Taco Tabs Front Alignment Kit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PMK, Mar 21, 2020.
  1. Nov 18, 2020 at 4:28 AM
    #121
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Which tabs are in there now? Looks like you have to do the same thing I did, although mine wasn't pulling in any direction at any time.
  2. Nov 18, 2020 at 8:01 AM
    #122
    t.hornstra
    t.hornstra Well-Known Member
    Ted
    NorCal
    White with 4 wheels
    Little this. Little that 4x4 Swap’d PreRunner
    front neutral. Rear most outward
  3. Nov 18, 2020 at 11:14 AM
    #123
    Chris(NJ)
    08 Indigo 4x4 DC OR
    Well, with a positive .7 and a -.7, you could technically go inward on the one side and outward on the other for the camber settings and get those closer to each other.
    Not sure how that would change the caster numbers, but you could see how it changes it then play w/ the caster tabs after.
  4. Nov 18, 2020 at 11:27 AM
    #124
    Muddinfun
    Muddinfun Well-Known Member
    Just to throw some more info into this, with those numbers, you probably have a pretty substantial Taco lean. I would get the truck leveled side to side. As for your tires, if they are able to overcome the left direction alignment pull and still pull to the right, that's a very substantial pull caused by the tires. My suggestion to swap the tires side to side was to confirm that the tires are the cause of the right side pull. To me that seems like some pretty junk tires. If leveling out the truck doesn't completely fix the alignment numbers, then we can go from there with cam change suggestions.
    t.hornstra and Chris(NJ) like this.
  5. Nov 18, 2020 at 12:07 PM
    #125
    t.hornstra
    Ted
    NorCal
    White with 4 wheels
    it does have a little lean. I’ll see about leveling it out and playing with the camber tabs.
  6. Nov 18, 2020 at 2:11 PM
    #126
    t.hornstra
    Ted
    NorCal
    White with 4 wheels
    So I swapped the camber tabs during my ‘lunch break’ from dad duties. Went outboard on driver, inboard on passenger and swapped the front tires. Truck drives straight now. Steering wheel is off, again, but that'll be easy. I’ll get into an alignment here in the next few weeks. only thing i noticed is a slight rub at full lock in reverse, but that's easy with some grinding/pounding later on. Taking possession of a new house this coming week so things are busy.
  7. Nov 23, 2020 at 12:03 AM
    #127
    Matty0317
    Matty0317 @taco.hog
    Jacksonville, NC
    '17 TRD O/R DCSB 4x4
    Dirt King +3.5 LT, RCV Axles, Mobtown Sliders, BAMF skids, 4.88's, Relentless Fabrication Front/Rear, Archive Garage Rear, Baja Designs
    Any solutions for a 3rd gen? @Andy@Poly I just ordered a kit thinking it would work for a 3rd gen, after reading this looks like i'll have to cancel for now. damnit.:facepalm:
  8. Nov 23, 2020 at 5:06 AM
    #128
    Chris(NJ)
    08 Indigo 4x4 DC OR
  9. Nov 23, 2020 at 6:14 AM
    #129
    Matty0317
    Matty0317 @taco.hog
    Jacksonville, NC
  10. Jan 1, 2021 at 4:59 PM
    #130
    Taco-Obsessed
    Already got the Marlin LCA brace in a box ready to weld on and now hearing more about these. Perhaps silly question, but would these be compatible, and if so is there even a benefit to both? Dont think there is a benefit, but no harm in asking.
  11. Jan 1, 2021 at 5:31 PM
    #131
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Based off of pictures alone, they don’t appear to be compatible together. It’s because of the little tabs on the bottom of this kit that sticks out. It could be shaved off though.
    Yes there’s benefit to both. Even with kits like marlin crawler or total chaos, you can still knock yourself out of alignment. This prevents that.
  12. Jan 1, 2021 at 6:00 PM
    #132
    Taco-Obsessed
    I follow you there , but with this kit no need for Marlin (redundant)?
  13. Jan 1, 2021 at 6:01 PM
    #133
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Not necessarily. With this and stock tabs, you could theoretically knock the stock tabs flat still. The two kits serve different purposes.
    Nopro likes this.
  14. Jan 1, 2021 at 6:05 PM
    #134
    Taco-Obsessed
    Ok, thanks. I'll proceed with my Marlin, and if I still am getting knocked out of alignment after wheeling, I'll investigate adding these (shaving down, etc).
    EatSleepTacos[QUOTED] likes this.
  15. Jan 1, 2021 at 6:05 PM
    #135
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    There’s another similar product, I think it’s called bison something or other, that locks alignment in place and would work with Marlin. Something to consider.
    Nopro and Taco-Obsessed[QUOTED] like this.
  16. Jan 1, 2021 at 6:07 PM
    #136
    Taco-Obsessed
    Great, thanks as always.
  17. Jan 1, 2021 at 6:08 PM
    #137
    65skyturbo
    65skyturbo Well-Known Member
    Mesa, AZ
    06 Speedway Blue DCSB TRD Off Road
  18. Jan 1, 2021 at 6:10 PM
    #138
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Yep, those. At a glance they give a little more adjustability than this kit but also aren’t quite as rock solid. Hard for me to say though since I haven’t had them in my hands.
  19. Aug 1, 2021 at 4:18 PM
    #139
    dpf88101
    dpf88101 Well-Known Member
    Just had these “”Taco Tabs” put on while replacing steering rack and a new set of oem LCA’s with Whiteline bushings. The alignment shop got me to 0 camber 0 toe with 3.4 degrees of caster per side.
    i told them to start at max (all the way outboard) for the caster and neutral for the front (camber )
    they put the max caster in but said they couldn’t get the neutral camber in ? Said it wouldn’t line the holes up? They used the max outboard for the camber ?
    Does this sound right.
    I have a BDS 6 inch lift (DB) with fox 2.5 coilovers so technically it should be at stock settings to start.
    they used the icon billet UCA’s to dial in the alignment.
    does this sound correct? I am confused why they couldn’t get the front (camber) to be neutral an the back (caster ) to be maxed (outboard ) to start
  20. Aug 1, 2021 at 4:23 PM
    #140
    montijo505
    montijo505 Moon soon?
    Rio Rancho, New Mexico
    08 4Runner SR5/ AKA The Great White Pig
    Only thing I can think of is they used the incorrect plates. One set is for neutral, the other for either max or min, you just flip them over for what you’re trying to do.
