taco lift help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by waller24, Feb 8, 2010.
  1. Feb 8, 2010 at 5:11 PM
    waller24
    waller24 [OP] Well-Known Member
    Alabama
    2007 Tacoma DC TRD 4x4 impulse red
    usa spec iphone adapter pa15, 1.5 coil lift, warn transformer, warn 8000 winch, UWS black short bed tool box, Grey weather tech mats, mounted streamlight stinger xt, rbc 4x4 light Alignment cam .15 .16 cast 2.24 2.5
    im installing this week a transformer and m8000 winch. I read on one thread this will drop the front an inch. I just dont want to have my frontend and tires eatin up so whats the best and economical way to raise it an inch or inch and a half? I dont want it any higher than a half inch or 1in over stock height. would the bilstein 5100's be sufficient if they were ajusted to 1.5 or do i really need spacers for the front like a 1.5 or 2.0in?
    Also once a lift of any sort has been added, how accurate has the toe alignment been in ya'lls experience, I guess im asking is the alignment still like factory driving as far as no pull?
    Thanks
  2. Feb 8, 2010 at 5:15 PM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    If you want to retain the factory ride then you should go with spacers.The bilstiens will give you better performance on and off road though and shouldnt change the ride that much.
  3. Feb 8, 2010 at 5:31 PM
    waller24
    Alabama
    ok??? so you just said the bilsteins are better but spacer provide a more factory ride?
  4. Feb 8, 2010 at 5:35 PM
    1TUFFTRD
    1TUFFTRD WTF
    06 AC with a skewp
    06 With a Skewp.
    Yes! bilstiens are better performance wise! The spacers will keep your stock factory ride. You said you wanted to retain the factory ride correct?
  5. Feb 8, 2010 at 5:45 PM
    waller24
    Alabama
    my focus is cost and mainly making sure my truck stay aligned after the toe'ing is done so that i do not eat my tires up. Plus were talking about added weight of about 200lbs
  6. Feb 8, 2010 at 5:50 PM
    1TUFFTRD
    1TUFFTRD WTF
    06 AC with a skewp
    06 With a Skewp.
    the spacers wont change a thing on alignment, so your good there. not sure about the shocks,im sure its possible to through something off there.i have the sway a ways and my truck drives straight!
  7. Feb 8, 2010 at 7:03 PM
    waller24
    Alabama
    how would ome 885 coils do?
  8. Feb 8, 2010 at 8:25 PM
    nuckinfuts
    nuckinfuts NyQuil on the rocks.
    Pacific NW
    '06 AC TRD Off-Road
    DT Long Tube Headers, Empire O2 simulator, catback, Shrockworks Sliders, Old Man Emu 3" lift with 885 coils (with 1/2" top plate spacer and Dakar Leaf packs), Hi-lift mounted in bed with 4XRAC mounts, WT floor liners, other stuffs
    You'd be better off with 886's with that much weight up front. Stay away from spacers unless you want to pay more later to redo it and get it right.
