Tacoma 4.0L hard to start when warm
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fike, Jul 15, 2017.
  1. Jul 24, 2017 at 7:06 AM
    #141
    Fike
    Fike [OP] Well-Known Member
    2015 white Tacoma TRD Sport
    Not much so far
    12TRDTacoma[QUOTED] likes this.
  2. Jul 24, 2017 at 1:02 PM
    #142
    Fike
    Not much so far
  3. Jul 24, 2017 at 1:44 PM
    #143
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Make sure your tank is low on gas ... should make it easier. ;)
  4. Jul 24, 2017 at 1:55 PM
    #144
    Fike
    Not much so far
    I filled up today, but I've got a 250 miles round trip this weekend so I should run it pretty low
    boogie3478[QUOTED] likes this.
  5. Jul 24, 2017 at 2:04 PM
    #145
    RaleighTaco
    RaleighTaco Well-Known Member
    Jonathon
    Raleigh NC
    '97 Toyota 4runner
  6. Jul 27, 2017 at 12:43 PM
    #146
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Any updates fellas?
  7. Jul 27, 2017 at 1:38 PM
    #147
    Fike
    Not much so far
    My new pump should be in tomorrow. It will probably be Sunday or Monday before I get to install it
  8. Jul 27, 2017 at 1:44 PM
    #148
    boogie3478
    14 TRD Off-Road V6
    All the mods
    :fingerscrossed:
  9. Jul 27, 2017 at 2:01 PM
    #149
    Fike
    Not much so far
    I'll be sure to update you when I get it done. Hopefully it isn't too hard
  10. Jul 31, 2017 at 6:29 AM
    #150
    Fike
    Not much so far
    Well today is the day for fuel pump install, and a couple of other minor maintenance items. I won't be able to get to it until early afternoon, but I will be sure to let y'all know how it goes.
    tomwil, boogie3478 and Torspd like this.
  11. Jul 31, 2017 at 7:26 AM
    #151
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Best of luck!
  12. Jul 31, 2017 at 3:54 PM
    #152
    Drivesector
    Drivesector Well-Known Member
    TRD sport
  13. Jul 31, 2017 at 4:21 PM
    #153
    Fike
    Not much so far
    I'm done with the install. Took longer than planned. The instructions from urd were ok, but did omit a few steps.
    I just drove up to make sure everything was working, went and filled up with gas. Had a good bit of gas leak out of the pump assembly so I need to drop the tank and retighten that.
    I'm letting it sit for a little while and then I'm gonna go crank it up and see if it's cranking better.
  14. Jul 31, 2017 at 4:22 PM
    #154
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Hard part is done.
  15. Jul 31, 2017 at 5:51 PM
    #155
    Fike
    Not much so far
    Well, just let it sit for about and hour and a half. Went out and got the old long start again....
    Fuel pump swap did not help, and now I've got to drop the tank again and retighten the pump assembly to prevent it from leaking again on fill ups.
  16. Jul 31, 2017 at 5:53 PM
    #156
    Fike
    Not much so far
    Fuel pump swap did not fix the problem.
  17. Jul 31, 2017 at 5:56 PM
    #157
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Damn this really sucks.
  18. Jul 31, 2017 at 5:59 PM
    #158
    Fike
    Not much so far
    I know. Don't really know where to look next. I'm pretty pissed at the whole situation
  19. Jul 31, 2017 at 6:01 PM
    #159
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Don't be because you were going to have to do it sooner than later anyways.
    Did you swap out your plugs already by the way?
    Denso is on one side NGK on the other. For some reason that has been known to cause issues also.
    This is the nature of these new generation vehicles. Too many on board electronics and overcomplicated setups over what simplicity can accomplish the same, causes odd problems and hard to track down issues. While this issue is well known of there are other variables which have to be or should be addressed which can cause much of the same symptoms.
  20. Jul 31, 2017 at 6:22 PM
    #160
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Also, while not probable because they are pretty well built on these trucks you might want to take a look at the VVT sensor/ cam sensor assemblies. Whatever you have going on is being produced by a hot saturation issue. Seeing that the entire engine is basically a convection oven during the summer and you are not having no start conditions, rather long starts, cam or vvt sensors are up next. They could be getting too hot and internally failing at extended heat saturation before start up. A lot of other Toyota' have issues ranging all sorts of symptoms with them but since they read camshaft position signals at all times if they are not reading at first that will cause the PCM to search for a known good signal value during cranking.
