Tacoma 4.0L hard to start when warm
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fike, Jul 15, 2017.
  1. Jul 19, 2017 at 1:48 PM
    #61
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Not yet. Does that need to be changed at a certain mileage (barring any issues before then)?
  2. Jul 19, 2017 at 2:20 PM
    #62
    Fike
    Fike [OP] Well-Known Member
    2015 white Tacoma TRD Sport
    Not much so far
    I don't know. Honestly, I always heard you could pull them, spray some carb cleaner through them, and if you shook them and they rattled they were good. On these new vehicles it appears that's not the case. In my research some people just go ahead and change them every 30k since they are under $10 and easy to access.
    I am amazed at the difference in my idle speed with this change. I'm sure my fuel economy is going to go up. The truck sounded like a jet engine before. I haven't been around enough Tacomas to realize it wasn't supposed to sound like that.
  3. Jul 19, 2017 at 2:31 PM
    #63
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Got any pics or info on where this PCV valve is and how to change it??
  4. Jul 19, 2017 at 2:54 PM
    #64
    Fike
    Not much so far
    https://www.tacomaworld.com/threads/pcv-valve-replacement.234196/
    This thread has all the info. It's driver side, near the firewall. It's got a black vacuum line going into it.
    Just take the vacuum line off, use a deep 19mm socket with a 3 inch extension. Remove old one. Start new one by hand to make sure it doesn't cross thread. Tighten down, but there will be threads still exposed due to the design and torque spec. Took less than 5 minutes since you don't have to remove anything to access it.
    AutoZone does not carry them, actually the manager argued with me that there wasn't a pcv valve on my truck. I pulled up the part number from Napa to show him. Ended up going to O'Reilly's since it was close to home and they had to order one for me.
  5. Jul 19, 2017 at 3:05 PM
    #65
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Sweet thanks! Did you use the same part as the OEM?
  6. Jul 19, 2017 at 3:14 PM
    #66
    Fike
    Not much so far
    They cross referenced the part number at O'Reilly's and I got some generic one for like 6 bucks. They are just as cheap at the dealership, so I will probably go there next time. I'm going to try to replace mine every 20 to 30k
    boogie3478 likes this.
  7. Jul 19, 2017 at 5:48 PM
    #67
    Fike
    Not much so far
    The pcv didn't not fix my issue with starting. Back to the drawing board
  8. Jul 19, 2017 at 5:50 PM
    #68
    boogie3478
    14 TRD Off-Road V6
    All the mods
    You mean this?
    tomwil and doorsidedown like this.
  9. Jul 19, 2017 at 5:51 PM
    #69
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Sorry to hear that man! But at least you helped lower your rpms with that pcv fix.
  10. Jul 19, 2017 at 6:48 PM
    #70
    Fike
    Not much so far
    That's what it feels like. It'd be alot easier if they would've put a damned fuel pressure port on this thing. Between that and no transmission dipstick I'm losing faith in the Japanese...
    But yeah, I am happy it's idling better. Should help my fuel economy. I checked most of the vacuum lines for any leaks, didnt find any. Really thinking it's the fpr, I wish I new somebody locally that had a Tacoma and I'd just swap my for with theirs and see if that fixes it.
    boogie3478[QUOTED] likes this.
  11. Jul 19, 2017 at 8:15 PM
    #71
    Radarninja
    Radarninja Safety 3rd
    Northern California
    06 taco
    Chromed out radiator cap
    I'd don't think the fpr was very expensive and it's super easy to replace however, it did not fix my issue.
    So far with the new fuel Pump relay starts normal every time. I'll let y'all know if it stays that way.
    And..... This morning same long start.
    so that wasn't it, I'll be doing crank sensor and WP today
  12. Jul 20, 2017 at 4:16 AM
    #72
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Where did you buy your fuel pump relay? Denso?
  13. Jul 20, 2017 at 5:09 AM
    #73
    Fike
    Not much so far
    Your truck was having trouble starting when cold though correct?
  14. Jul 20, 2017 at 6:31 AM
    #74
    Radarninja
    Northern California
    06 taco
    @boogie3478 i got it on Amazon. But it's didn't fix it.
    @Fike yes long start when cold.
    Mine extended cranks intermittently when it hasn't been driven. After the initial long start it starts fine. Sometimes after work (been sitting 10 hrs) it starts long again.
  15. Jul 20, 2017 at 6:40 AM
    #75
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Hmm long starts when cold could be a battery/starter/alternator issue. I think Advance Auto Parts tests all 3 of those for free.
  16. Jul 20, 2017 at 7:14 AM
    #76
    Fike
    Not much so far
    So, I'm testing the pump relay today. There is another identical relay so I swapped them. I'll let it sit for a couple of hours and then go see how it starts.
    My one concern with it being fuel related is, if it is losing fuel pressure causing the hard start when warm, it should still have no pressure when cold, so why does it start fine cold?
  17. Jul 20, 2017 at 7:18 AM
    #77
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Yeah it's bizarre ... which is why I think it might be a bad ECT sensor ... but then it "should" throw a code if that were the case.
  18. Jul 20, 2017 at 7:47 AM
    #78
    Fike
    Not much so far
    I'm going to try to test my ect today to see if it's bad.
    Also, I picked up a Haynes manual for th2005 to 2015 Tacoma and it shows a way to do a fuel pressure test at a quick connect fitting without adding any taps or adaptors.
  19. Jul 20, 2017 at 7:55 AM
    #79
    Radarninja
    Northern California
    06 taco
    @boogie3478
    I have read that a bad starter will pull some wierd shit "loading the electrical system" and causing start issues. I just don't think this is my issue
    My battery voltage is good at rest and while cranking. I'll post a video if I can figure out how
  20. Jul 20, 2017 at 8:58 AM
    #80
    Fike
    Not much so far
    First test of my ect is showing 639 ohms at 122 degrees. I'll let it cool down some more and see where we get
    Second reading, 102 degrees and 930 ohms. According to a chart I found online, I am slightly below the standard for both of these temperatures. Maybe that is why I'm having an issue, but not low enough to throw a code?
    I just had a long start, so it wasn't the fuel pump relay...
