Tacoma Fender Flares
Discussion in '2nd Gen. Tacomas (2005-2015)' started by park713vmn, Jul 27, 2010.
  1. Jul 27, 2010 at 1:22 PM
    park713vmn
    park713vmn [OP] Member
    Hey guys,
    So I was wondering if any of you have put fender flares on your taco. I have an '05 SR5 that I would like to get some for. I'm talking about OEM ones, not the bushwhacker style. If you have, did you have to get them from the dealership, and how much did you pay for them? How was the installation on them, they don't look like they would be that difficult to install.
  2. Jul 27, 2010 at 5:09 PM
    drewskie
    drewskie Well-Known Member
    Drew
    Burbank, CA.
    08 Prerunner 4 banger
    If your truck is not a prerunner, you can't install them they attach to holes in the fenders and bedsides, which you don't have.
  3. Jul 27, 2010 at 5:59 PM
    park713vmn
    Thanks for the help, I appreciate it!
  4. Jul 27, 2010 at 9:26 PM
    grizzlytravis
    grizzlytravis Well-Known Member
    tampa florida
    08 taco 5 lug
    3inch ready lift, tint, foglights,BHLM,dumped exh,rims,tires, and a dent in the bumper
    in my moms hood there is a guy with a reg cab base model and he has fenderflares...dont kno how or where he got em but imo they look like shit on his truck
  5. Aug 8, 2010 at 3:03 PM
    hansonian
    hansonian swims with fishes
    Tampa, FL
    2010 Double Cab PreRunner SR5
    Stock
    i have a 07 prerunner and mine came with the fender flares painted to match the truck. IMO this looks like a$$. does anyone know how hard it is to take them off? i was thinking about getting them painted black or would it be easier to find some black ones and just swap them out?
  6. Aug 8, 2010 at 3:23 PM
    Larry
    Larry CARL
    CARL
    I betcha you could find a member on here that would do the swap for your color flares.
    Post up in the parts section.
    Good luck.
  7. Aug 8, 2010 at 3:43 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Holes are easy enough to make. Is there something special about these holes?
  8. Aug 8, 2010 at 3:58 PM
    epa4wd
    epa4wd Well-Known Member
    Eduardo
    2019 SR
    Clazzio Seat Covers OR Wheels 40% tint Side Steps KC Fog Lights
  9. Aug 8, 2010 at 6:27 PM
    drewskie
    Drew
    Burbank, CA.
    To get the right placement, and size. it would be damn near impossible. The holes are used for clips that fit perfectly in them, then attach to the fender. I guess if you want to drill the fenders and bedsides you could just bolt the flares on that way.
  10. Aug 8, 2010 at 7:04 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    You could do the holes if you know how to do body work, getting it aligned correctly would be difficult but not impossible.
    The easiest route would probably be to just swap the entire panel that's already pre cut for them. Though if I were going that route I'd probably just do some glassworks widebody.
  11. Aug 9, 2010 at 4:34 AM
    Pugga
    Massachusetts
    Yeah, that would be difficult. I was thinking just a drilled hole and couldn't see why that would be a problem. Aftermarket look-alikes might not be a bad option then.
