord KM6PIM
    Jim
    Parker, Colorado
    Spruce Mica 2013 TRD-OR
    yep, LBJ failure. Its super common on 4runners, not so much on tacos. Tacoma LBJ and Outer tie rod ends are actually stronger than the 4runner ones and are a common swap as preventative maintenance.
  6. Jun 14, 2012 at 11:45 PM
    drifter
    Sam
    Oregon
    good stuff
    The truck was lifted with a Revtek spacer lift by the previous owners. However, the steering rack was replaced back in December. There was only a few hundred miles put on the truck since the rack replacement.
    Thanks for the info on the LBJ failures.
    I forgot to mention that it is a 95 4x4 4 cylinder regular cab manual. 3 inch lift on 33's.
  7. Jun 17, 2012 at 11:13 AM
    slo13zx3
    slo13zx3 Well-Known Member
    Brian
    forest city pa
    14 trd off 6speed nav
    ball joint fail
