Tacoma’s door rattle JBL
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JohnnyTaco215, Jun 3, 2018.
My 2017 Trd Sport with the JBL audio upgrade has a rattle ...anyone experience the same?
  1. Is it common?
    12 vote(s)
    63.2%
  2. Is it only JBL upgrade?
    7 vote(s)
    36.8%
  1. Jun 3, 2018 at 8:36 AM
    JohnnyTaco215
    JohnnyTaco215 [OP] Member
    2017 TRD Sport Technology/Towing package Graphite Grey
    Stock
    Hey I’m new to TacomaWorld!!!!
    StayinStock likes this.
  2. Jun 3, 2018 at 8:41 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    You need to be more descriptive....
  3. Jun 3, 2018 at 8:44 AM
    TacoManOne
    TacoManOne YotaWerx Authorized Tuner
    Paul
    Liberty Lake, WA
    2018 Blazing Blue TRDOR DCLB Premium JBL
    YotaWerx Tuned, Meso stuff, JBL upgrades, Bilstein 6112/5160, RAS
    I have a 2018 with the JBL and the doors rattle at high volume high bass.
    Garrett75x and JohnnyTaco215[OP] like this.
  4. Jun 3, 2018 at 8:47 AM
    JohnnyTaco215
    Stock
    Thanks for the response!!!! Well I have a 2017 Tacoma Sport with the upgrade JBL audio and I’ve noticed a rattle type noise when I play music....only on the front driver side. It comes and goes, sounds like a cheap plastic rattle... I’ve removed the panel and checked all of the plastic hardware and taped everything down... it seems to go away and then it comes back..
    ydlee likes this.
  5. Jun 3, 2018 at 8:47 AM
    devildog0327
    devildog0327 Well-Known Member
    Johnny
    Carson City, NV
    2017 DC TRD Offroad
    Whatever I learn from you guys
    Welcome to TW. This site will want you to spend money on your truck!
    If it’s under warranty have the dealer fix it. Otherwise, a common rattle on the passenger a pillar. I also suggest dynamat or other sound deadening material if you want it to sound a little better. The search button is your friend ;)
  6. Jun 3, 2018 at 8:50 AM
    JohnnyTaco215
    Stock
    Thanks guys but I took it to the dealer and they couldn’t “replicate “ the sound .... no help there. I’m just going to take the panel off again and turn the volume up and try to pinpoint the rattle
  7. Jun 3, 2018 at 10:04 AM
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    Gen 3
    bunch of stuff - Bro Pro style
    Maybe truck doesn't like your choice of music. My truck, if it rattles I cant tell.
  8. Jun 3, 2018 at 10:06 AM
    JohnnyTaco215
    Stock
    Maybe you’re right lol... it only rattles on certain songs
    bobrown14 likes this.
  9. Jun 3, 2018 at 10:27 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    While you have the door panels off you might want to put sound deadener in the doors.
    bobrown14 and JohnnyTaco215[OP] like this.
  10. Jun 3, 2018 at 10:35 AM
    JohnnyTaco215
    Stock
    That was going to be my last option... I’m at that option now unfortunately. Thanks
    shakerhood likes this.
  11. Jun 3, 2018 at 12:02 PM
    modifiedtaco
    modifiedtaco Well-Known Member
    Alex
    2016 Magnetic Gray Tacoma Limited
    Tuff Country 3 inch spacer kit with aal Tuff Counrty 1/4" spacer on LF (for taco lean) Bilstein 5160 rear shocks Bilstein 5100 adj front struts (removed tuff country front spacers) set to 0 lift OME 886 coil springs Front sway bar relocation bracket N-Fab Rock Rails 17x9 -12 Fuel Beast wheels Toyo AT2 285/70/17 tires Led light conversion on all interior lights Morimoto 35w HID kit 5500k OE all weather floor mats OE Tonneau cover OE Door Sill Protectors Bed Mat De badged all factory emblems matte black vinyl tailgate letter and Tacoma emblem on door silver vinyl insert on glove box and door sill protectors OME Carrier Bearing Drop Insain Fab cab mount chop plates Weathtech Rain guards
    On my 16 limited I get a rattle.. its more noticeable with songs that have high bass at medium volume.. it does it also at high volume but blends in a bit more.. the issue with mine is the window switch panel on the driver door when I hear the rattle I can put my hand down on that area and the noise instantly goes away. try that I plan to dynamat when I upgrade the audio to cure the issue.
  12. Jun 3, 2018 at 12:12 PM
    shakerhood
    Southern Ohio
    I used it in my doors when I changed out the speakers, it makes the doors sound and feel more solid.
  13. Jun 3, 2018 at 5:05 PM
    bobrown14
    Bob
    Philadelphia
    Gen 3
    Shaker, where did you put the sound deadening material? I have some but never installed it when I did my speakers. I was kinda sorta pissed when I got in there and found what I found. Had truck to dealer to fix a faulty switch which they said just "came unplugged" which is total bs and they pulled back the vapor barrier and never put it back and broke retaining clips on my trim and not replaced. Trifecta of fuck ups. Done with the dealership.
    shakerhood[QUOTED] likes this.
  14. Jun 3, 2018 at 6:18 PM
    shakerhood
    Southern Ohio
    I reached inside the door cavity and did the outer door skin, I probably could have done more by doing the area under the door panel too.
  15. Jun 3, 2018 at 6:26 PM
    Ricebox
    Ricebox Well-Known Member
    FL
    18' TRD Off-Road 4x4 Prem/Tech
    my 15' had this same issue, dealer told me they couldn't replicate it so didn't know how to fix it. actually just learned to deal with it. very annoying. if you have the panel off id recommend insulating anywhere where it looks like two hard surfaces could touch/rattle with foam tape.
  16. Jun 3, 2018 at 8:21 PM
    badfish_55
    badfish_55 Unknown Member
    OC-->TN
    '17 TRD Sport
    The dealership can never replicate any issues but thank god for TW and people who are willing to put the work in themselves. I reluctantly got the JBL "upgrade" for the extra safety features but the obnoxious high pitched rattles/vibrations drove me insane, especially with any kind of acoustic music. I ended up following some of these guys' tips https://www.tacomaworld.com/threads...d-rattle-and-vibration-noise-resolved.462969/ I got some felt pads that go on furniture legs so they don't scratch the floor (like these https://www.lowes.com/pd/Scotch-2-Pack-4-in-x-6-in-Brown-Strip-Felt-Pad/1000422103) and cut them to size for all the different areas. I padded up both A-pillars, sides of the dash, the mount of the rear-view mirror, and all over the window switch panels which most of the rattles were coming from. This took out 90% of the plastic vibrations and I can finally crank up my music in peace. Hope this helps anyone who is annoyed as I was with the constant rattle
    andrewbrandon19 likes this.
  17. Jun 29, 2018 at 11:38 AM
    justinlj93
    justinlj93 Well-Known Member
    Justin
    2017 MGM Tacoma TRD off road 4x4
    I have rattling in my 17 sounds like its coming from the door as well.
  18. Jun 29, 2018 at 11:54 AM
    Spencer4x42006
    Spencer4x42006 Whoisthatguy
    Spencer
    Bend, OR
    2006 TRD OR
    5100s Wildpeaks Light bar Other shit
    Mine does the same thing, Fairly common when the base is high in certain songs
    tonered likes this.
  19. Jun 29, 2018 at 12:06 PM
    Deacon Blues
    Deacon Blues Well-Known Member
    Colorado
    2017 SR5
    Are you sure it's not the speaker itself bottoming out/distorting?
    Not a ton in the door panel to rattle around, two harnesses and two cables really.
    You should be able to press hard from the outside and isolate the vibration if it's the panel.
  20. Jun 29, 2018 at 12:14 PM
    AltaTacoma
    AltaTacoma Well-Known Member
    2018 BRM Tacoma TRD Off Road
    I don’t recall driving or owning a vehicle that didn’t rattle somewhere with heavy bass. Sound deaden and foam tape! Lots of videos and help online for this as it’s a very general issue across all brands. The GMC Colorado diesel I test drove before pulling the trigger on the Tacoma shook the doors so much with moderate volume/bass that the wing mirror had to be readjusted.
