Tacoma 4.0L hard to start when warm
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fike, Jul 15, 2017.
  1. Jul 16, 2017 at 11:59 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    You will probably need the tee adaptor to cross into the line and run the gauge since there is no shrader valve on the fuel rail. I have the master kit that costs big money. You may be able to rent one.
  2. Jul 16, 2017 at 12:28 PM
    Fike
    Fike [OP] Well-Known Member
    2015 white Tacoma TRD Sport
    Not much so far
    Do you have a link to what tee adaptor? And do you just relieve pressure and cut the line, or does it go into the fpr?
  3. Jul 16, 2017 at 12:31 PM
    Bebop
    Nick
    I'll look at my kit tomorrow. It's locked up in my box at work.
  4. Jul 16, 2017 at 1:49 PM
    Fike
    Not much so far
    Thanks, that would help alot
  5. Jul 16, 2017 at 2:46 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    vapor lock would be another possibility
  6. Jul 16, 2017 at 4:05 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Just sub'd!
    boogie3478[QUOTED] likes this.
  7. Jul 16, 2017 at 4:08 PM
    winkel
    Corydon, IN
    Just from a purely trouble shooting stand point, when you first start cranking over, step on the gas a little and see if that makes a difference. I only suggest that because when I changed injectors on my T-100, I ran into the same problem a couple of times. I assume it was air in the fuel rails but the problem finally worked itself out. I'm not saying this will fix the problem, but if it makes a difference, it's another variable to add for discussion.
    Is there a 'check valve' in the fuel system that may be letting pressure bleed back out of the rails?? I may be way off base here, but as long as we're all spit ballin'.......
    boogie3478 and Bebop like this.
  8. Jul 16, 2017 at 4:35 PM
    Bebop
    Nick
    That should be the pressure regulator
  9. Jul 16, 2017 at 4:45 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    :cheers: Thanks!
  10. Jul 16, 2017 at 4:46 PM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    How long did you have to give it some gas like that before the issue went away?
  11. Jul 16, 2017 at 5:36 PM
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    Vapor lock seems very unlikely since the fuel pump is in the tank and pushes the fuel. Vapor lock occurred before the fuel pump as it cannot suck vapor.
  12. Jul 16, 2017 at 5:50 PM
    Lester Lugnut
    I think you're right. I keep forgetting where the Tacoma fuel pump is.
  13. Jul 16, 2017 at 5:50 PM
    winkel
    Corydon, IN
    If I remember correctly, it would pretty much start right up then. My problem finally went away in a couple of weeks but I think we're talking about two different things here.
  14. Jul 17, 2017 at 7:20 AM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    A guy on a different thread that he had this warm starting issue and it turned out to be a bad fuel pump.
  15. Jul 17, 2017 at 8:38 AM
    #35
    Fike
    Not much so far
    Are you going to try to do a fuel pressure test boogie?
  16. Jul 17, 2017 at 8:44 AM
    #36
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Lol there are about 10-15 different things I still need to check to try to figure this issue out.
  17. Jul 17, 2017 at 8:54 AM
    #37
    Fike
    Not much so far
    I know, we need to split up the possible problems and start checking them out 1 by 1. I took a video of it starting and dying a couple times today. I'll try to post it later
  18. Jul 17, 2017 at 8:57 AM
    #38
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Dang yours is dying on you now??
  19. Jul 17, 2017 at 9:15 AM
    #39
    Fike
    Not much so far
    Well, sometimes it will turn over for several seconds and then run fine, and other times it will start up quick and immediately die. It always run fine on the second start up
  20. Jul 17, 2017 at 9:15 AM
    #40
    Fike
    Not much so far
    The more I get into this, the more I realize how poorly maintained this truck was with the previous owner
