Tacoma 3.4 Low Idle, on start up and running.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Anthony250, Jun 8, 2013.
  1. Jun 8, 2013 at 8:50 PM
    Anthony250
    Anthony250 [OP] E-Fabber
    Anthony
    San Gabriel Ca
    99 Tacoma LT Prerunner
    TC Kit, Methods Double Standards, Sway Away, King Shocks. Prp Seats, 35's
    Okay so i have a99 V6 Auto , 3.4 mostly stock except for Afe Air filter with the Deck plate mod. And It has been running great , just recently it has been running funny, only on some start ups ,it starts and idles really low 400 rpm, usually my normal was about 550 ish. Some times it will start and idle like normal or sometimes it will start idle for a few seconds and die, when it does that i have to give it some gas and keep it going, once running it runs just fine, sometimes to I stop at a light and it will idle low. I suspected dirty air filter but i just had cleaned it, and dirty MAF sensor so I cleaned that which was very dirty, and it still does it. Any body care to chime in
  2. Jun 8, 2013 at 9:37 PM
    tacomataco2
    tacomataco2 Well-Known Member
    Eastham Mass
    02 Dbl cab Silver
    Bilstein 5100's, eibach coils, u bolt flip, Dakars/d6xl, Ome shackles, Poly sway bar bush, Poly rack bush, voltmeter, led guage lights, magnaflow stainless catback, stainless cats, deckplate mod, afe filter, tundra brakes,PIAA fogs behind grillecraft, color matched grille, soft topper, Projector retrofit, Allpro bumper , Blitzpro light bars, Alpine/ rock fosgate sound system, 35% tint, Some derped stuff
    Iac valve
  3. Jun 8, 2013 at 9:44 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    x2 pull it off and clean it with some throttle body cleaner.
  4. Jun 8, 2013 at 11:12 PM
    Anthony250
    Anthony
    San Gabriel Ca
    Where is it located?
  5. Jun 9, 2013 at 3:30 AM
    ARB1977
    ARB1977 Don't be a dick
    North Texas
    15 Speedway Blue DCSB Prerunner 4.0L
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    It's located under the throttle body.
  6. Jun 9, 2013 at 9:59 AM
    Gooch
    Gooch Well-Known Member
    Orange County CA
    2000 Tacoma SR5 V6 4x4
    X3
    Somebody just posted a PDF on removal and cleaning the IAC and TPS recently. If you can't find it, PM me with your email address and I'll email it to you.
  7. Jun 9, 2013 at 11:57 AM
    RJ MacReady
    RJ MacReady professional trousersnake charmer
    RJ/Mike Hauncho/HeavyHands
    US OUTPOST North 31-Mayday Mayday! We've found som
    00 4Runner 4WD LTD - Cheatin' Bitch Build 2
    Cheatin' bitch build 2: All stock for now... 99' Tacoma 4wd TRD Cheatin' bitch build 1: BG44K additive, motul 5w40(always), deckplate mod, K&N washable air filter, 2.5" flow master(cut thanks to Airdog), king fronts 2.5", all pro standard leaf pk, stainless steel rear ext brakeline, 5125's 10" travel rears, 4-jasper offroad 6" pod LED spot lights, secret compartment for small bottle of wild turkey, cobra CB, Hi-lift jack w/locking bed mount, hi lift curved bumper lift & road base plate, smittybuilt X20 winch, wab fab F&R bumpers w/ hitch receivers, smittybuilt 4in1 recov tool, 10gal mini flamethrower, 11 lbs dynamite sticks, 13 4-hr snowflares, .50Cal full auto mounted machine gun w/ RPG unit & a shitoad of death metal to fuckstart your brain...everything you need for first contact with a shape-shifting alien entity frozen for over 100,000 years reanimated & immitating all life it engulfs.
    THIS...
    are you throwing a CEL???
  8. Jun 19, 2013 at 12:23 PM
    mauibuilt41
    mauibuilt41 Active Member
    Maui
    02 PreRunner Dbll Cab
    I had this same problem and my truck was throwing a CEL. The code said a bad TPS sensor. I will be replacing that soon and let you know how that goes. Did cleaning the IAC valve help?
  9. Jun 19, 2013 at 12:36 PM
    Anthony250
    Anthony
    San Gabriel Ca
    Cleaning the IAC did the trick ,truck runs great agian. I had no CEL.
