Taco Pro vs. TRD Off Road
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FatChance99, Feb 25, 2019.
  1. Feb 25, 2019 at 11:39 AM
    FatChance99
    FatChance99 [OP] Well-Known Member
    Greg
    Denver, CO
    2019 Cav Blue TRD OR 4x4 DCSB
    None
    I'm new to trucks and new to off-road. From reading on the forum it looks like there are a lot of routes to take to upgrade your truck just like everything else. I assume Toyota started offering the Pro model to get a piece of the upgrade pie. Hey, look, we've already upgraded the truck for you. My question is if you'd rather buy a TRD Off-Road and upgrade it or if a Pro checks most of the upgrade boxes. It seems like most of the trucks on here are models other than Pro.
  2. Feb 25, 2019 at 11:42 AM
    Azza
    Azza ㅤㅤㅤㅤㅤㅤㅤㅤㅤ
    I’d rather buy an Off Road and use the money I saved to mod it, instead of buying a TRD Pro.
  3. Feb 25, 2019 at 11:44 AM
    OriginalMan
    OriginalMan Well-Known Member
    Oahu 808
    2017 TRD OR 4x4
    Bilstein 5100/888; 5160/AAL; SCS Ray10 Limited Gold; 285/70 Cooper STT PRO; AVS; OVTuned; Prinsu Cabrac; RCI Bedrack; TC Bed Stiffner
    The pro comes with a 5.6 V8 motor. Ask your sales rep. Use the up up down down left right left right to unlock it.
  4. Feb 25, 2019 at 11:46 AM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    Giggity
    Jukeboxx13 and GillyLink like this.
  5. Feb 25, 2019 at 11:46 AM
    Freegolf
    Freegolf Well-Known Member
    Denver
    2016 offroad, manual tran
    This topic is :deadhorse:. Here's the general. Since you're new to trucks and offroading the pro could be tailored for people like you. A truck well equipped for anything you could throw at it from factory. People who seriously offroad could buy lower end models and upgrade themselves because they know what they are doing, and will save themselves a shit ton of money. Rather than paying the extra cash for some people consider an underwhelming upgrade that is the pro.
    Jukeboxx13, jeff b, Ckerper and 11 others like this.
  6. Feb 25, 2019 at 11:52 AM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    When the Pro was introduced in 2017 it was the only way to get leather seats other than a Limited model. Now with the leather seats being an option on the Sport and OR, the real difference is the suspension and the hood scoop vs. the OR. Also with Toyota dropping the Pro colors to the rest of the lineup each year, the color exclusiveness is not even there. Add on that some dealers are charging an extra fee called market adjustment or something like that for the Pro, it makes more sense to get the OR and upgrade to your preference.
  7. Feb 25, 2019 at 11:57 AM
    FatChance99
    Greg
    Denver, CO
    None
    That's kind of what I thought most people would do. I did search the forum to see if this had been discussed before. I didn't see anything. Sorry to resurrect a well debated subject.
    Freegolf[QUOTED] likes this.
  8. Feb 25, 2019 at 12:04 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Get the Off Road Manual
    Rick111, 24-7, Gunnar_19 and 17 others like this.
  9. Feb 25, 2019 at 12:16 PM
    WiscoPat
    WiscoPat One does not simply purchase a Ridgeline
    Pat
    Wisconsin
    2019 TRDOR Tacoma 1995 JDM 80 Series
    Mall Rated
    Well discussed topic, but it's fine to ask questions - this is a forum after all.
    Depends on your intended use for the truck. The primary difference that matters between the two trims is the Fox racing shocks with 2.5 reservoirs that come with the Pro, which are overkill for most Taco owners, in my view. The Off-Road trim comes with Bilstein's that are perfectly adequate for most off-roading situations you will probably encounter, as the majority of us will not be rock crawling or cruising through Moab on a regular basis.
    Otherwise, the differences are mainly cosmetic in nature, with some blacked-out headlights/tailights, faux hood scoop, grille, wheels, and badging on the Pro. Same engine, transmission, approach/breakover/departure angles, ground clearance, rear locker, etc. Are those differences worth the extra $6k-$10k over a TRD Off-Road? That's up to you. Both are great, again just depends on your intended usage and budget. My signature shows my personal preference.
  10. Feb 25, 2019 at 12:21 PM
    navin r
    navin r Well-Known Member
    2017 double cab short bed trd off road 4wd w/ premium pkg.
    OP, if you're new to off-roading, I'd skip the pro. I bought a 17' OR, but only because the pro at that time didn't offer a sunroof, which I wanted. If a person has very specific thoughts on what they want their suspension/ lift to do, they're better off buying a lower model and building it up. A person that doesn't have a specific plan, but wants a good off road truck, would be fine buying either the OR or the pro. Go with the pro if the dollars aren't a big deal to you. Even if the dollars are important, you might still consider the pro; it'll have great resale. Most people who do a lot of mods to any vehicle do it because that's what they want to do, knowing they will never get most of their dollars back when they eventually sell the vehicle.
  11. Feb 25, 2019 at 12:25 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Depends on how you drive and when you plan to upgrade the suspension. The off-road is very capable off-road stock, the sport actually does the trick but if you plan to get your feet wet off-road before upgrading the suspension it’s kind of a no brainer. If you need the skewp in your life but prefer the off-road suspension then you might want to go that route. No one on this site will know what you want. I assume you have driven both and know the actual differences.
  12. Feb 25, 2019 at 12:34 PM
    ksj
    ksj Well-Known Member
    Pacific NW
    2018 Cavalry Blue TRD Pro
    265/70-17 KO2
    Not according to Toyota...
    Source
    6MTPro, Toki, GillyLink and 3 others like this.
  13. Feb 25, 2019 at 12:37 PM
    gurneyeagle
    gurneyeagle Well-Known Member
    Saint Augustine, FL/Houston, TX
    2008 Tacoma SR5, 2018 Audi TT RS, 2018 Tacoma TRD Off Road (Cement), 2019 MDX
    Soooooooooooooooooo, what about this thought.....
    What percentage of your original purchase price would you get back on a Pro versus what you would get back (original price plus mods) on an Off Road assuming you didn't de-mod the Off Road?
    Flash1034 likes this.
  14. Feb 25, 2019 at 12:50 PM
    WiscoPat
    Pat
    Wisconsin
    Mall Rated
    Ah - should have said similar. Learn something every day.
    Depends on a quite few variables, chiefly mileage. I'm not sure how the value of a Pro holds up over time in comparison to a stock OR, as we don't have long-term data with them yet. I assume the Pro would be slightly higher, but not as much of a discrepancy between the difference of new models.
  15. Feb 25, 2019 at 12:54 PM
    TOMRR
    TOMRR Well-Known Member
    Tom
    Mass
    2016 TRD OFFROAD, DCSB, AUTO, BLAZING BLUE, PREMIUM JBL TECT.
    Stock TRD OFF ROAD DCSB AUTO JBL TECT. Bed Mat Heated and turn signal mirrors Wet Okole Front Seat Covers Prodigy Brake Controler Front Skid Plate Power Wagon Badge Tint Driver and Pessenger door windows Inchannel window vents
    Not worth the extra $$$ the OFF ROAD is all you really need !!
    Rick111, Gunnar_19 and remgu2000 like this.
  16. Feb 25, 2019 at 12:54 PM
    kakwvu
    kakwvu Almost Heaven
    Kyle
    WV
    ‘24 JLURX
    :headbang:
  17. Feb 25, 2019 at 1:24 PM
    supmet
    supmet Well-Known Member
    Paul
    Rancho Cucamonga, CA
    2019 White TRD OR 4x4
    It's debatable at MSRP but I think the OR is a better deal. Throw in the $5-10k pro market adjustment and I don't see why anyone is buying a Pro right now.
    Rick111, Jukeboxx13 and nickbozilov like this.
  18. Feb 25, 2019 at 1:26 PM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    The money saved on an off road vs pro will go a hell of a lot further in mods than the one skid plate and the suspension of a pro.
  19. Feb 25, 2019 at 2:04 PM
    Chief Dub
    Chief Dub Well-Known Member
    18 TRD OR DCSB QKSD
    None, finally back in a Taco
    Wasn’t the pro introduced in 15? I may have been duped by my dealer back then, but I’m pretty sure it was legit lol.
    BTW, I am just playing. I knew what you meant.
    Arailt and daddy_o[QUOTED] like this.
  20. Feb 25, 2019 at 2:11 PM
    Chief Dub
    18 TRD OR DCSB QKSD
    I loved my pro, and I got the same percentile return on it upon trade-in. In 2015 it wasn’t nearly as heavily priced-up, nor was it as heavily geared up.
    My second time around, I bought an 18 TRD OR. There are some characteristics I love about the pros, and I am sure they hold value, but the market is more specific. I enjoy mods, would eventually have replaced everything that differentiates it from an OR, and leather was a sticking point because I didn’t want it (my 15 had weather resistant cloth and I loved it.)
    To each their own, but you can certainly replace your suspension (the only truly differentiating factor between the two) with something even more capable than the PRO has and still come in under the bill of a new PRO. And mods almost never add value, but used FOX and King suspensions sell on their own if you de-mod prior to sale.
    That snorkle tho!!!!
    ButteTRDPro and Flash1034 like this.
