Tacoma doesn't move when put in drive
Discussion in '1st Gen. Tacomas (1995-2004)' started by dallas01tacoma, Feb 4, 2010.
  1. Feb 4, 2010 at 9:08 PM
    dallas01tacoma
    dallas01tacoma [OP] Member
    Forney, TX
    01 Tacoma Prerunner 4 door TRS package
    OK, let me be more specific. The truck is an 01 Tacoma V6 auto. Sometimes, not everytime, maybe 1 out of every 20 times I drive it or less, I put it in drive and it seems like nothing happens. I hit the gas and it just kind of barely moves. When it happens I have put it into the Low gear and it goes fine, throw it into second and then drive, and it drives normal. But like I said it doesn't happen very often. Not sure if there is some type of tranny fluid issue, pressure issue, or maybe even some kind of issue with the shifter. Tranny fluid is good. Anyone heard of this, and can tell me what it might be.
  2. Feb 4, 2010 at 9:31 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    is the truck completely stock?
    no suspension or wheel mods?
  3. Feb 4, 2010 at 9:33 PM
    dallas01tacoma
    Forney, TX
    Stock as it gets. I guess I should mention it has about 140k on it.
  4. Feb 4, 2010 at 10:29 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    It doesnt sputter or anything? It just wont go?
  5. Feb 5, 2010 at 8:21 AM
    dallas01tacoma
    Forney, TX
    Correct, no sputtering. Just kind of rolls along and then sometimes starts to kick in while still in drive. Normally I will throw into Low, then upshift into 2 and then drive. But occassional it kicks in on its own. Like I said it doesn't do it very often so I don't get it.
  6. Feb 5, 2010 at 2:03 PM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    15 DCSB SR5 MGM
    What do you mean by kick in?
  7. Feb 5, 2010 at 2:30 PM
    dallas01tacoma
    Forney, TX
    Sometimes if I keep it in drive it eventually starts to go. I normally don't wait. I do the manual shifting and everything is fine.
  8. Feb 5, 2010 at 3:00 PM
    tmt411
    tmt411 Active Member
    01 4X4 TRD
    K&N Filter system
    Sounds like an actuator on the tranny or some type of computer failer or maybe a linkage problem, Have you hooked up a code reader to yet?
  9. Feb 5, 2010 at 3:03 PM
    dallas01tacoma
    Forney, TX
    I haven't hooked up a code reader. Didn't know if that would even register on one, I didn't honestly think of a computer failing. I really don't think it's the tranny itself just for the simple fact that it drives fine when put into the low gear.
  10. Feb 5, 2010 at 3:17 PM
    tmt411
    01 4X4 TRD
    K&N Filter system
    Yeh its possible i had a problem with my 4 wheel drive doing kind of the same thing a few years back it was the actuator ( it was a $500 repair). Try some local parts place like Napa or Car quest usually they will let you check it for free.
    Good luck
  11. Feb 5, 2010 at 3:38 PM
    98tacoma27
    Ben
    Not Beech Creek
    The No.2 one-way clutch is going out
  12. Feb 5, 2010 at 11:10 PM
    dallas01tacoma
    Forney, TX
    Can you explain a little bit further.
  13. Feb 6, 2010 at 6:59 AM
    98tacoma27
    Ben
    Not Beech Creek
    It's an internal component of the tranny.
  14. Feb 6, 2010 at 7:22 AM
    JeffRock
    JeffRock Well-Known Member
    Capital region, NY
    09 Tacoma accesscab 4x4 SR5 2.7L
    Toyota all weather floor mats. Mag light that clunks around in the jack compartment. Dog hair. Dog drool on the windows.
    Is it possible the shifter cable could be fraying?
  15. Feb 6, 2010 at 7:49 AM
    98tacoma27
    Ben
    Not Beech Creek
    Do you mean the throttle cable?
  16. Feb 6, 2010 at 9:39 AM
    dallas01tacoma
    Forney, TX
    That would make sense if it didn't move in d, and 2 positions. But it just doesn't move in D. L and 2 work fine. But then again, if one isn't working, then maybe it is the no.2 one way clutch. Good info on the links.
