Hammer Hangers® by Archive Garage 2005-2023 Tacoma Shackle Hangers
Discussion in 'Archive Garage' started by ARCHIVE, Nov 13, 2017.
  1. May 6, 2021 at 9:34 AM
    #2841
    ARCHIVE
    ARCHIVE [OP] Well-Known Member Vendor
    Eric
    Orchard Park, NY (Buffalo)
    '05 Taco, '22 Tundra, '91 Cummins
    2.5" Fox relocation * Hammer hanger * Archive MD springs
    I also take issue with a frame only boxed at the rear, but I understand it helps the rear frame not bend at bumpstop landing or hangers, just that is pretty much all its going to do more than say the Hh cross tube option.
    I would like to see you get our cross tube option under your truck with that weight, but I understand the spare tire issue on the camper
  2. May 6, 2021 at 9:45 AM
    #2842
    ARCHIVE
    Eric
    LT guys often have no choice but to box rear section because they notch the bottom, notch the side, cut in bumps cans.
    It doesn't solve the inherent Taco wiggles that result from an 1/8" thick C channel in the middle of the truck.
    The Tacoma frame should be the Ranger frame, its done right, basically the Tacoma frame 1/8" thick outside with full boxing inside.
    That's why the Ranger has the same 1,700lb payload as a current Tundra. Doubters can go check the numbers.
    Toyota should copy Ford so they can be respectable.
    Thankfully my frustrations with Toyota will be addressed in the 4th gen Tacoma and Tundra
  3. May 6, 2021 at 9:47 AM
    #2843
    Round the world
    Round the world Well-Known Member
    Andy
    Home's our Tacoma
    2019 Tacoma AC LB TRD Sport MT
    flatbed with 4WC Fleet with extensive mods
    Definitely would love to have the cross tube for strength but need to have the spare tire there as there’s no other place for it. I feel we already look like the Clampetts of the show Beverly Hillbillies.
    9F712309-9CC8-4C8E-8BE3-854CFBF70AF5.jpg 57FB0C58-A34B-4741-A7A1-384255F6117C.jpg
  4. May 6, 2021 at 11:26 AM
    #2844
    Round the world
    Andy
    Home's our Tacoma
    What grease are people using to lubricate the shackles? Was hoping that a synthetic grease called superlube would work?
  5. May 6, 2021 at 1:46 PM
    #2845
    ARCHIVE
    Eric
    I use that, it's pretty good, but Energy suspension or Prothane is more viscous and choosen by them for their bushings, so better choice
  6. May 7, 2021 at 8:47 AM
    #2846
    whatstcp
    whatstcp currently drunk so don't listen to me
    Ed
    Fontana, CA
    2006 Tacoma Regular Cab 2.7l 4x4
    King + Archive Relocation Wheeler's bumps +hydros
    like @ARCHIVE said, energy suspension is pretty good. They have a regular grease but also have their Formula 5 grease which is the tackiest sticky icky grease that I've personally dealt with. It's a bit pricey and doesn't come in a tube, only a small tub.
    https://www.amazon.com/Energy-Suspension-9-11104-Formula-Prelube/dp/B000CN7B4I
    Area51Runner and mud like this.
  7. May 7, 2021 at 8:50 AM
    #2847
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    Just curious when you lubricate the bushings what all do you lubricate? Im about to change out all mine again.
  8. May 7, 2021 at 8:56 AM
    #2848
    Round the world
    Andy
    Home's our Tacoma
    Curious myself, if it doesn’t come in a tube for the zerk fitting, how do you use it?
  9. May 7, 2021 at 9:02 AM
    #2849
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    Dissect the assembly. Lube by hand, then reassemble.
  10. May 7, 2021 at 9:03 AM
    #2850
    whatstcp
    Ed
    Fontana, CA
    I follow energy suspensions recommendation to lubricate everything that touches metal. So clean the inside of shackle/leaf eye, maybe take a brillo pad first if the leaf eye is a bit gritty, then lube up the eye and outer edge, OD/ID of bushing, and anti-seize inside the bushing sleeve. I've heard some people lube the inside of the bushing as well instead of anti-seize. Anything to keep the bolts and bushing sleeve from rusting I suppose. When finally installed, I just wipe any excess grease that may have been squeezed out to try and minimize the accumulation of dirt and grime.
    lube it up when it's apart, reassemble. You can also scoop the grease out of the tub and into a small grease gun which is a bit messy. I don't have zerk fittings on my stuff yet, on the to do list.
  11. May 7, 2021 at 9:05 AM
    #2851
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    :confused:
  12. May 7, 2021 at 9:09 AM
    #2852
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    Ive heard like a million different things lol. Im just gonna lube everything that touches metal lol. I always lube the outside/face and inside of bushing. Ive never put anti-seize on that bolt though but in the south we don't really have to worry about rust. Even pulling my stock cam bolts for the first time i was able to get them out with not that much rust on them and they had been through hell lol over 100k.
  13. May 7, 2021 at 9:15 AM
    #2853
    whatstcp
    Ed
    Fontana, CA
    yeah I remember some folks saying to not lube the outside of the bushing because of some reason; but yeah if it touches metal, it's getting a slatherin'. No issues and everything cycles as it should.
    Brian422[QUOTED] likes this.
  14. May 7, 2021 at 10:06 AM
    #2854
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
  15. May 7, 2021 at 11:11 AM
    #2855
    TheBlueBeast15
    TheBlueBeast15 Well-Known Member
    Kevin
    SoCal
    2015 Blue Ribbon Metallic TRD Off Road double cab short bed
    whatstcp[QUOTED] likes this.
  16. May 7, 2021 at 7:39 PM
    #2856
    ARCHIVE
    Eric
    I think the only good reason to grease the outside of the bushing is for insertion and to keep the outer metal from rusting, which would squeeze down on the bushing.
    Having the bushing turn is bad, therefore why greasing outside of bushing could potentially be bad.
  17. May 9, 2021 at 4:52 PM
    #2857
    ARCHIVE
    Eric
    New stickers and hint about something new
  18. May 9, 2021 at 4:57 PM
    #2858
    H3llRid3r
    H3llRid3r Well-Known Member
    SLcUT
    2018 DCSB Cement TRD OR
    Not much stock left.
    Leaf pack perhaps?
    Edit: sticker looms bitchen!
    ARCHIVE[QUOTED][OP] likes this.
  19. May 9, 2021 at 5:14 PM
    #2859
    doorsidedown
    doorsidedown Well-Known Member
  20. May 9, 2021 at 5:22 PM
    #2860
    Sixthelement
    Sixthelement Ran over a Yeti once, Texas, never again
    Flagstaff
    JD LT
    I spy engineering drawings for leaf packs...
