Tacoma 05-15 L/T August Special !!
Discussion in 'Camburg' started by motoxscott, Aug 18, 2015.
  1. Aug 18, 2015 at 10:25 AM
    motoxscott
    motoxscott [OP] Well-Known Member Vendor
    Scott
    Socal -> Hurricane, UT
    2017 Tundra - 2008 Tacoma
    Camburg, FOX, Method, General Tire, Deaver
    For the month of August when you purchase our long-travel kit and FOX coilovers for the 2005-2015 Tacoma's we'll upgrade you to FOX DSC compression adjusters at no charge. That's a $300 savings! This gives you the ability to adjust both low and high speed compression externally. No other coilover has these options.
    "The Camburg Toyota Tacoma long-travel system ..... We run larger 1.250" uniballs replacing the upper and lower ball joints. This yields more travel and adds more strength than other kits. We also do not run bushings on the lower A-arm pivots we run 1" uniballs. This eliminates flex during suspension travel and braking and provides a precision pivot with zero binding. We also have a custom shock made by FOX with the DSC compression adjuster. Our 4x4 axles are made with 4340 alloy steel and are heat treated and powdercoated. This applies to either a 2wd or 4x4 kit. Call or email us for details. 714 848-8880 or sales@camburg.com"
