Taco has its first problem...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Khaos, Aug 11, 2008.
  1. Aug 11, 2008 at 2:26 PM
    Khaos
    Khaos [OP] Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    Aside from TSB stuff (Tailgate and Leafs), my truck had been problem free. Yesterday my Taco began having its first problem. Neither of my keyless entry fobs will lock my truck any more. I can unlock my truck with the key fob, yet I can't lock it. Inside the truck I can press the button and they will lock, and the key in the door locks the doors.
    Anybody got an idea what the problem is?
  2. Aug 11, 2008 at 2:48 PM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    sounds like the fob has gone south.
  3. Aug 11, 2008 at 2:51 PM
    Khaos
    Bryant
    I forgot to mention, both key fobs I have do the same thing. They will unlock the truck, but will not lock. :mad:
  4. Aug 11, 2008 at 2:54 PM
    tacoskim
    tacoskim Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
    mine sometimes sticks. but i think its cuz of all the sand and salt water its exposed too.... have u gotten any sand in urs at all?
  5. Aug 11, 2008 at 3:07 PM
    j4x4ar3
    j4x4ar3 Well-Known Member
    Jay
    Austin, TX
    05 DC 4x4 - TRD Off Road - White
    Round Step Bars, Bed Mat, Cargo Bars, Rocky Mounts bike mount, JVC MP3 Head Unit, TRD Cat Back Exhaust, Rigid Industries front and rear light pods, dual HAM radio with remote mount heads.
    Ok wait.. if you're sitting inside the truck the buttons work but when you step outside the truck they don't work? Did they both come with dead batteries which could be significantly reducing their range??? Either that or your truck is in another dimention and you leaving it puts you out of phase with it. :)
  6. Aug 11, 2008 at 3:16 PM
    eordonez
    eordonez Living vicariously through mjp2
    Ed
    Chihuahua, Mexico
    TRD Sport Dcab 4x2 Black Sand Pearl
    OEM All Weather Mats, wheel locks, Toyota Silver Tube steps.....
    have you tried reprogramming them??
  7. Aug 11, 2008 at 3:19 PM
    Khaos
    Bryant
    How would I go about doing that?
  8. Aug 11, 2008 at 3:19 PM
    GunMetalSteak
    GunMetalSteak Active Member
    LA, CA
    07' PreRunner SR5
    Hood scoop, side steps.
    I think what he means is when he is inside the truck he can press the unlock/lock button on the door and it will lock.
  9. Aug 11, 2008 at 3:34 PM
    eordonez
    Ed
    Chihuahua, Mexico
    You have the rs3200 vip??
  10. Aug 11, 2008 at 3:39 PM
    Khaos
    Bryant
    I have no idea actually. If that's the stock keyless entry and alarm, yeah.
  11. Aug 11, 2008 at 4:51 PM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
  12. Aug 12, 2008 at 3:34 AM
    ph16drive
    ph16drive \m/.....\m/
    Paul
    Clevelandish
    08 DC, V6, 4x4, 5-Speed Auto
    Shorty antenna, Pop-&-Lock tailgate lock, Undercover bed cover, Aeroforce Interceptor gauge (custom mount), bed mat, AFE Pro Dry S air filter, map light mod, suspension TSB, Billy 5100's all around, Eibach springs, custom fuel tank armor plate, custom cat armor plate, painted front brake calipers, Grillcraft MX upper grill & Hella 500s, ipod adapter, dash pushbutton garage door opener, aux reverse lights, custom ipod nano 4G mount, seatbelt chime mod, custom bull bar w/ (3) Lightforce 140 Lance lights, POR-15 Chassis Coat Black drivetrain, illum 4x4 switch, xtra bed D-rings mod, locker anytime mod, diff breather relocation mod, ABS disable switch mod, Heated seats
    05 . . . maybe you checked this already but mine did the same thing once and I found out that one of my kids cracked the door open and it was latched but not closed completely. Once I closed the door, both fobs worked. I hope it's that simple for you . . . sorry if this doesn't help.
  13. Aug 12, 2008 at 7:51 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    I'd guess it's a sensor in the truck. I pulled pretty much every sensor out of my truck and since then I'm not able to lock the doors using the fob. Like you, I can unlock with the remote but just not lock.
    I figure the truck's computer thinks one of the doors isn't shut and thus won't lock the doors. Just like on yours I can lock using the button on the door.
    Not sure if that helps or not but at least you're not alone. :eek:
  14. Aug 19, 2008 at 1:35 PM
    Khaos
    Bryant
    Update:
    I have not bothered working on fixing it yet.
    Today I went to get something out of my truck and now it all works perfectly again... Odd...
  15. Aug 19, 2008 at 2:07 PM
    Johnson8537
    Johnson8537 Well-Known Member
    Oregon
    06 TRD SPORT 4x4 Double Cab Long bed
    Revtek Leveling Kit with 1 1/2 block spacer in rear. 17" MotoMetal blacks on 32" tires. Access Lorado Tonneau - Bed mat Billet Grill Tinted Windows Pioneer 700BT with PAC steering wheel inerface. Wet Okole Seat Covers Front and back.
    Take you FOB part and clean th connections and the board with alcohol and then put it back together... should fix it up... it will have black junk in there that needs cleaned out to make a good connection.
