Tacoma Brakes - Swaps and Tech
Discussion in 'Technical Chat' started by Low Range Off-Road, Jan 4, 2017.
  1. Sep 3, 2018 at 9:54 PM
    #81
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    It’s not steering but the master cylinder. I can’t do that one since I have an electric hydro boot vs vacuum hydro boost which that one is. I need to call them And see as that’s one of my hesitations
    TacoZim[QUOTED] likes this.
  2. Nov 12, 2018 at 3:42 PM
    #82
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Someone please clarify if I need new dust shields for the WA caliper/rotor swap.
  3. Nov 12, 2018 at 3:45 PM
    #83
    TacoZim
    TacoZim Well-Known Member
    Bay Area, CA
    2008 DCLB
    Unless you feel like hacking up your current one, yes you do.
  4. Nov 12, 2018 at 3:55 PM
    #84
    Chuy
    Lakeside, CA
    Silver Taco
    @TacoZim
    Thanks. I'm not averse to some hacking. I presume the outside edge needs to be flattened out? Or is it the caliper opening? or ...
    TacoZim likes this.
  5. Nov 12, 2018 at 4:05 PM
    #85
    TacoZim
    Bay Area, CA
    2008 DCLB
    i'm not quite sure, I just bought the new dust shields. I'd imagine you'd have to keep putting the rotor and caliper on and marking what needs to be cut and repeating til it fits.
  6. Nov 12, 2018 at 4:16 PM
    #86
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
    Just install and SEND IT!
    They will eventually self clearance :anonymous:
    KeezfB, buyobuyo and TireFire like this.
  7. Nov 12, 2018 at 8:55 PM
    #87
    nudavinci64
    Robert
    What folks said. Stock will not work without cutting. If you get the 4Runner dust shields they are the match for the setup. Also had a buddies use them for a
    setup which doesn’t come with any.
    The write up I did has all the info.
    https://www.tacomaworld.com/threads...ade-for-2nd-gen-tacomas.504234/#post-15751686
  8. Nov 15, 2018 at 12:12 AM
    #88
    Chuy
    Lakeside, CA
    Silver Taco
    I wonder if the dust shields from the WH calipers fit with the WA calipers. The WH shields 47781-60120/47782-60120 run $63 ea, compared to $290 for the WA shields, 46504-60091/46503-60131. Rotors are same diameter for both calipers; the fitting has got to be close.
    Also, anyone know about Callahan Brake Parts? Their WA reman calipers run $116 for a pair and no core. They don't have a website, that I can find, but they sell on eBay and Amazon.
    https://smile.amazon.com/Callahan-C...refinements=p_89:Centric|Callahan+Brake+Parts
    #88
  9. Nov 15, 2018 at 12:50 AM
    #89
    nudavinci64
    Robert
    These are the ones I am running and were for the 4runner which is the WA and are around $50-$60 each as you noted. Parts list is noted i the link above I posted.
    #47781-60140
    #47782-60140
    The other setup 46504-60091 you noted is for the rear not the front.
    #89
  10. Nov 15, 2018 at 1:00 AM
    #90
    Chuy
    Lakeside, CA
    Silver Taco
    Good catch. I picked the 1st 2 I saw on the Elmore Toyota website. However, each of the 4 shields run the same price. The 47781-60140/47782-60140 are now down to $52 - duly noted, thanks.
    nudavinci64[QUOTED] likes this.
  11. Nov 15, 2018 at 1:14 AM
    #91
    nudavinci64
    Robert
    yah saw that. Great price. They fit perfect in the swap.
  12. Nov 15, 2018 at 10:30 PM
    #92
    Boomkanani
    Boomkanani Well-Known Member
    Goldsboro, NC
    2009 TRD OffRoad DCSB - 6 Speed
    Some stuffz
    Did Low Range ever make a kit for this? Didn’t see anything on their website.
  13. Nov 15, 2018 at 10:32 PM
    #93
    nudavinci64
    Robert
    Does not seem like it. I got the parts from them did the write up but never heard back from the guy I was working with. He may have left the company and it never materialized. Aside from that its pretty easy to source all the parts. There are not special pieces to be fab'd up. All bolt on. New calipers, rotors and backing plates.
    Boomkanani[QUOTED] likes this.
  14. Apr 1, 2019 at 8:24 AM
    #94
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    I dunno if LowRange is still an active member and can update one of the earliest posts...
    But I run 14WA calipers and GX470 Rotors on my 1st gen, which requires no additional modifications other than the dust shield.
    I also run a 2mm pad shim on the inboard pad so that the Pistons stick out the same amount inboard/outboard... which isn't necessary, just for piece of mind about popping pistons out as the pads wear.
    I did try 14WA calipers with the appropriate rotor, but this does not work without modifying the Calipers in a not-so-ideal manner, and I would not recommend that setup.
  15. Apr 13, 2019 at 12:36 AM
    #95
    jruiz555
    jruiz555 Well-Known Member
    I am also running stop tech, and no issues. they perform great. have them on all my daily drivers. even my shitty daily drivers.
  16. Jun 8, 2019 at 1:18 AM
    #96
    nudavinci64
    Robert
    What was the issue with the 14WA caliper and appropriate rotor. I was under the impression that the newer 4runner and GX use the same rotor.
  17. Jun 8, 2019 at 2:14 AM
    #97
    Chuy
    Lakeside, CA
    Silver Taco
    I believe the 14WA calipers do not fit well on 16" OEM wheels.
    Toki likes this.
  18. Jun 8, 2019 at 4:59 PM
    #98
    nudavinci64
    Robert
    ah that makes sense, that combo is meant for 17" wheels not 16".
  19. Jun 10, 2019 at 5:14 AM
    #99
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    The 5th gen 4runner and GX460 have the same caliper/rotor (14WA) the GX470 has the same diameter rotor, but the rotor thickness is ~4-5mm less than the rotor used with the 14WA caliper.
    1st gen's and 2nd gens have a few mm difference between the hub surface and the Caliper mounting surface, and it is just enough to prevent a person from properly installing a full set of brand new 14WA stuffs on a 1st gen truck.
    I'm running 17" wheels.
  20. Jun 10, 2019 at 6:18 AM
    #100
    buckmaster243
    buckmaster243 I don’t know what to do with my hands
    Buck
    Washington
    2013 DCLB, 2023 4runner
    Anyone know how many miles the stock rotors are good for? I've got 77k on my truck and the rotors are starting to warp. Is it worth it to get them turned or just buy new? What's the stoptech kit costing everyone?
