Tacoma 2005-2015 Intermediate Steering Shaft Replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wcstory, Apr 1, 2018.
  1. Feb 18, 2023 at 5:14 AM
    #41
    Longfellow
    Longfellow Member
    NH seacoast
    2004 TRD Xtracab Black
    bump for part numbers for the bolts? thanks in advance. 90105-A0086 is what I believe I need
  2. Jan 8, 2024 at 3:38 PM
    #42
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    How did y'all know that the shaft was bad and needed to be replaced?
  3. Sep 23, 2024 at 10:27 AM
    #43
    2009Access4x4
    2009Access4x4 Well-Known Member
    Shane
    2009 Silver 4x4 access cab 6cyl
    Are you turning the truck on to turn the steering wheel to line up the bolts so that you can reach them?
  4. Oct 1, 2024 at 1:48 PM
    #44
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    I found this thread helpful, along with the following threads:
    @EatSleepTacos
    https://www.tacomaworld.com/threads/the-lair.495066/page-1729#post-17351582
    @Nimble9
    https://www.tacomaworld.com/threads/lazy-mans-guide-to-the-replacing-the-intermediate-shaft.671990/
    Job took me about 1.5 hours, with test drive. My steering was crooked after, so I loosened things up again and jumped a spline to correct. Everything was new so adjustment was easy. I loosened both the bottom attachment and two yolk bolts to make the adjustment.
    Nothing was really stuck on. The hardest part was removing the lower attachment, which I hammered out with a pry bar.
    I turn the key to "ON" just to turn the steering shaft.
    Unfortunately this didn't solve the issue I'm experiencing, but at least I have a new shaft with no labor cost. Plus I like learning and touching my truck's private parts.
    Nimble9 and EatSleepTacos like this.
