Tacoma differential fluid change thoughts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Thatonetacodude, May 7, 2023.
  1. May 11, 2023 at 3:50 PM
    Williston
    Williston Unknown Member
    2014 Tacoma 040 SR5 4x4 DC SB V6 AT5 Tow Pkg Entune+ Mostly stock with a couple of non-OEM nods.M mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. (winter) OEM All-Weather floor mats (summer).
    Thank you! I appreciate the quick response. I really didn't believe the diff shared it's 75W-90 gear oil supply with a common passage to the actuator side, but didn't want to assume so thought I'd ask here. Since it's a sliding fork and collar on the actuator side, it makes sense that it's grease that is specified for lubrication. It's fairly obvious the seal and bolts holding everything on mine have never been disturbed. I did my due-diligence searching for something about this label or at least an explanation and found nothing really: So I'm figuring it's one of those "for life" specs. A least for me, I look at it and I know I'm not going to go exploring unless it's leaking.
