Tacoma Diesel Swap (VW or otherwise)?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Vrbas, Apr 13, 2011.
  1. Apr 13, 2011 at 8:55 PM
    Vrbas
    Vrbas [OP] Well-Known Member
    2013 4x4 DCSB 6speed
    So I've seen a few threads talking about swapping diesel motors into a tacoma and was curious about it's feasibility. My friend got a VW Jetta last year with whatever diesels they have in there and i was wondering if those could be tailored to bolt up to a new Tacoma? Or any other diesel that would take kindly to a new Tacoma.
    Don't plan on doing anything soon, just feeling it out to see what is out there. Thanks in advance guys.
  2. Apr 13, 2011 at 8:59 PM
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
  3. Apr 14, 2011 at 6:53 AM
    IsmellBacon
    IsmellBacon Well-Known Member
    Denver, Colorado
    TRD offroad double cab
    None yet, need to finish the HEEP first
    The VW diesel was designed for a vehicle that weighs 1/2 as much as the Tacoma. Look at the 4 cylinder cummins, Isuzu's or Mercedes. WWW.4btswaps.com has tons of information on diesel swaps. Good luck and keep us posted.
    Bacon
    because_wumbo-truck and Camel51 like this.
  4. Apr 14, 2011 at 5:03 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    I own a VW diesel it's great but it does not have much HP but it does have twice the torque of a 4 cyl gas. I don't think you would be pleased with a 1.9 but a 2.5-3 liter turbo engine would do it I would kill for a V6 turbo TDI diesel in my Tacoma!
  5. Apr 14, 2011 at 5:51 PM
    t_e
    t_e Well-Known Member
    Erik
    miami,fl
    Speaking of vw and diesels, I was next to a VW Amarok with a tdi engine driving around here the other day with a Michigan manufacturer tag... should be giving all mid-size trucks a run for their money.
  6. Apr 14, 2011 at 7:28 PM
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    This guy swapped a freightliner diesel from a sprinter van into a first gen. If you can fit one in a first gen should be no problem in a 2nd
    BuelltonTacoma likes this.
  7. Apr 18, 2011 at 10:05 AM
    Vrbas
    Dang ^^^^ good find!
    I'm wondering if it would even be worth looking into. I'm trying to determine if the money and labor is worth the extra gas mileage i would get out of it. I'm already averaging about 24 mixed which isn't bad at all... but if it could drive me up to the 30s it may be worth my time.
  8. Apr 18, 2011 at 10:15 AM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    Easy enough to figure out.
    In the above example, using his best possible mileage, his mileage before was 26 mpg highway and went up to 30 mpg. The further you drive, the better the results.
    If he travelled 12,000 miles in a year, that means he would use 461 gallons of gasoline @26mpg and 400 gallons of diesel at 30mpg.
    If he was paying $5/gallon, that works out to about $2305/year in gas at 26mpg and $2000/yr. So best case, would be about $300 in savings every year based on $5/gallon. At $4/gallon, that drops to $244 dollars in savings. The savings would also drop due the price differential between regular gas and diesel (about $0.30/gallon extra for diesel)
  9. Apr 18, 2011 at 10:32 AM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    I don't think it would be cost effective to do the swap unless you got all the parts super cheap or free.I would have to almost double my mileage to make it worth it.it's just like all the people who buy hybrids. How long would you have to keep the car to make it worth it to pay extra for the hybrid. If you took an old wrangler or samurai and converted it to veggie oil it would be worth it as a neat cheap project.
    Extreme 4x4 did a samurai with veggie oil.simply install and you could get the waste oil from any dinner or deli
  10. Apr 18, 2011 at 11:02 AM
    kirkofwimbo
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    I plan on swapping to diesel when the motor in my truck eventually dies. May be a while, but that just gives me time to save. I plan on doing a kind-of ground up rebuild at that point, reinforcing the frame for the extra weight, possible SAS(while maintaining a "stockish" ride height), replacing worn out parts such as seats etc. I plan on keeping my Taco for a long time!!:D
    texvet61 likes this.
  11. Apr 24, 2011 at 12:07 AM
    Vrbas
    I'm with you on that. My puppy will be run into the ground. At that point I might consider a diesel swap or who knows, by then Toyota may have a diesel option (i got a 2011 Tacoma so they have plenty of time to figure that out before my sucker dies).
  12. Apr 24, 2011 at 8:44 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    Totally agree...
    But if you do have the parts...the time...the skills and the tools. It would be a super neat project!
  13. Apr 24, 2011 at 10:20 AM
    BCTacoma
    BCTacoma Well-Known Member
    Port Hardy, BC
    06 SR5 Tacoma
    Toytec ULK, OME Dakars, Bilstein Shocks, Extended Brake Lines, 285/75/16 Duratracs, Pro Comp Steel wheels, Relentless Fab Front Bumper/Sliders
    what about these guys. not cheap but looks like you get what you want, turn key.
    www.dieseltoyz.com
    Zenphx likes this.
  14. Apr 11, 2012 at 8:16 AM
    jprovence
    jprovence Well-Known Member
    Joshua
    Albany
    11' Tacoma TRD
    Stock
    Pretty sure these trucks as they sit, will last longer then we have fuel for. Fuel going to be like 10-15 bucks a gallon someday.The whole veggie thing won't last forever as more and more people catch on. I had a buddy doing it to a Chevy LUV though college, and he was always having to ensure his "source" was secure as more people were looking for oil as well.
  15. Apr 11, 2012 at 12:02 PM
    TacoDaTugBoat
    TacoDaTugBoat Well-Known Member
    Goshen, Ct
    13 DCLB TRD Sport
    If I had funny money, I would def do this!
  16. Apr 11, 2012 at 1:27 PM
    squashroll
    squashroll taco tuesday
    NorthWest
    sold '90, waiting for 3rd gen
    Are you serious!? I wonder if it was some car magazine doing a test drive for an article?
  17. Apr 11, 2012 at 1:54 PM
    squashroll
    NorthWest
    If you want to see some cool stuff visit Toyota's websites for other countries. the power plants available in the Hilux are sick--
    imagine what your Fuelly # would be with the 2KD-FTV VNT 2.5L diesel.
    Toyota must think folks like [a certain diesel hater in this thread, who has almost twenty-nine thousand posts] accurately represent the general American demographic.
  18. Apr 11, 2012 at 2:14 PM
    squashroll
    NorthWest
    Agree and agree. why can't we get any good diesels around here???
  19. Apr 11, 2012 at 4:09 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    I don't see a Jetta engine swap being possible since those cars are front wheel drive and sit sideways in the engine compartment like all FWD's do, but a truck diesel motor could be done! It would be cool to get a Jetta motor to work though, they can get 50mpg, but in a Tacoma would probably only get 35.
  20. Apr 11, 2012 at 5:12 PM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    tdiclub.com dozens of TDI swaps into Tacoma's. The ALH TDI engine with a few mods will do 250HP. Any diesel of the same displacement as a gas motor will do about 30% better on fuel.
