Tacoma 4.0L hard to start when warm
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fike, Jul 15, 2017.
  1. Jul 17, 2017 at 9:22 AM
    #41
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    I just hope it's a relatively cheap/easy solution whatever it is.
  2. Jul 17, 2017 at 9:24 AM
    #42
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  3. Jul 17, 2017 at 10:32 AM
    #43
    Fike
    Fike [OP] Well-Known Member
    2015 white Tacoma TRD Sport
    Not much so far
    boogie3478 likes this.
  4. Jul 17, 2017 at 11:06 AM
    #44
    Fike
    Not much so far
    Does anyone know how to remove the vacuum line on the fpr. It's tight back there, and I figured it just slid on, but I pulled pretty hard and it didn't budge. I didn't want to break the line, but I do want to check to make sure it is pulling a vacuum and that there isn't any oil or fuel in it.
  5. Jul 17, 2017 at 12:07 PM
    #45
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Twist, pull.
  6. Jul 17, 2017 at 12:10 PM
    #46
    captn.fat.beard
    captn.fat.beard Well-Known Member
    Anthony
    NJ & Philly PA
    13' DCSB on 33"
    sub'd. curious to see whats up
  7. Jul 17, 2017 at 12:14 PM
    #47
    Fike
    Not much so far
    I just pulled the vacuum hose of the regulator, and could not feel any vacuum at all. I'm going to try to rig up something to manually pull a vacuum on the regulator and see what that does. Should it have any vacuum at idle? I know it increases as you accelerate
  8. Jul 17, 2017 at 12:28 PM
    #48
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    It is setup using a different theory. Not regular vacuum.
  9. Jul 17, 2017 at 12:41 PM
    #49
    Fike
    Not much so far
    Venturi? So is there any way to check it? I know a fuel pressure test, but that wouldn't necessarily isolate the regulator.
    Also, I've been trying to do like someone said earlier and give it some gas when I crank it. That seems to help somewhat. I'll probably end up having to change the fuel pump
  10. Jul 18, 2017 at 11:56 AM
    #50
    Fike
    Not much so far
    Day two, and giving it some gas while cranking seems to help. It still sounds funny when starting, but I haven't had an extended crank since I've tried it. I will keep reporting as I test it out.
  11. Jul 18, 2017 at 11:58 AM
    #51
    boogie3478
    14 TRD Off-Road V6
    All the mods
    How many times have you given it some gas on startup?
  12. Jul 18, 2017 at 12:08 PM
    #52
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    I'm leaning towards a bad pressure regulator
  13. Jul 18, 2017 at 12:11 PM
    #53
    Fike
    Not much so far
    I've tried it 4 times when i feel like it would have normally messed up. It didn't startup perfect, but it was noticably quicker.
    Have you tried it?
  14. Jul 18, 2017 at 12:19 PM
    #54
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Not yet but I will. Thankfully I only really have to start my truck when it's "warm" just several times a week because most of the time I'm cold starting to go to work, truck sits all day, then I'm cold starting back home.
  15. Jul 18, 2017 at 1:23 PM
    #55
    Fike
    Not much so far
    I got ya. Well I usually have to crank mine once or twice a day after my morning commute
    Just went and tried it again just to see, and it cranked up pretty good. Definitely thinking it's a fuel issue. I really wish they had an easier was to pressure test the system
  16. Jul 19, 2017 at 11:03 AM
    #56
    Fike
    Not much so far
    Well, now I'm not so sure it was fuel. I finally got my new PCV valve in (O'Reilly's had to order it) and put it on. My engine cranked up better than it ever has, and it idled around 700 RPM. Before changing it out it idled at 1500 and then dropped closer to 1000 when warmed up.
    Will report back the more I test it.
    captn.fat.beard and boogie3478 like this.
  17. Jul 19, 2017 at 1:30 PM
    #57
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    You sure you didn't just have a vacuum leak?
  18. Jul 19, 2017 at 1:35 PM
    #58
    Fike
    Not much so far
    No, I'm not sure. I think the old pcv was open all the time. It rattles, but upon further research, the rattle is not an accurate test for newer pcvs since the spring could be bad and it would still rattle.
    I'm going to be driving again around 5, so I will see how it starts then, but it would be nice if this fixed my issue.
    Torspd and boogie3478 like this.
  19. Jul 19, 2017 at 1:39 PM
    #59
    boogie3478
    14 TRD Off-Road V6
    All the mods
    :fingerscrossed:
  20. Jul 19, 2017 at 1:45 PM
    #60
    Fike
    Not much so far
    Have you ever changed yours?
