Tacoma Factory oversized oil filter, really?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ERdept, Mar 19, 2008.
  1. Mar 19, 2008 at 2:19 AM
    ERdept
    ERdept [OP] Well-Known Member
    I read somewhere that Toyota made their own oversized oil filter for the Tacoma, but I don't see it on the TRD website.
    Oversized, supposedly being better for larger surface area for better flow and more filtration.
    Is there such an oil filter to fit the Toy Taco 2008 V6?
  2. Mar 19, 2008 at 3:18 AM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    It could be someone was refering to using the filter from the V6 which is larger in place of the filter for the I4.
  3. Mar 19, 2008 at 4:14 AM
    45longcolt
    45longcolt Well-Known Member
    DFW Area
    2020 Off Road
    Ask for the "D4" filter. The "D3" is the shorter one.:)
  4. Mar 19, 2008 at 7:47 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    The filters I use 90915-YZZD3 are supposed to be oversized....?? They're actually Tundra filters (I think).
    For 1FZFE, 2UZFE and 1GRFE V8 engines
    They're the same width but a little taller....atleast, taller than what was on it from the factory.
  5. Mar 19, 2008 at 11:17 AM
    ERdept
    And it will screw perectly onto the thread of the 2008 Taco?
    This will mean I'll have to add more oil, how much more do you think, 1/4 bottle?
  6. Mar 19, 2008 at 11:53 AM
    Janster
    Jandy
    Lancaster, PA
    It's working on my 2007 4.0L.
    I'm still trying to figure out the oil capacity. The dipstick on these trucks suck. My last oil change I put in the required 5.5qts and the dipstick was low. I added about another 1/2 quart.... that's as far as I went. I posted a thread on here (I think) and got atleast one other person to confirm they put in 6qts with an oversized filter (not the same filter). I'm not adding anymore regardless of what I think the dipstick says...6qts is enough. I'll probably check it in a few thousand miles to make sure. I think the dipstick is easier to read once there's some miles on the oil.
    The first time I did the oil - I put in 5.5qts and left it there. After about 3,000 miles, I added 1/2qt to it cuz it was at the low line.
    (I've only had 2 oil changes on the truck since I've owned it)
  7. Mar 19, 2008 at 7:01 PM
    aaronk
    aaronk Well-Known Member
    2009 Dbl Cab V6 TRD
    I just did my first oil change a few hundred miles ago and noticed the same thing; 5.5 quarts and it was still low. I didn't put in 6 qts but it was a good 5.75 qts. I'm using the YZZD3 filter if it makes any difference.
  8. Mar 20, 2008 at 2:33 AM
    ERdept
    OK, thanks. I also read about the dipstick being bad. I will sand it with 800 grit tomorrow and clean really well to make the oil adhere and more readable. My old car used to have cross hatch makes built right into the end of the stick.
  9. Mar 20, 2008 at 7:52 AM
    Janster
    Jandy
    Lancaster, PA
    Let me know if that works....
    I didn't have any problems with the oil on the dipstick at all. In fact, the oil was everywhere on the dipstick.
  10. Mar 20, 2008 at 8:04 AM
    Demoncleaner
    Demoncleaner Well-Known Member
    Upstate NY
    05 Dcab 6spd 4x4 TRD Sport w/Tow
    TRD exhaust Homemade bed mat & bed extender, front Drings, Short clutch throw, Summer: Stock 17's Winter: Blizzaks on 16' black steelies
  11. Mar 20, 2008 at 12:02 PM
    Janster
    Jandy
    Lancaster, PA
  12. Mar 20, 2008 at 4:10 PM
    45longcolt
    DFW Area
    2020 Off Road
    Me BAD. I had the numbers reversed in my head. Thanks guys for not ripping me on it, but I don't mind being corrected. The "D3" is the taller one.
    Mine had a tall one on it from the factory and it looked a whole lot more engineered inside compared to the replacement. Anyone else notice that?
  13. Mar 20, 2008 at 8:44 PM
    Janster
    Jandy
    Lancaster, PA
    Believe it or not.... I did some googling earlier this week and there is a D4 filter that some of the other toyota vehicles use. Your post was perfectly legit.
    I also found out (according to other folks online) that the D3 filters are made in Thailand and are inferior to its older counterpart that Toyota stopped making. Go figure...
  14. Mar 20, 2008 at 11:37 PM
    ERdept
    Ahh, the Thai. Good food though.
  15. Mar 21, 2008 at 4:12 PM
    nc1100c
    nc1100c Active Member
    I just ordered a case of the original type oil filters that come on our trucks. These filters are made in Japan and are part number 90915-20004. The dealership tells you they are not avalable but they are. I ordered mine from American Toyota in Albuquerque, NM. Phone number is 505-823-4440. Ask for Jim. You can get them cheaper if you order them by the case. They are what came on our trucks from the factory and are superior than the replacement filter style.
    These filters are very hard to find in the US so just give American Toyota a call in Albuquerque.
  16. Mar 27, 2008 at 1:57 PM
    awoit
    awoit Well-Known Member
    CA
    08 TRD, SR5
    hey guys, i just changed my oil filter for the first time, and its way shorter than the one that came with my 08 taco, the one kragens gave me was PH3614, anyone else using that one for the v6 4.0?
  17. Mar 27, 2008 at 5:13 PM
    jdubh
    jdubh Active Member
    08 Double Cab V6 4x4
    I used a Fram XtraGuard filter on my first oil change last night, part number PH3614, it was way shorter than the stock filter which is why I'm here searching threads on the oil filter. I about never got that factory filter off, first the filter wrench stripped the top, then my pipe wrench twisted it...I had to shove a philips screwdriver through it to turn it, damn was it on there!
    I'll have to order a supply of the big ones from Toyo. Also switched to Mobil-1 Full synthetic and put in a K&N air filter to see if mileage improves at all.
  18. Apr 1, 2008 at 8:47 PM
    4x4x4trd
    4x4x4trd My other ride weighs 200 tons
    North Texas
    08 White Access Cab TRD OR, Debadged
    AFE oil free drop in, Secondary removed, tint, front D-rings, Toyota bed mat, Undercover tonneau, TRD seat covers and floor mats, Pioneer speakers, Westin Platinum bars, Fumoto oil valve, short antena, Nifty Xtreme's, TSB leaf springs, Bilstein 5100's set at .85" in the front
    I changed mine today and the filter the Toyota parts dept. gave me was Toyota #90915-YZZG1. This one was the same diameter and thread but was about .75" shorter than the original one I removed. I also installed the Fumoto valve on the oil pan at this time. I did a full warm up leakage test and it was good. This appears to be the same filters I used on my '99. This replacement is also the same size as a Purolator #L10241 that I bought after reading some reviews. I got 4 of these Toyota filters for $3 a peice. It took 5.5 Qt to top it off.
    Anybody see anything bad happening using these up as far as actual filtering? :eek:
  19. Apr 2, 2008 at 4:04 PM
    4x4x4trd
    North Texas
  20. May 8, 2008 at 5:35 PM
    Punisher
    Punisher Billy Reuben
    Massachusetts
    2008 Access Cab TRD Off-Road
    Here is what I just took off , black stock one from factory, and then the new white TRD one. The TRD one is taller and wider.
