Taco Lean? Not Leveled?
Discussion in 'Suspension' started by TEX357, May 26, 2009.
  1. May 26, 2009 at 2:00 PM
    TEX357
    TEX357 [OP] TX
    05 TACOMA
    285\70-17 BFGoodrich KM2's 17x8 Pro Comp 7089
    Well I want to fix two things! first i want to fix the taco lean, but i want to know if i can put the front top plate spacer on my 3" Revtech Spacer? Or is that too much?
    Next question I feel as if my front of the truck is higher than the back, can i replace my Rear Block (1.5") with the to give me the proper leveling of the truck(Didnt Qualify for the TSB AAL)?
  2. May 26, 2009 at 2:13 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    not sure of the first question, but as for the second....what size block do you have in the rear now?? 1", 2", 3", etc?
  3. May 26, 2009 at 2:28 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    You should never stack spacers.....
    I'm not familiar with the RevTech kit...
    Did you have to compress the coils to put it in?
    How thick is the toytec top plate spacer?
  4. May 26, 2009 at 2:45 PM
    The_Hodge
    SC
    toytec top plate is 1/4" i'm pretty sure
  5. May 26, 2009 at 3:09 PM
    TEX357
    TEX357 [OP] TX
    05 TACOMA
    Rear block is 1.5"
  6. May 26, 2009 at 4:30 PM
    The_Hodge
    SC
    then yeah, u should get a lil bit out of the rear. depending on use though, the AAL may flatten and produce less lift over time. wont be anywhere quick though
  7. May 26, 2009 at 4:31 PM
    fixedforbroke
    fixedforbroke Well-Known Member
    St. Simons Island
    06 PreRunner SR5 White as Snow
    Stock the way god made her. (FOR NOW)
    yeah toytec spacer is for the driver side to compensate for driver weight and battery weight and steering wheel assembly and other stuff, and it is 1/4"
  8. May 26, 2009 at 4:46 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    The Toytec 5mm spacer "can" be used on the Revtec lift.
  9. May 26, 2009 at 4:56 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    I am not sure how his RevTek kit came, but mine included two 1/4" top plate spacers. Unless some extra large studs were used in order to stack a 1/2" worth of spacers on top(not sure how safe that would be), his only other option will be to take the passenger side spacer off, leaving the drivers side on.
  10. May 26, 2009 at 5:18 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ah..Ok then. Every Revtec I have seen had No spacers on the top.....
  11. May 27, 2009 at 2:25 PM
    TEX357
    TEX357 [OP] TX
    05 TACOMA
    Thanks for the help!
