Tacoma dual case "taco box" question
Discussion in 'Solid Axle Suspension' started by v5ensx, Sep 23, 2018.
  1. Sep 23, 2018 at 2:29 PM
    v5ensx
    v5ensx [OP] CARB legal is not CALI legal
    This might not be the appropriate section but i think it fit better here then in the 1 gen built section cause most solid axle are dual case....
    I want to add a dual case (4.7 taco box) in front of my chain driven case on my 2001 tacoma 3.4 4x4 automatic with ADD tcase. I will be swapping the ADD case out with a j pattern tcase from a earlier year tacoma. Im in the process of doing a manual hub conversion as well.
    My question is: do anyone know if i have to swap the input shaft from my ADD case over to the J pattern tcase? Or will the J pattern case be compatible?
    Thanks for any help and advice
  2. Sep 24, 2018 at 5:10 AM
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    Input is the same on both. 23 spline on the 3.4 and 26 spline on the 2.7
    ToyRyd04 likes this.
  3. Sep 24, 2018 at 11:45 AM
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    J shift 3.4 v6 and ADD push button shift 3.4 v6 use the same input, 3.4 V6 use 23 spline input.
    J shift 2.7 I4 and ADD push button shift 2.7 I4 use the same input, 2.7 I4 use 26 spline input.
    Also check here for more info, one of the good technical threads left without too much bs.
    https://www.tacomaworld.com/threads/official-crawlbox-bs-thread.422186/:turtleride:
    villlein likes this.
  4. Sep 24, 2018 at 2:21 PM
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    Why are you swapping inputs?
  5. Sep 24, 2018 at 3:01 PM
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    Just go on car-part and get a v6 j-shift case or just keep your electronically shifting case. V6 cases are all over the place...I think I literally threw one away a couple of years ago.
  6. Sep 26, 2018 at 9:57 AM
    Crawler Brennan
    Crawler Brennan Well-Known Member
    1999 Tacoma lifted with dual case gears and lockers larger tires
    2wd to 4wd, 4.7 Taco box, 3 inch lift with upper A arm and coilovers, ARB rear Spartan front 4.88 R&P, MC bumpers front + rear and sliders, 35 12.5 tires with walker evans race bead lock wheels, on board air system, lots of cutting in fenders and fire wall.
    yes and no, 2.7 has different spline depending on auto vs manual
    v6 is 23
    4cyl 5speed is 26 and auto is 23
  7. Sep 26, 2018 at 11:20 AM
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    I forget the 3/2RZ were available with auto's...It's a very forgettable a combo...
  8. Sep 26, 2018 at 4:47 PM
    ToyRyd04
    Greg
    Perryville, MD
    '04 PreRunner
    While your in there, might as well mod the shift rails for twin sticks....
    malburg114 likes this.
  9. Sep 4, 2019 at 6:24 PM
    Jimmynolife
    Jimmynolife Actually has a life
    Jimmy
    Bend, OR
    3 linked 2002 Tacoma
    If you have the push button and do the grey wire mod, with a 4.7 tacobox you get
    2hi
    2lo
    2 lo in 4.7
    2 double lo
    4hi
    4lo
    4 lo in 4.7
    4 double lo
    No need for twin sticks
    Ask me how I know...
  10. Sep 7, 2019 at 10:03 AM
    v5ensx
    Grey wire mod? Correct me if I'm wrong but isn't that for the elocker? What does it do for the tcase?
  11. Sep 8, 2019 at 5:11 PM
    Jimmynolife
    Jimmy
    Bend, OR
    It allows you to use your elocker in 2wd, and somehow it made it so I could have 2 wheel drive low
