tacoma dies in about 3 ft of water
Discussion in '1st Gen. Tacomas (1995-2004)' started by the taco man, Nov 11, 2011.
  1. Nov 11, 2011 at 6:47 PM
    the taco man
    the taco man [OP] Member
    Anthony
    mooresburg tn
    98 taco 3 in body lift on 33s
    3 in body lift 33s on Mickey Thompson classic 2 wheels Norma exhaust
    My taco dies in about three feet of water pull it out and it will start right up no water in air box and nothing getting wet that should make it die any ideas
  2. Nov 11, 2011 at 6:52 PM
    Unknown
    Unknown He who angers you conquers you
    Brian
    Los Angeles
    Unknown
    Unknown
    derp thread?
  3. Nov 11, 2011 at 6:52 PM
    davestaco
    davestaco TW's number one gear whore
    David
    Schofield Barracks
    00' tacoma xtra cab trd v6 4x4
    I bet its the water....
  4. Nov 11, 2011 at 6:53 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    Alternator probably got wet.
  5. Nov 11, 2011 at 6:54 PM
    dayNnite4
    dayNnite4 We can't stop here, this is bat country.
    Nick
    Southern NH
    '11 4x4 5-speed AC
    i have to disagree i would say its excessive moisture
  6. Nov 11, 2011 at 6:55 PM
    davestaco
    David
    Schofield Barracks
    SHIT! why didnt I think of that?
  7. Nov 11, 2011 at 6:58 PM
    the taco man
    Anthony
    mooresburg tn
    The alt shouldn't make it die unless the battery is completely dead so I don't think its the alt I've got a buddy who has the same problem and we can not figure it out
  8. Nov 11, 2011 at 7:00 PM
    davestaco
    David
    Schofield Barracks
    if you drown the alt it can kill the truck
  9. Nov 11, 2011 at 7:01 PM
    Tacomanator
    Clam Slammer
    Southern Cali
    Water + Alt = No bueno
  10. Nov 11, 2011 at 7:01 PM
    davestaco
    David
    Schofield Barracks
    this^ it also kills the life of the alt with it getting so dirty.....why didnt you get a boat?
  11. Nov 11, 2011 at 7:08 PM
    the taco man
    Anthony
    mooresburg tn
    Ok maybe its not quit 3 ft maybe like 2 feet or so if it was the alt it would die when spray it with a water hose
  12. Nov 11, 2011 at 7:11 PM
    elytravis
    elytravis Well-Known Member
    Travis
    Always changing...but there is no place like home.
    2012 Nautical Blue DCLB TRD Sport
    Black tube steps, Skid plate, Bilstein 6112's front and 5160's rear, Bakflip F1 folding cover, EGR raingaurds, All weather floor mats, AFE pro dry filter, BFG 265 70 R 17 KO2's.
    This happened to me with a jeep I used to have. The plug wires were old and arcing once they got wet. The jeep stopped running when all the spark was arcing over the engine. After a few minutes to dry, it started up inside the massive mud hole I was in and pulled right out. Swapped the wires and tackled the mup puddle again and it didn't even hesitate as it pulled all the way through...could be the same problem.
  13. Nov 11, 2011 at 7:13 PM
    davestaco
    David
    Schofield Barracks
    submerged and sprayed are way different
    this happened to both my tacoma and my jeep. would be a very good place to start looking
  14. Nov 11, 2011 at 7:14 PM
    the taco man
    Anthony
    mooresburg tn
    It has fresh tune up plugs wires
  15. Nov 11, 2011 at 7:16 PM
    davestaco
    David
    Schofield Barracks
    when a engine dies of wont start there are 3 possible reasons why. Air, Fuel, and Spark.
  16. Nov 11, 2011 at 7:22 PM
    the taco man
    Anthony
    mooresburg tn
    It will start and run great once you get it out of the water I don't have to give it time to dry or anything I am a mechanic at a local dealership and I have talk to a bunch of different people about this and we can not figure it out so I thought I would give this a shot
  17. Nov 11, 2011 at 7:23 PM
    98tacoma27
    Ben
    Not Beech Creek
    Not in a first gen. ;)
  18. Nov 11, 2011 at 7:23 PM
    davestaco
    David
    Schofield Barracks
    that is pretty odd....mabey some others will chime in that have had some similar issues
  19. Nov 11, 2011 at 7:24 PM
    Ivan
    Ivan Well-Known Member
    Ivan
    Western Mass
    06 Tacoma, 4x4 + SR5
    genius!!
  20. Nov 11, 2011 at 7:27 PM
    98tacoma27
    Ben
    Not Beech Creek
    Pittim killed his in a puddle.
