Tacoma Hill Towing
Discussion in 'Towing' started by beeser, Jul 31, 2008.
  1. Jul 31, 2008 at 3:09 PM
    beeser
    beeser [OP] Active Member
    I have a 2004 Tacoma Prerunner (V6 - auto) that struggles pulling a 3700 lb. travel trailer up hills. The best I can do is about 30 - 40 mph up 6% inclines. The speed drops to about 25 to 30 mph on 8% grades. What would you expect from a newer Tacoma under the same conditions.
  2. Jul 31, 2008 at 3:39 PM
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
    The 4.0L would do well.
  3. Jul 31, 2008 at 3:48 PM
    ubermx5
    ubermx5 Well-Known Member
    Santa Clara CA
    98 2.4 5 speed
    K&N Air filter
    Well did you have the Towing package?
    if not You might want to upgrade a few parts.
    1. Tranny cooler
    2. tranny flued
    3. Fan Clutch
    4. Possible headers and better exhuast
    5. Deck plate mod. Search
    6. Super Charger.
  4. Jul 31, 2008 at 4:10 PM
    beeser
    Any ideas on how much better the 4.0L would be over the 3.4L? I know it's subjective and hard to answer but how much more speed can I expect up the mentioned grades?
  5. Jul 31, 2008 at 4:15 PM
    beeser
    My 2004 has the factory hitch and fan clutch for towing. The Toyota dealer changed the transmission fluid to a synthetic. Not other coolers besides what the factory provides, in other words no supplemental coolers. I don't want to modify the truck. That's why I was asking for a comparison with 2nd generation Tacoma. If that doesn't deliver the performance needed I'll probably moved over to a Tundra.
  6. Jul 31, 2008 at 4:37 PM
    Ridingontrd
    Richard
    Laughlin,N.V
    There are some 7%-8% hills here also.But I'm pulling half your lbs.Maverick491 is the keeper of the towing bible.Much better info from him.:) I can only guess what your mph would be w/that load. Hope this helps.
  7. Jul 31, 2008 at 6:20 PM
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    The 4.0 won't disappoint you! I've towed 2 ford full size pickups on UHaul auto transports up and over mountains on 100 mile trips. Down into city traffic and back up the other side. I have a manual and had no problems meeting the 30mph limit and accelerating after the speed limit jumped to 45 and then 55. If the speed limit was 55 then I had no problem maintaining speed and was after to keep it in 6th on the flats. I figure those trucks and transport weighed around 6,000lbs since the auto transport was 2,000lbs alone.
  8. Jul 31, 2008 at 7:30 PM
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    My travel trailer is 3750 wet and ready to camp, and On a 6-8 % grade I do have to dump 6th gear, but can hold 55-60 in 5th. One of our favorite campgrounds is on a mountain top in the Pocono Mountains of Pennsylvania, and there are some grades on that climb that require 2nd or even 1st gear, Not sure what the grade is on the last part of that climb, but I always wind up getting to the campsite with only 3/4 of my freshwater tank remaining, the other 1/4 having run out of the overflow durring the climb if that helps to classify them at all. I'd be concerned about them in a vehicle with less power on tap.
    Regards,
    Adam
  9. Jul 31, 2008 at 7:51 PM
    TacoTurd
    TacoTurd Defying Alliances since 2007
    Central Texas
    07 PreRunner TRD Sport
    TRD Exhaust, TRD CAI, Bull Bar, PIAA lights, Passport, Bed Mat, UWS Toolbox, Hood Struts, Rear TSB, TRD/Okole Seat Covers, Hellwig Rear Sway Bar, Burned Carpet, Nasty Dent in Roof
    Hell I'd get the Tundra if you're towing 2 tons regularly for the engine AND the brakes. Plus I bet you would actually get better gas mileage on the loaded rig.
    They are GIVING Tundras (and Silverados and F-150's) away right now. :eek:
  10. Aug 1, 2008 at 7:13 AM
    beeser
    You're probably right about the Tundra. It's just that I like the Tacoma for the size and gas mileage while not towing. I was hoping that the 2nd generation Tacoma towed significantly better up grades over the 2004.
  11. Aug 1, 2008 at 8:04 AM
    maverick491
    South Jersey
    It is and the Tundra is ugly as hell. You would do fine with a gen 2 truck. Don't worry about it. The gen 2 truck does fin on all but the steepest grades, gets good mileage, and doesn't look like ass on wheels.
  12. Aug 1, 2008 at 8:07 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Do you have any lift or bigger tires on it?
    What's the stock gearing in the 3.4L Auto pre-runner?
    You might wanna put some higher (numerical) gears in the diff. That might get you back in the power band up those hills.
  13. Jan 17, 2009 at 9:08 AM
    jonl9
    jonl9 Jonl9
    Eastern North Carolina
    06 Prerunner, Xtra cab, towing package
    I haul a high wall pop up with our 2006 Access Cab with automatic and tow package. The dry weight of the Pop Up is around 3200 pounds, the GVWR is just under 4,000 pounds which is probably close to where the weight really is. I can pull the 8% grade up to Boone, NC and maintain the speed limit of 55 mph comfortably, it has shifted down to third gear, but I don't have to floor it and the engine is not wound up unduly. I am totally satisfied with my Tacoma's pulling power.
  14. Jan 18, 2009 at 6:58 AM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    The true test is how is does on the road into Blowing Rock. That is one steep sucker.
  15. Jan 18, 2009 at 9:55 AM
    jonl9
    jonl9 Jonl9
    We take highway 421 up to Boone which is the long 8% grade I referred to. Boone, NC and Blowing Rock, NC are fairly close together and our route to Blowing Rock is through Boone. There is a route 321 that heads directly up to Blowing Rock from the highways to the south, we've not taken that road. We have hauled 194 up to the Boone KOA with no problems. The Tacoma has exceeded my expectations with our camper on the mountain roads we've been on.
    In fact, I worry more about coming down some of these roads far more than going up. I go slower towing down than I do towing up those grades.
  16. Jan 20, 2009 at 5:55 AM
    JDCPA
    Jim
    SW FL
    That's the road I am talking about. It is one steep sucker.
