Tacoma 4.0L hard to start when warm
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fike, Jul 15, 2017.
  1. Aug 29, 2017 at 2:36 PM
    #281
    Fike
    Fike [OP] Well-Known Member
    2015 white Tacoma TRD Sport
    Not much so far
    Just wanted to update, after a week, I still have not experience a long start. I am now convinced I have fixed my issue.
    Now I just have 2 more problems to fix and maybe I can enjoy my truck for a bit
    boogie3478[QUOTED] likes this.
  2. Aug 29, 2017 at 3:12 PM
    #282
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Guess I'll be looking into getting some new injectors. What other issues are you having?
  3. Aug 29, 2017 at 3:27 PM
    #283
    Fike
    Not much so far
    Nothing major, think I have a bad inner tie rod, and the horn isn't working.
    I would get the urd fuel pressure fitting and diagnose it before you buy new injectors. The only problem with the urd fitting is it is hard to access to hook your tester up. But it's cheaper to buy that and figure out the exact problem then just guessing at parts.
  4. Aug 29, 2017 at 7:05 PM
    #284
    igno1tus
    igno1tus Small member
    Lehigh Valley Area , PA
    '07 Tacoma Access Cab TRD Off Road
    A vapor lock problem ? I'm just guessing here
  5. Aug 30, 2017 at 6:23 AM
    #285
    Fike
    Not much so far
    Not sure who you were addressing this to. If you were talking to me, I already found my issue. It was a leaking injector
  6. Nov 25, 2017 at 10:06 AM
    #286
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Update for my similar issue: my truck has miraculously "fixed" itself. I believe I was able to get my ECU to fully reset after disconnecting my battery for an hour or so. My issue slowly went away over the next few weeks after doing that. :fingerscrossed:
  7. Jan 1, 2018 at 7:16 AM
    #287
    Radarninja
    Radarninja Safety 3rd
    Northern California
    06 taco
    Chromed out radiator cap
    Well doods my long start has been resolved. As you may recall I was throwing parts at it.
    A few weeks ago and all at once I changed,
    Both cam pos. Sensors, mass air flow, coolant temp sensor, spark plugs, and pcv valve.
    Haven't had the long start since. Also at 195,000 miles my valves were all in spec. Thanks for everyone's input and help.
    Wakecoach and boogie3478 like this.
  8. Jan 7, 2018 at 2:53 PM
    #288
    Drivesector
    Drivesector Well-Known Member
    TRD sport
    Sometimes it all comes down to the parts shotgun. Glad your problem is solved OP!
  9. Apr 17, 2018 at 6:15 PM
    #289
    stewyeww
    stewyeww Member
    Sory to dig up an old thread but what else did you have to replace when you did the injectors, looking at doing this soon myself and trying to get everything together.
  10. Apr 17, 2018 at 9:26 PM
    #290
    Radarninja
    Northern California
    06 taco
    You have the long start issue I take it...
    You have a 2nd gen?
    You can also replace the Fuel pressure regulator while your at it.
    This all however did not solve my issue.
  11. May 3, 2018 at 9:25 PM
    #291
    stewyeww
    stewyeww Member
    In terms of gaskets and seals, what needs to be replaced once I take it all apart, planning to replace the injectors. Is it the intake plenum gasket? Any others?
