Tacoma in Snow
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Edgeplay, May 11, 2013.
  1. May 11, 2013 at 5:05 PM
    Edgeplay
    Edgeplay [OP] Well-Known Member
    Sean
    Connecticut
    13 DCLB MGM
    -Leather Seats -Weathertechs -LED map and dome -6K HID head lights, -Glove and Center Consol organizer -30" LED bar in lower valence
    Been a long time lurker and after this summer I am going to be able to finally get one. I'm in the northeast and as I keep reading on here with snow and overprotective ABS. Are these trucks bad in the snow? I will be coming from a older yukon(2000). I know it will be a little different because of the bed with no weight but I keep thinking putting a little weight in would fix that. It won't change my mind with the truck but is there something I am missing.
  2. May 11, 2013 at 5:11 PM
    dsjones5
    dsjones5 Well-Known Member
    DSJ
    Georgia
    2011 MG DC Taco
    Seat covers, weather tech digi fit, bug deflector, plasti dip wheels, magnaflow muffler, and many more to come!.. as soon as i get money. Ill probably go broke typing this...
    heard they are pretty bad. Probably the best thing to do is install some snow tires and perform the ABS switch mod. Just search TW forum.
  3. May 11, 2013 at 5:13 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    You'll be fine
  4. May 11, 2013 at 5:16 PM
    Edgeplay
    Sean
    Connecticut
    13 DCLB MGM
    I will have the 4WD and all season tires (at least till I get some money). I have been looking though forms I was just wondering if anyone had any other input that I might have missed other than the ABS being too safe.
  5. May 11, 2013 at 5:17 PM
    OZ-T
    Peter North
    British Columbia
    The ABS is sensitive on these trucks , not a death trap
  6. May 11, 2013 at 5:20 PM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    if you buy one with the dunlops get new tires or have the dealer give you what you want before you buy. i have not one issue with my truck in snow here in mass
  7. May 11, 2013 at 5:39 PM
    Edgeplay
    Sean
    Connecticut
    13 DCLB MGM
    Thanks for the replies Was just seeing what people thought cause some make it sound like death traps.
  8. May 11, 2013 at 5:42 PM
    OZ-T
    Peter North
    British Columbia
    Good tires will help , stock size or close to stock size tires will help , driving style helps and snow type is a factor ( dry vs wet )
    Worst case scenario you can install an ABS disable switch for winter
  9. May 11, 2013 at 5:53 PM
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
    Designated winter tires make a big difference and minimize the impact of the ABS sensitivity
  10. May 11, 2013 at 5:54 PM
    radtastic
    radtastic New Member
    11 V6 SR5 4x4
    I did fine, up in Maine. I have a few hundred pounds in the back with my cap/tools. The Dunlops were terrible the second winter, but I put over 8,000 miles in this winter without any issues. Just take it easy, and you'll be all set, no matter what tire you have (except Summer, for obvious reasons). I'd definitely recommend a better set of tires than the Dunlop Grandtrek. I use Goodyear Wrangler SilentArmors on my Silverado. While they are not snow tires, they do great, in my opinion.
  11. May 11, 2013 at 6:05 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Duratracs are amazing in the snow, and studdable if you've got a bunch of ice. 4wd is a must. Driving style helps (be aware that you're on snow and don't punch it or slam on the brakes). If you must, do the abs kill switch. I did mine before this last season and played around a little bit with it. Truck is completely drive-able with abs active, you just need to be aware of it. I ended up leaving it off because it seemed more predictable and I trust my driving skills enough that in the event of a slide or skid I can stay in control. All depends on your preference, though good snow tires are a must, and the duratracs are the best I've seen/ heard/ used.
    Now hurry up and get yourself a truck :thumbsup:
  12. May 11, 2013 at 6:11 PM
    Jux
    Jux :D
    Northern Colorado
    2013 V6 4x4 SW DCSB TRD OR
    I didn't have any problems this past winter.
  13. May 11, 2013 at 6:15 PM
    Hairy Taco
    North of Hell
    08 TRD
    My understanding is that the Duratracs are an AT with a relatively soft rubber compound which helps them perform in wet and snowy conditions. While snowflake rated, they are not a winter tire per se. A Blizzak would be a proper winter tire. It is even softer and thus provides even better traction in slippery conditions.
  14. May 11, 2013 at 6:17 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    I've never seen a "bad" truck in snow, I doubt there is such a thing. It simply a matter of having a tire providing traction + driving habits.
    As far as the "deathtrap" syndrome, it occur on every model of truck out there when someone assumes 4wd will/has to/ does make their truck better than a car, combined tires that aren't optimal in snow.
    For snow, consider any number of "severe weather rated", they vary from commercial, AT and a few in ASR.
    some models...
    Silent armor/duratracs from gd year
    toyo has xtx & wintercat, (m55 too?)
    BFG has one, Ta Ko maybe,
  15. May 11, 2013 at 6:17 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    They do fine, just use common sense. ABS shouldn't even be necessary for a good driver. With good tires and 4x4, you don't need any weight in the bed. Of all the trucks I've driven, I liked the taco's manners in snow and ice best to be honest. They aren't heavy enough to get stuck easy, yet they aren't light enough to slip and slide on ice like a toboggan.
  16. May 11, 2013 at 6:19 PM
    OZ-T
    Peter North
    British Columbia
    What does " ABS shouldn't even be necessary " mean ? It's not like you get to choose when it comes on
  17. May 11, 2013 at 6:20 PM
    Hairy Taco
    North of Hell
    08 TRD
    ^exactly
  18. May 11, 2013 at 6:22 PM
    Tacoyota
    08 4wd
    I think he is just referring to some peoples habits of using ABS as a signal to drive safer.... a safe driver wouldn't want to rely on it , etc
  19. May 11, 2013 at 6:22 PM
    OZ-T
    Peter North
    British Columbia
    Wut
  20. May 11, 2013 at 6:24 PM
    Tacoyota
    08 4wd
    my comment was in reference your post 16 about post 15 .
