tacoma exhaust question
Discussion in 'Performance and Tuning' started by pherpher85, May 20, 2008.
  1. May 20, 2008 at 8:15 PM
    pherpher85
    pherpher85 [OP] Member
    tulsa, ok
    1998 Tacoma SR5 2.7L, 31x10.50
    I have a 1998 Tacoma with a 2.7l. I'm going to put on a 3-chamber flowmaster and i'd like to know if it's going to affect me to take off my catalytic converter. Will it cause any problems with my o2 sensor? I don't have any emmission laws so I'm not worried about that. If i take it off will i benefit at all? I can use any help. Thanks
  2. May 20, 2008 at 8:20 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    sweet.....going with the flowmaster!!! gonna sound killer man!! depending on where your o2 sensor is, it may help to take it off. if the sensor is before the cat.....take it off......it wont throw a cel as far as i know anyway. removing the cat will probably yield better flow, a bit more power too, and maybe mileage will increase a bit. if you are any worried about the environment(as alot of people are), go with a magnaflow hi-flow cat. i say remove the cat and put in straight pipe....do it the right way. one caution for you though.....its gonna make it quite a bit louder, but if your like me and like "loud".......i say go for it!
  3. May 22, 2008 at 9:16 AM
    ubermx5
    ubermx5 Well-Known Member
    Santa Clara CA
    98 2.4 5 speed
    K&N Air filter
    I can not say for sure 100% that removing the cat will help or hurt gas millage but you should keep a CAT in there if you can..
    If we want to go off roading and have forests, we need to think about how we impact it.
    But if you are racing and need the extra bit of peak only HP that removing it gives go for it. then when the race is over put the CAT back in...
    Yes removing CAT will only help with Peak HP in most case.
    keep food for thought...
  4. May 22, 2008 at 10:26 AM
    1killerkaw
    1killerkaw Well-Known Member
    08 Silver DC LB SR5 4x4 Tow Pkg.
    Pop-N-Lock, AFE OE Replacement Pro Dry S, 20% tint all the way around, 6000k Bi-Xenon HIDs, 3" Dynomax super turbo muffler, ATC LED Limited campershell, Bedrug, Suspension TSB.
    Make a test pipe. Header flanges on the cat, test pipe and pipe from the motor and tailpipe.
  5. Mar 8, 2011 at 4:09 PM
    TacomaNC
    TacomaNC Active Member
    NC
    borla exhaust tintind windows
    what he said
