Tacoma 4.0L hard to start when warm
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fike, Jul 15, 2017.
  1. Aug 2, 2017 at 2:39 PM
    #181
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
  2. Aug 2, 2017 at 3:04 PM
    #182
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Let us know.
  3. Aug 3, 2017 at 12:17 PM
    #183
    Fike
    Fike [OP] Well-Known Member
    2015 white Tacoma TRD Sport
    Not much so far
    Boogie, have you done anything on your truck recently to try to fix the starting issue with your truck? Havent heard from you in a while. Just trying to get an idea on where we stand
    boogie3478[QUOTED] likes this.
  4. Aug 3, 2017 at 1:36 PM
    #184
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Everything I've done is minor so far and has been covered by you or others on this thread. I will say that mine seems to be doing it less now ... so if before if I would get a long warm start 100% of the time, now it seems like 75-80%. Hey it's progress.
  5. Aug 3, 2017 at 6:17 PM
    #185
    Fike
    Not much so far
    So I ran another experiment to just gain some more information. After letting my truck sit all day at work, I went out alittle early and cranked it. Let it run for about 30 seconds to build up fuel pressure, and then shut it off. I went back in and waited alittle over an hour, went back out and it cranked up perfect.
    This tells me that whatever the issue is, the truck has to get up to operating temp for it to be effected.
  6. Aug 3, 2017 at 6:22 PM
    #186
    boogie3478
    14 TRD Off-Road V6
    All the mods
    And you have changed the ECT sensor right?
  7. Aug 3, 2017 at 6:25 PM
    #187
    Fike
    Not much so far
    I changed it out for a day, and when it didn't fix the problem I returned it. I've got a buddy that can get me some parts through his work and return them if they look unused.
  8. Aug 3, 2017 at 11:24 PM
    #188
    12TRDTacoma
    Rob
    Concordia
    Boosted
    This really sounds like the ECT. Wherever the issue is stemming from it sounds like it is based on a vital sensor which affects start ability. The vital sensors are Cams/ Crank, coolant temperature and air flow at start up.
    You already did your fuel pressure testing right? The one which you told me about to isolate it to the injectors and FPR?
  9. Aug 3, 2017 at 11:45 PM
    #189
    Fike
    Not much so far
    No, I ordered the fuel test port from urd, it should come in the mail tomorrow
    Torspd likes this.
  10. Aug 4, 2017 at 12:06 AM
    #190
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    This still sounds like leaking injectors to me. I know you said you changed them, but it sounds like a classic "flooded" intake condition.
    Have you considered running a bore scope down the intake and watching the injectors for leakage during the "heat soak"?
  11. Aug 4, 2017 at 5:28 AM
    #191
    Fike
    Not much so far
    Funny you mention that, I got a buddies bore scope and was planning on doing that today or tomorrow.
    And I haven't changed injectors, that must've been someone else.
    boogie3478 likes this.
  12. Aug 4, 2017 at 5:31 AM
    #192
    12TRDTacoma
    Rob
    Concordia
    Boosted
    You literally own the car from hell @Fike. Your truck is cursed or something Lol. Run your fuel test tomorrow if you get the time and get back to us on what you found.
  13. Aug 4, 2017 at 5:40 AM
    #193
    boogie3478
    14 TRD Off-Road V6
    All the mods
    My truck was also assembled in Hell. :bananadead:
    12TRDTacoma[QUOTED] likes this.
  14. Aug 4, 2017 at 6:10 AM
    #194
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Side note: The flaming banana is my favorite emoji on this site. :D
  15. Aug 4, 2017 at 6:12 AM
    #195
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Flaming banana or TACO? ;)
  16. Aug 4, 2017 at 6:13 AM
    #196
    Fike
    Not much so far
    At this point I'm hoping it's injectors. At least I will have an answer and can fix it. It just baffles me how it cranks fine when cold
  17. Aug 4, 2017 at 2:23 PM
    #197
    Sae68
    Sae68 Well-Known Member
    JimS
    Stockton, CA
    05 FJ 4x4 PreRunner
    Fuse pump Relay? my integra used have that issue during warner weather.
    Turn out to be solder connection is crack .
  18. Aug 4, 2017 at 2:25 PM
    #198
    Fike
    Not much so far
    So I got the urd fitting and a 1/8 Schrader valve in today. Going to install tomorrow and test fuel pressure.
    Also booked my odb gauges back up. I'm keeping a log of every startup, how it performs, and what exact temperature the engine is when starting. Hopefully it will give us an idea of what's going on.
  19. Aug 4, 2017 at 2:26 PM
    #199
    Fike
    Not much so far
    I swapped out all of the relays associated with the efi system and fuel pump with other relays in the box. Also resistance tested them. So either all of my relays are bad or that isn't it.
  20. Aug 5, 2017 at 10:28 AM
    #200
    Fike
    Not much so far
    So I got the urd fitting on, and have run multiple pressure tests.
    First two tests the engine was cold when started, got fuel pressure around 41 psi. Shut off, had a quick drop to around 35 psi, then over 30 minutes slowly dropped to around 22 psi.
    Then I ran the truck up to operating temp and shut it off.
    Fuel pressure running was 41, dropped to 39 on shutoff, then a slow drop to 22 psi after 30 minutes. I'm currently letting it drop further, going to wait til an hour and recheck pressure.
    The Haynes manual states that as long as the pressure is above 21 psi 5 minutes after shutoff, the system is good. Does this sound correct to everyone?
    Or possibly I am reading it wrong, and it is saying that the system should always maintain above 21 psi even after 5 minutes?
