Tacoma 6 lug 4x4 BIG BRAKE KIT
Discussion in 'Performance and Tuning' started by socalgasking, Dec 13, 2011.
  1. Dec 17, 2011 at 9:47 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I can easily.
  2. Dec 17, 2011 at 10:33 AM
    elmo7
    elmo7 Easily Replaceable Member
    SC
    07 DC TRD OR 4x4
    I don't have much experience with "big brake" kits, especially in the truck world, (those who tow big can speak to serious braking requirements) but I have spent some time on the track w/different brake setups in cars. The needs are probably worlds apart, but in the end, you are still looking for stopping power.
    Track conditions will glaze up a set of OE pads, so of course you go with a setup that can handle higher temps. That means they suck for the street as they are often running too cool to grab. But a pad upgrade can give better performance w/o fading as fast, yet still stop you on a cold day.
    For rotors, I prefer as much metal as possible to soak up as much heat as possible. The difference might not be much, but I always skipped out on cross drilled and slotted combos. People will argue to the death on virtues of any rotor combination. So of course a larger rotor will likely perform better.
    I was definitely a fan of braided SS lines though. Seemed to help keep the pedal firm when the fluid gets hot. But I'll say I never saw any tests of the factory lines bulging out at higher temps. Also seems to offer more durability.
    I did see people assume that a big brake kit on the front would work better than factory. But sometimes it seemed to just futz up the balance of the braking system. Just make sure you know what you're getting into. Otherwise you could end up replacing the master cylinder, proportioning valves, etc., just to get a properly working setup going again.
    It's one thing to have some fancy intake rob you of some horsepower, but totally another to have a brake setup put you 20 ft further down the road. Some sellers just want to sell you that shiny red caliper and drilled rotor because it looks good, so look for tests and reviews, IMO.
  3. Aug 27, 2013 at 5:40 PM
    DOUBLLD
    DOUBLLD Well-Known Member
    Daniel
    Bluemont, VA
    05 Tacoma LS Swap Twin Turbo
    Alot
    I need some big brakes
  4. Aug 28, 2013 at 4:27 PM
    jdmdcfan
    jdmdcfan Well-Known Member
    east WA
    dcsb
    Read this post above. From my experience tracking my s2000, type R and EVO ix you don't need big brake kits for what we plan on doing with our tacos. Only benefit would probably be for towing. More rotor to fight off brake fade.
  5. Aug 28, 2013 at 4:29 PM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    I have heard of tundra brakes on 1st gen tacomas. Im not sure if they have anything compatible with 2nd gens
  6. Aug 28, 2013 at 4:33 PM
    jdmdcfan
    east WA
    dcsb
    Maybe someone has done a rear disc swap on our 2nd gen.
  7. Aug 28, 2013 at 5:02 PM
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    I was thinkin about doin it takin the axle/ hub so I can have rear disc. Also some of us do need big brakes tor def does so do I. Ill have about 575 whp an tor will be well over that so if we are gonna go fast we need 2 stop fast just sayin
  8. Aug 29, 2013 at 4:42 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Www.tundraracing.com They have a rear disk conversion which uses the 4Runner rear brakes.
    Just be thankful that the PreRunners/4x4 's have 4 pot front calipers from the factory, instead of the 1 pot that the XR comes with.
    I love how well my brakes handled at MSR Houston. Didn't have the HP in the straights, but definitely had superb braking power for the corners. I was able to late brake my ass off with these 6 pistons. Scared quite a few times too, while I was gdtting used to it.
  9. Aug 29, 2013 at 5:11 AM
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    That's insane 6piston I'd like 2 see the 8piston ones hahaha
  10. Aug 29, 2013 at 5:25 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    They were only sometthing like $900 more. :cool:
    If I do a rear disk conversion, I will be adding in an AP Racing adjustable proportioning valve. If.
  11. Aug 29, 2013 at 7:37 AM
    DOUBLLD
    Daniel
    Bluemont, VA
    Alot
    I've thought of doin it a couple times. I would do it myself instead of gettin there conversion kit.
  12. Mar 10, 2015 at 10:23 AM
    Aspringfield
    Aspringfield New Member
    '12 Tacoma 2.7
    3"lift 33"km2
    Is there a conversion kit to switch the rear drums to disc brakes
  13. Mar 10, 2015 at 10:57 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I posted the link above.
  14. Jun 10, 2016 at 10:47 PM
    Bray1197
    Bray1197 Well-Known Member
    Bobby
    Myrtle Beach, SC
    2017 Tacoma Trd Pro
    A lot of stuff, just ask and I'd be happy to tell you. Or we could wheeling/camping
    Question regarding these brakes.. I've gone to the site where you said you purchased your Rotora 6 piston bbk brake kit, but all they have is stop tech? I currently trying to build a new Tacoma and finding a good big brake kit is becoming a task if I keep the wheels under 18".
  15. Jun 11, 2016 at 12:21 PM
    #35
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Stop Tech sells plenty that will fit. The ST40 caliper.
    Tundra Racing no longer carries Rotora.
  16. Jun 13, 2016 at 9:49 AM
    #36
    Revelations
    Revelations Well-Known Member
    2014 MGM DCSB
    StopTechs are insanely good brakes. You can't go wrong with them.
  17. Jun 28, 2016 at 5:58 PM
    #37
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    I run stock calipers with carbotech pads, ss lines, higher temp rated brake fluid. It handles racing conditions very well, for most this is all they would ever need.
  18. Dec 22, 2016 at 12:43 AM
    #38
    planesane
    planesane Well-Known Member
    2015 white Tacoma limited 4x4
    6 inch rough country lift kit, Kings shocks front and rear, Deaver leaf pack, 4xinnovations shackle flip, 6 inch shackle, front, rear bumpers , rock sliders, warn winch, 35 inch tires
    still stoptech and rotora for big brake kits?
  19. Jan 1, 2017 at 5:30 PM
    #39
    trabo
    trabo Well-Known Member
    Los Angeles
    2017 Silver DCLB OR
    I won't say anything about the tacoma since I am a new owner but I had braking issues with my Honda pilot while carrying a load so I did a bunch of research on brakes.
    First of all, I highly recommend Engineering Explained on YouTube.
    https://youtu.be/78wbht355R8
    https://youtu.be/sOzd5o8B7eA
    I'd venture an educated guess that a BBK would make a big difference but you're also making a big expenditure.
    On my pilot I went with high carbon rotors (not drilled or slotted) and a high quality performance semi-metallic pad and my brakes improved greatly.
    Getting quality parts makes a big difference, I bet a BBK is overkill for a lot of you. Unless you're towing a big boat (yes, brakes matter most for weight) you probably don't need some over-the-top kit.
    Biscuits likes this.
  20. Jan 5, 2017 at 8:43 AM
    #40
    planesane
    Much appreciated. I will definitely be making some changes.
    Masshole_And_His_Taco likes this.
