Taco Lean, top plate spacer necessary with 5100s?
Discussion in 'Suspension' started by STLTaco09, Jun 26, 2009.
  1. Jun 29, 2009 at 3:58 PM
    STLTaco09
    STLTaco09 [OP] Well-Known Member
    5100's all around, fronts at 1.75". TSB leaf pack + Toytec TSB AAL
    I dont think the 5100s are meant to be used as coil overs as far as their adjustability when used with the stock springs (however I'm certainly not an expert, maybe someone can chime in and correct me if I'm wrong). What I mean is that I dont think the 5100s are typically run using different settings. For the people that used the stock coils with the 5100s, the taco lean is still there, therefore the change to the 5100s did nothing to help the lean. So in this case, the 1/4" top plate spacer is necessary.
    I've not researched any other setup than running stock coils, so I can't comment on any other setup.
  2. Jun 30, 2009 at 6:20 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    It's either use the top plate spacer for stock shocks or with 5100s on any setting with stock coils OR buy fully adjustable coilovers where you can adj for the lean without using spacer.
    My question about this concerns the use of fully adjustable coiovers...Will tightening one side up more to get rid of lean make the preload different enough to matter or feel like one side stiffer than the other? And when wheeling would it affect performance enough to make truck act wierd from one side being softer than the other?
  3. Jun 30, 2009 at 6:22 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    No. Most people preload the driver side by turning the collers a bit more than the passenger side to even the truck out. That little bit of preload isnt going to be noticable.
  4. Jun 30, 2009 at 6:38 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Didn't really think so for just that little bit but figured I'd ask anyway.
  5. Jun 30, 2009 at 8:25 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Assuming they have the coils on the proper side... if people have adjusted the 5100's differently to correct the lean, and they still have a leaning problem..... then I'd start investigating for other problems and perhaps even in the rear suspension.
    Ironically (for instance), if something in the rear isn't working...like a frozen shackle that can't pivot properly..... can actually pitch the opposite corner.
    Adjusting the 5100's differently isn't any big deal (as CHris mentioned), it really won't be noticable.
  6. Jun 30, 2009 at 8:57 AM
    STLTaco09
    Right, but If I'm not mistaken, Chris is referring to the 5100s used in a fully adjustable coilover setup (i.e. The Toytec ultimate lift kit). Not with the 0", .85", 1.75", and 2.5" settings.
  7. Jun 30, 2009 at 11:17 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Exactly. Im talking about the ones with the threaded collers. FWIW, if one side is off by an inch, you could always move the adjusting clip to the next level to account for the difference....:)
