Taco Horn Replacement.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ERdept, Jan 15, 2008.
  1. Jan 15, 2008 at 12:21 AM
    ERdept
    ERdept [OP] Well-Known Member
    Is there a louder sounding horn replaceable on the Taco WITHOUT going to an airhorn and the related tank, compressor/pump, etc.
    I just want a change out and wire hook-up that's louder.
  2. Jan 15, 2008 at 8:47 AM
    ERdept
  3. Jan 15, 2008 at 8:57 AM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    I'm not sure what the spec for the stock tacoma horn is but there are electric horns made for boats that put out well over 120 db.
  4. Jan 15, 2008 at 9:20 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    You could always just take out the little plastic pieces on your stock horns. They're there to keep water out, but you probably wouldn't have any issues. Look at the horn opening and just pop that obstruction out.
  5. Jan 16, 2008 at 6:31 AM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    I did that. Doesn't seem to make much difference. People still seem unaware of the horn when they're almost hitting me when I lay on it. I swear nothing short of train horns will wake some of these idiots up! :mad:
    I may have to look into those boat horns mentioned above.
  6. Jan 16, 2008 at 8:51 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I put in a set of Hella Supertone horns in my 96 Tacoma. They were cool
    (& LOUD).
    Yeah, I removed the plastic things out of my 07 horns. They're loud enough - atleast until I run outta other things to buy for the truck (that might be a long time).
    :D
  7. Jan 16, 2008 at 9:16 AM
    piercedtiger
    Jon
    Southern Tier, NY
    My problem is people have cut me off or tried to merge into my line while they are even with me, and when I lay on the horn they don't seem to hear it. Either they are completely F-ING oblivious to what's going on around them, or this horn sucks.
    My solution is to do a set of train horns like PB on TN. That way they'll either shit their pants, or look around to see WTF is going on and pay attention.
    But this all goes back to my idea that there should be more driver education before unleashing them on the public. But that's another rant, and my plans for train horns are more likely to happen.
  8. Jan 16, 2008 at 11:02 AM
    SteelCity
    SteelCity Wherever I May Roam
    Charleston, SC
    06 Radiant Rd DC LB PreRunner SR5 V6
    Optima Red/Stinger Terms, DT Headers, Empire O2 sim, Bluetooth, USASpec PA12TOY, Redline Struts, Extang Tonneu, OEM Bed Mat/front Skid/Roof Rack, Grillcraft Grille, Susp TSB, Toytec 1/2" front spacers, Raammat/Ensolite, Sony GTs, Curt Hitch, Tranny cooler, Wet Okoles, AFE Pro-Dry Drop in, Muth Sig Mirrors, Temp/Comp RVM, Silverstar HLs/Fogs, Royal Purple Diff/PS Fluid, Detroit Truetrac LSD, Hellwig rear sway bar, SG II, Filter Mag, 265/75/16 Nitto TGs
    How big are those Hellas? I was thinking about picking up a set.
  9. Jan 16, 2008 at 12:10 PM
    ERdept
    Voltage: 12V
    Frequency: 300 Hz low tone, 500 Hz high tone
    Sound level: 118 dB
    Connection: Flat plug
    Power consumption: Max 72W
    Dimensions: 4-27/32" dia. x 3-11/32" depth
  10. Jan 16, 2008 at 9:16 PM
    ERdept
    I bought the Hella Supertones off ebay and will let you know a subjective evaluation of the sound differences.
    I listened to my horn from inside with door/windows closed and outside near the front of the car as well for my base line.
  11. Jan 17, 2008 at 12:01 AM
    Janster
    Jandy
    Lancaster, PA
    :thumbsup:
    You get a pair of them (I think). I mounted mine side by side right in the middle of the grill on the 96. They're loud - but not a 'deep' (manly) sound. :D
  12. Jan 17, 2008 at 12:59 AM
    LazyRyan
    LazyRyan Wtf am i suppose to type here?
    Long Beach,CA
    08 DblCab PreRunner V6 TRD Sport
    BHLM, Black badges, Trex Eyelids, AFE drop in
    how bout throwin a train horn on it. or is that the same thing as a air horn..:eek:. i dont know, im dumb today.
  13. Jan 17, 2008 at 5:27 AM
    piercedtiger
    Jon
    Southern Tier, NY
    Train horns are big air horns.... Think of sizes going from those used by big rigs to ones for trains up to ones used by ships. I've seen a few for ships on trucks, but they take up the whole roof or bed! :D
    Train horns are usually louder and can still fit under the hood or under the body depending on what size you get.
    Check out this thread. I wanna copy this sometime! :D
    Pb's Air System & Train Horns - Toyota Forums :: Toyota Nation
  14. Jan 17, 2008 at 10:38 AM
    piercedtiger
    Jon
    Southern Tier, NY
    My seats are Scotch Guard'd. :D
  15. Jan 17, 2008 at 11:35 AM
    5862007 Active Member
    2007 Toyota Tacoma Regular Cab 4x2
    It's embarrassing to say now, but it just occurred to me that, in the past month that I've owned my truck, I have no idea what the horn sounds like. That's probably something that I should have looked at during the test drive, I suppose, but I had too many other questions about other aspects of the truck. I haven't had any occasion to use the horn in traffic since I bought it.
    Actually...I have multiple occasions to use my horn every day since I drive through Atlanta rush hour and deal with improper lane changers in front of me several times each trip. I figure that karma will get the best of them in the end, though, so I don't honk at them.
    I'll try the horn out at my earliest convenience.
  16. Jan 17, 2008 at 12:21 PM
    Hotdog
    Hotdog
    Wet Okole Underwear
    It's better(louder) than my friend's Chevy Silverado.
  17. Jan 17, 2008 at 6:15 PM
    SteelCity
    Charleston, SC
    Thanks ER. I do think that maybe the Taco horn is a bit weak - or the cab is insulated so well It doesn't seem as loud.
  18. Dec 5, 2008 at 8:21 PM
    csxrailfan
    csxrailfan Active Member
    North Cackalacky
    2021 Toyota Tacoma DBL CAB TRD / GONE: 2002 Toyota Tacoma Access Cab TRD, 2011 Tundra TRD
  19. Dec 5, 2008 at 8:26 PM
    ERdept
    Now that I have lived with the Hellas for a while, I'm VERY glad I put them on.
    I use them selectively though. But when you're horns are at head level of others and you need them and especially if there is an open window, they give off quite and impression.
    The tire installers saw them and asked his buddy to look at something under the hood while I was waiting for my Revo's to be installed.
    I was thinking, "What the H..." are they looking at, when they guy got under the hood, his buddy blew the horn and they all said a Fuk U to each other and had a good laugh.
    So did I.
    Loud, but not too loud to be arrested for and no airtank compressor to maintain, install and worry about.
