Tacoma Dyno Results
Discussion in 'Performance and Tuning' started by KingKoda, Jan 21, 2014.
  1. Mar 21, 2014 at 6:08 AM
    KingKoda
    KingKoda [OP] Never Satisfied
    Palmetto
    '12 TRD.S DCSB 4x4
    Boosted TRD/URD All Terrain Sleeper w/ Sockmonkey Decals Worth +666HP
    Justus; yes slushbox, all the way to redline. We did pulls in 2nd and 3rd gear. I am fairly certain this was 2nd gear pulls on the printouts.
    To Vassily's point; conservative in that if the bolt-ons produced the max HP they stated could be gained it would should be something like..
    AFE Intake; 5-10HP Catback; 5HP 2.85 Pulley; 10-25HP; URD YPipe; 5HP which on paper should be a 40+ HP bump over 305. But in the real world that's not the case and didn't see those numbers and the atmospheric conditions were good even though I did not officially record them. But i get what you're saying, yes, it is not really conservative to say 325/350 as that is probably closer to accurate than the higher numbers.
  2. Mar 21, 2014 at 6:24 AM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    I thought dynos were done on a 1:1 ratio
  3. Mar 21, 2014 at 6:27 AM
    KingKoda
    Palmetto
    '12 TRD.S DCSB 4x4
    You're likely correct and I may be wrong, it's been a few months now. I know jack squat about how a dyno pull should be done and this was my first time with any sort of dyno experience. The truck was warmed up as it was nearly an hour drive, guy spent several minutes once hooked up to everything making some mid-rpm runs/punches to get a feel for the gear kick downs/changes and then we made a few pulls looking at the computers each time in between. They seemed knowledgeable for whatever that is worth, had plenty of turbo cars EVO/STI types in the back that they tuned, turbo vipers, and said they had the diesel truck guys come in to dyno fairly often. I doubt it was the first time they had dyno'd an automatic.
  4. Mar 21, 2014 at 6:52 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Until ya do the fuel pump, I'd def get that fpr hooked to the boost port.
    I'd say keep an eye on em, but u don't have a gauge yet...... Just be careful I guess.
  5. Mar 21, 2014 at 6:55 AM
    KingKoda
    Palmetto
    '12 TRD.S DCSB 4x4
    Oh yeah, The truck is babied for the most part, I mean, I get on it some to stretch the legs occasionally, but I'm not taching this bitch out drag racing at lights or keeping the pedal in it slinging mud in the field...as fun as that would be. This is just a DD truck that I sup'd up a little and sees some light camp trails in the mountains. I get pissed off at bird shit, no need to dent and scratch it up just yet.
    Thing is that was brought up as well is that during the dyno session the AFR was measured from the tailpipe probe, down stream of the front two cats. This likely made the reading slightly leaner than what it truly is at the collectors/manifold. But I have the fuel pump upgrade sitting in the garage....still.
  6. Mar 21, 2014 at 6:55 AM
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    Sorry didn't realize you had a dual VVTI so it can explain most of the difference.:D
  7. Mar 21, 2014 at 6:58 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    ? We don't have dual vvti
  8. Mar 21, 2014 at 7:02 AM
    KingKoda
    Palmetto
    '12 TRD.S DCSB 4x4
    Nope, unless I did some sort of FJ engine swap in my sleep.
  9. Mar 21, 2014 at 7:05 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Lol.... Ambien defense
    I believe I heard they aren't as strong anyhow.
    I'm on my phone tho and the PDF I read is on the pc
  10. Mar 21, 2014 at 8:26 AM
    WOODEX M.E.
    WOODEX M.E. Well-Known Member
    Corey
    Maine
    2013 Tacoma TRD OR Pyrite Mica
    TRD Supercharger, Speedhut TRD Boost Gauge, Speedhut TRD AFR Gauge, PLX Wideband Controller W/Bosch O2 Sensor, Cravenspeed Boost Pod, AFE Pro Dri II Si Intake, Calvert Racing Caltrac Traction Bars. URD Catback Exhaust, URD 2.825" Super Grip Pulley, URD Spec-U Equal Length Headers, URD 255lph Fuel Pump, OEM FPR Mod.
    If that's the case then I can appreciate these numbers. So really he has gained about another 70-75 hp on top of the supercharger? My goal ultimately is to some day get a safe 375hp/400lb-ft to the crank. But based on these numbers, it can be done without being too ridiculous. I really don't want to go down the same path you have Torspd, too expensive for my blood. I know Toyota rates the engine at 304hp with the charger so I was concerned when I saw all the modifications and the pulley with what I perceived as a small gain. Glad to see that those numbers are at the wheels. Guess I should dyno this summer so I have a baseline before I start adding stuff.
  11. Mar 21, 2014 at 12:30 PM
    KingKoda
    Palmetto
    '12 TRD.S DCSB 4x4
    I don't believe this is correct. I am under the assumption the ~304HP/334TQ factory TRD S/C figures are at the wheel. Not sure these bolt on performance modifications produced 70+ HP at the wheel. They produced an additional 20-30HP at the wheel depending on conditions which would back up the dyno fiqures for roughly 325HP/350TQ. Either way, you won't know for sure what mods have what effect and how to tune for those mods without using a dyno and using that same dyno as your baseline. I do know, my Tacoma is pretty fun when you press down that skinny pedal for what it is, a midsize truck with some balls. This isn't my need for speed machine though. Hell, I'd even tweak my leaf blower to make it more powerful if I thought it was worth it.
    EDIT: maybe they did....pulley 20, intake 10, exhaust free up 20...I dunno, I'm a shade tree mechanic in my own home garage that just has a knack for mechanical things and knows how to put back together what I take apart from working on cars with my father as a kid, if I have the tools I will do it; not sure how the factory states its' HP/TQ numbers, I always assumed at the wheel, maybe the dyno software adjusted for that....TORSPD?
  12. Mar 21, 2014 at 1:16 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    TRD numbers for bolt on s/c are what you two listed. At the crank. Pulley (size depending), headers, intake, Y-pipe, catback, etc..... will get it over. Tuning combined will further advance those wheel hp numbers.
    There is a dyno graph in my F/I #'s link, near the end, which shows what a bare stock s/c install does. Under impressive really, but it is accurate in the fact that the increase was around 70 whp over stock N/A. _~200 whp.
    Lucario Runner is making around ~250 - 270 whp N/A ( I cannot remember exactly, but his dyno is recorded here.), and ~ 300 wtq.
    So to pick up 50 - 70 whp from those simple bolts-ons, on top of the TRD s/c, is easily achievable.
    DanoDavis likes this.
  13. Mar 21, 2014 at 1:19 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    They aren't as strong. They have been redesigned again to make up for their failings. Our 1GR is a very well designed engine. Rods and pistons pretty much makes it amazing.
