Tacoma Fuel Economy
Discussion in 'Technical Chat' started by 007Tacoma, Feb 1, 2007.
What Engine + Mileage Does Your Tacoma Have (Average)?
  1. 4cyl <16 MPG
    17 vote(s)
    0.5%
  2. 4cyl 16-20 MPG
    186 vote(s)
    5.1%
  3. 4cyl 20-25 MPG
    369 vote(s)
    10.1%
  4. 4cyl >25 MPG
    80 vote(s)
    2.2%
  5. V6 <16 MPG
    412 vote(s)
    11.3%
  6. V6 16-20 MPG
    2,121 vote(s)
    58.1%
  7. V6 20-25 MPG
    448 vote(s)
    12.3%
  8. V6 >25 MPG
    18 vote(s)
    0.5%
  1. Feb 5, 2007 at 7:36 PM
    LovinMyTaco07
    LovinMyTaco07 Well-Known Member
    This thread discusses ECU re-flash...
    It will adjust to your driving habits...
  2. Feb 7, 2007 at 5:13 AM
    007Tacoma
    007Tacoma [OP] I dub thee malicious!
    Mark
    San Antonio, TX
    2003 4Runner SE 4WD
    I would not recommend "resetting" your ECU yourself. I am going to talk to the dealership when I get my first oil change, but I am betting that they do this themselves.
    I went to go get my oil changed at 3000 miles - they told me not to come back until I hit 5000 miles. I told them that I wanted to make sure that my truck was in peak performance condition. They said they aren't allowed to change the oil until 4900 miles due to the break-in period of the engine. Sounds to me like smoke. What do you guys think?
  3. Feb 7, 2007 at 6:04 AM
    007Tacoma
    Mark
    San Antonio, TX
    2003 4Runner SE 4WD
    BTW - I think my MPG is slowly starting to come up.
  4. Feb 7, 2007 at 10:12 AM
    TRDeity
    TRDeity Well-Known Member
    ATX
    '07~TRD Offroad~Idigo Ink~Access Cab~4.0~6speed
    After your engine is truely broken in your MPG may go up. A friend of mine average milage went up 6 MPG at 10K (Not a tacoma but it keeps me hopeful that mine may go up slightly).
  5. Feb 7, 2007 at 10:16 AM
    007Tacoma
    Mark
    San Antonio, TX
    2003 4Runner SE 4WD
    Crossing my fingers!
  6. Feb 10, 2007 at 9:35 AM
    tx_steve
    tx_steve Member
    have under 3000 still on the 2007 v6 auto.
    was getting 19-19.5 till last tank got 20.2 and that included a couple of hard charges onto the freeway! looking forward to breaking into atleast the 22 mpg range
  7. Feb 11, 2007 at 7:37 PM
    surfponto
    surfponto Well-Known Member
    Good to hear.
    We just got 22 mpg on ours this last tank. Still under 3000 miles on the odometer. That is our best so far.
  8. Feb 12, 2007 at 3:09 AM
    RAPOM
    RAPOM Well-Known Member
    I changed mine at 3200 and went with a larger filter. Depending how you drive as long as you score the cylinder walls and the rings conform to them as I was told by a CAT mechanic you are good to go. I was also told to go with a bigger filter for less chance of it filling and bypassing the filtering process.
  9. Feb 12, 2007 at 3:30 AM
    007Tacoma
    Mark
    San Antonio, TX
    2003 4Runner SE 4WD
    Huh, I have never heard of going with a larger filter. I will have to look into it.
    I do have good news. Last tank, I got 23 MPG. That was with a ton of in-town driving.
    I went back to my sticker on my 007 (glovebox for life!). It says that the city average should be 23, so I am good there. When I go to San Antonio this weekend, I will see if I can get closer to the 28 MPG it says that I should get on the highway! :rolleyes:
  10. Feb 12, 2007 at 3:32 AM
    RAPOM
    It just holds more oil and contaminants. I went with a KN 2009. It also has a 1 inche nut on the bottom to make getting it off a lot easier.
  11. Feb 12, 2007 at 3:35 AM
    007Tacoma
    Mark
    San Antonio, TX
    2003 4Runner SE 4WD
    How in the world do you make sure that the cylinder walls are scored in an even manner that the rings can conform to??? :confused:
    The only thing that I can think of is the obvious - change your oil. Dirty oil will score the cylinder walls and cause compression issues and eventually will have you burning oil! :eek:
    I have always made it a point to change my oil at 3,000 miles. Even my diesels got changed at 3,000 miles. Plus, I use the best oils I can find. Usually I use Amsoil if I can find a dealer near where I live at the time. Maybe that is why I get 200,000+ miles out of my old Accord, Jetta TDI, Suburban, and my old Subaru... :)
  12. Feb 12, 2007 at 3:36 AM
    007Tacoma
    Mark
    San Antonio, TX
    2003 4Runner SE 4WD
    The nut on the bottom - Is that for draining it before you take it off?
  13. Feb 12, 2007 at 7:59 AM
    RAPOM
    The rings score the cylinder walls in any motor, thats what creates a good seal for compression. (Remember, I am not a mechanic this is just stuff I have heard over the years) It may not even be that visible to the naked eye.
    The nut on the filter is to aid in removing the filter. I just use a 1 inch socket and a long extension. Its better than trying to get a filter wrench.
  14. Feb 12, 2007 at 9:53 AM
    007Tacoma
    Mark
    San Antonio, TX
    2003 4Runner SE 4WD
    Ditto! :D
    OH! I guess I was over analyzing it's purpose in life... :)
  15. Feb 12, 2007 at 10:10 AM
    #35
    RAPOM
    You would have to tear the engine down to check it. The motor does all this by running. Break in as I am told is the mating of parts in an engine, they break in or fit together. They produce exceptable wear patterns, evidence of this is how an oil sample monitors or detects different metals in your oil. Different metals for differents parts of the engine. That is how they can tell what part is wearing or wearing out as time and miles add up. A oil with good film strength is what to look for I am told. Anyway, how I see it as the motor breaks in over say 5000 miles the parts of the engine, tranny, axles have gotten to where they work smoothly together with less friction, which equals better mileage. I am no expert and if I have stated an inaccuracy here I'm sure someone will help me get on the right path and there I go learning again!
  16. Feb 13, 2007 at 12:24 PM
    #36
    007Tacoma
    Mark
    San Antonio, TX
    2003 4Runner SE 4WD
    I may be completely off my rocker :crazy:, but that makes complete sense to me! :D Thanks for the info.
  17. Feb 15, 2007 at 7:06 AM
    #37
    Rick2007Tacoma
    Rick2007Tacoma Active Member
    Well my mpg went up from up from 17.2 to 18.3 for the second fill-up. Not much but I’ll take it. I’m certainly expecting a lot better, 23 to 28, as the car sticker indicated. Every gas station I go to only has Ethanol, which I’m told reduces the mpg by 10%. Therefore, I can’t get a test without Ethanol. Just to grip a little, when I purchased the truck I was deciding between cars which were rated at getting 31 – 38 mpg, however I was willing to forgo a few mpg 23 – 28 just to have a truck. I would not have purchased the truck if I had known that the mileage was only 18+. It certainly better improve, or Toyota and I will be having some major discussions. Now on the bright side, I love the truck, but I want better gas mileage. I want this truck to get between 23 – 28 mpg as Toyota indicated. The truck is brand new as you know, only second tank full, but in reality, should I really expect the mpg to improve after the first 5000 miles?
  18. Feb 15, 2007 at 8:20 AM
    #38
    surfponto
    We are at 3000 miles and the mileage seems to have gone up. Just got 22 with a mix of hwy and city driving.
    I am pretty happy with that.:D
  19. Feb 15, 2007 at 10:26 AM
    #39
    Rick2007Tacoma
    What mpg did you get when the truck was new? And is it a 4 cyl?
  20. Feb 15, 2007 at 10:37 AM
    #40
    natrlyst
    natrlyst Well-Known Member
    The mpg rating you get is relevant to the American gallon, not the British Imperial Gallon, if you are calculating your own mileage then you should use the American Galon measurement. If your machine calc's it for you, it will be based on the American gallon measurement.
