Tacoma Lift FAQ/Guide - READ THIS
Discussion in 'Suspension' started by Khaos, Jul 10, 2008.
  1. Apr 18, 2012 at 9:32 AM
    #281
    jeratbp
    jeratbp Well-Known Member
    Jeremy
    Norfolk, VA
    '05 4Runner Sport V8
    Like others, I only want a 1" to 2" lift. I'm a bit overwhelmed and confused, but I thought all I need are the Bilstein 5100 Front and the AAL's.
    Which AAL's do I get to match the Bilstein fronts - 1.5" or 2"? What is the recommended height?
    I called one of the vendors today, and they sell the Bilstein 5100's front/rear together. Do I need the rear?
    Now I'm also thinking about wheel spacers (hub centric) too which I know is another subject. I think the higher stance with the wheels slightly out 1.25" would look great!
  2. Apr 18, 2012 at 9:37 AM
    #282
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    You want the rears also. They have longer travel & ride better.
  3. Apr 18, 2012 at 2:37 PM
    #283
    jeratbp
    Jeremy
    Norfolk, VA
    So with the Bilsteins, do I want the 1.5" or 2" AALs?
  4. Apr 18, 2012 at 2:44 PM
    #284
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    IIRC the rear 5100's have the same travel and length as stock, they are just valvued differently
    1.5" to level, 2" for some rake. That is if you are setting the front to 2.5"
  5. Apr 19, 2012 at 4:55 AM
    #285
    jeratbp
    Jeremy
    Norfolk, VA
    I'm not sure I want the fronts 2.5", I was thinking more around 1.5". So I will still have some rake then, unless I do go with 2.5".
    Thanks!
  6. Apr 19, 2012 at 6:47 AM
    #286
    TexasTacoma37
    1.75" front, 1.5" rear will still leave you with some rake. Close to the stock amount.
  7. Apr 25, 2012 at 1:20 PM
    #287
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    ok. i’m just trying to plan a lift for maybe this winter. (right now seeing what cost will be for lift and wheels tires) what is a good leaf pack? i kinda read over some pages. but i want 3” of lift and i’ll run a 33” tire.
  8. May 13, 2012 at 11:24 PM
    #288
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    Read the entire thread & it didn't click.
    I want a 3" lift. The 5100 billies seem most popular. But they only go to 2.5"?
    At 2.5" can you still use stock springs? TRD package.
    If at 2.5" the front would be higher than the back, how big of an AAL would I need?
    Besides the billies and AAL would anything else need to be replaced?
    Seems 3" is the breaking point for some other things like a UCA, is that if you go past 3" (3.1"+) or if you hit it (~3.0)
  9. May 16, 2012 at 10:20 AM
    #289
    IrmoRabbidMoose
    IrmoRabbidMoose Well-Known Member
    Jay
    Irmo, SC
    2003 SR5 Debadged 4x4
    tool box, tint. (Soon to come... HID's, Mud Terrains.)
    Wow, that was a lot of help quick! So with the install of 5100's I would have to go and buy larger coils with that as well? I'm just trying to make my truck level off or have that "Squatting" look on it. I'm not looking to go all out, it's only a double cab prerunner.
  10. May 18, 2012 at 2:26 PM
    #290
    TexasTacoma37
    Yes the only go up to 2.5. You can use your stock coils. And the uca break over point is 2.5". At 2.5" some need them some don't
    you can use your stock springs.
  11. May 19, 2012 at 4:52 AM
    #291
    Afraz
    Afraz Well-Known Member
    Toronto
    03 Double Cab TRD
    Projector H.I.D
    Hello Folks,
    If i got a 2 inch or 3 inch AAL lift n the back of the truck would a 2 - 3 inch lift cause significant issues with respect to the driveshaft or anything else ?
    Also by just lifting the back for the time being and not lifting the front, will it cause issues while driving ? especially at highway speeds ?
    I didn't even know it was possible to get a 3 Inch lift from simply an AAL until my spring shop said they'd really Arc up that piece of steel.
    I expect that while driving on bumpy roads, the rear will be fishtailing all over the place, what would be the best way to gain that extra height and still have relatively comfortable ride ? or is it just something i'd have to sacrifice for the time being ?
    Thank You All
    Also would i need to do alignment ? since its just the rear.. the guy at the shop said i didn't need to do alignment for rear.. if i went with an AAL
    [​IMG] [​IMG] [​IMG] [​IMG]
  12. May 29, 2012 at 3:07 PM
    #292
    1998triton
    1998triton Well-Known Member
    Matthew
    TN
    98 SR5 TRD
    do yall know the part number for the 5100s for a 1998 tacoma. there for the front
  13. May 29, 2012 at 5:53 PM
    #293
    RMAN808
    RMAN808 S)(AKALO)(AWAII
    Reid
    Pearl City, Hawaii
    '17 TRD OR 4X4 Quicksand
  14. May 31, 2012 at 6:36 PM
    #294
    TacomaMatt
    TacomaMatt Well-Known Member
    09 4x4 TRD OR AC 4.0L
    5100s x4; Front @ 2.5 & 1.5" AAL, Truxedo Lo Pro, WeatherTech window deflectors & floor mats
    Why do some guys need UCAs at 2.5 and others don't?
  15. Jun 30, 2012 at 1:49 AM
    #295
    Jbcm12
    Jbcm12 Well-Known Member
    Joshua
    Bay Area
    Hey guys, so I just picked up FJ TRD wheels and eventually I want to lift the truck to fit 85/75/16 tires. I have an 05 prerunner, but I feel as if the height of the truck is the same as 5 lug models and I don't know why. Last time I tried to get new tires they told me 265 was too big, I don't know why my truck is so low. But basically I want to get Billie's in the front and rear to go with an aal but do I need to change anythig else? Will anything wear down faster by changing it?
  16. Jul 1, 2012 at 9:51 AM
    #296
    TacomaMatt
    Thanks Khaos. I found this info about alignments on tirerack.com that helped me
    Alignment
    Lea esta página en español
    While it's often referred to simply as an "alignment" or "wheel alignment," it's really complex suspension angles that are being measured and a variety of suspension components that are being adjusted. This makes an alignment an important suspension-tuning tool that greatly influences the operation of the vehicle's tires.
    Out-of-alignment conditions occur when the suspension and steering systems are not operating at their desired angles. Out-of-alignment conditions are most often caused by spring sag or suspension wear (ball joints, bushings, etc.) on an older vehicle. They can also be the result of an impact with a pothole or curb, or a change in vehicle ride height (lowered or raised) on any vehicle regardless of age.
    Incorrect alignment settings will usually result in more rapid tire wear. Therefore, alignment should be checked whenever new tires or suspension components are installed, and any time unusual tire wear patterns appear. Alignment should also be checked after the vehicle has encountered a major road hazard or curb.
    Front-End, Thrust Angle and Four-Wheel Alignment
    The different types of alignments offered today are front-end, thrust angle, and four-wheel. During a front-end alignment, only the front axle's angles are measured and adjusted. Front-end alignments are fine for some vehicles featuring a solid rear axle, but confirming that the front tires are positioned directly in front of the rear tires is also important.
    On a solid rear axle vehicle, this requires a thrust angle alignment that allows the technician to confirm that all four wheels are "square" with each other. Thrust angle alignments also identify vehicles that would "dog track" going down the road with the rear end offset from the front. If the thrust angle isn't zero on many solid rear axle vehicles, a trip to a frame straightening shop is required to return the rear axle to its original location.
    On all vehicles with four-wheel independent suspensions, or front-wheel drive vehicles with adjustable rear suspensions, the appropriate alignment is a four-wheel alignment. This procedure "squares" the vehicle like a thrust angle alignment, and also includes measuring and adjusting the rear axle angles as well as the front.
    Not all vehicles are easily adjustable or fully adjustable. Some vehicles require aftermarket kits to allow sufficient adjustment to compensate for accident damage or the change in alignment due to the installation of lowering springs.
    When aligning a vehicle, it's appropriate for the vehicle to be carrying its "typical" load. This is important for drivers who continuously carry loads in their vehicles, such as sales representatives with samples or literature in the trunk. Additionally, when a vehicle is used for autocross or track events, some racers will sit in their car, or have the alignment shop "ballast" their vehicle to include the influence of the driver's weight on the suspension angles.
    The primary static suspension angles that need to be measured and adjusted are caster, camber, toe and thrust angle. Here's a definition of each angle and its influence on a vehicle and its tires.
    Camber
    The camber angle identifies how far the tire slants away from vertical when viewed directly from the front or back of the vehicle. Camber is expressed in degrees, and is said to be negative when the top of the tire tilts inward toward the center of the vehicle and positive when the top leans away from the center of the vehicle.
    Since street suspensions cannot completely compensate for the outer tire tipping towards the outside when the vehicle leans in a corner, there isn't a magical camber setting that will allow the tires to remain vertical when traveling straight down the road (for more even wear), and remain perpendicular to the road during hard cornering (for more generous grip).
    Different driving styles can also influence the desired camber angle as well. An enthusiastic driver who corners faster than a reserved driver will receive more cornering grip and longer tire life from a tire aligned with more negative camber. However with the aggressive negative camber, a reserved driver's lower cornering speeds would cause the inside edges of the tires to wear faster than the outside edges.
    What's the downside to negative camber? Negative camber leans both tires on the axle towards the center of the vehicle. Each tire develops an equal and offsetting "camber thrust" force (the same principle that causes a motorcycle to turn when it leans) even when the vehicle is driven straight ahead. If the vehicle encounters a bump that only causes one tire to lose some of its grip, the other tire's negative camber will push the vehicle in the direction of the tire that lost grip. The vehicle may feel more "nervous" and become more susceptible to tramlining. Excessive camber will also reduce the available straight-line grip required for rapid acceleration and hard stops.
    Appropriate camber settings that take into account the vehicle and driver's aggressiveness will help balance treadwear with cornering performance. For street-driven vehicles, this means that tire wear and handling requirements must be balanced according to the driver's needs. The goal is to use enough negative camber to provide good cornering performance while not requiring the tire to put too much of its load on the inner edge while traveling in a straight line. Less negative camber (until the tire is perpendicular to the road at zero camber) typically will reduce the cornering ability, but results in more even wear.
    Even though they have some of the most refined suspensions in the world, the next time you see a head-on photo of a Formula 1 car or CART Champ Car set up for a road course, notice how much negative camber is dialed into the front wheels. While this is certainly an example of wear not being as important as grip, negative camber even helps these sophisticated racing cars corner better.
    Caster
    The caster angle identifies the forward or backward slope of a line drawn through the upper and lower steering pivot points when viewed directly from the side of the vehicle. Caster is expressed in degrees and is measured by comparing a line running through the steering system's upper and lower pivot points (typically the upper and lower ball joints of an A-arm or wishbone suspension design, or the lower ball joint and the strut tower mount of a McPherson strut design) to a line drawn perpendicular to the ground. Caster is said to be positive if the line slopes towards the rear of the vehicle at the top, and negative if the line slopes towards the front.
    A very visual example of positive caster is a motorcycle's front steering forks. The forks point forward at the bottom and slope backward at the top. This rearward slope causes the front tire to remain stable when riding straight ahead and tilt towards the inside of the corner when turned.
    Caster angle settings allow the vehicle manufacturer to balance steering effort, high speed stability and front end cornering effectiveness.
    Increasing the amount of positive caster will increase steering effort and straight line tracking, as well as improve high speed stability and cornering effectiveness. Positive caster also increases tire lean when cornering (almost like having more negative camber) as the steering angle is increased.
    What's the downside to positive caster? If thevehicle doesn't have power steering, a noticeable increase in steering effort will be felt as positive caster is increased. Other than that, the effects of positive caster are pretty much "positive," especially increasing the lean of the tire when the vehicle is cornering while returning it to a more upright position when driving straight ahead.
    Cross-Camber and Cross-Caster
    Most street car alignments call for the front camber and caster settings to be adjusted to slightly different specifications on the right side of the vehicle compared to the left side. These slight side-to-side differences are called cross-camber and cross-caster.
    For vehicles set up to drive on the "right" side of the road, the right side is aligned with a little more negative camber (about 1/4-degree) and a little more positive caster (again, about 1/4-degree) to help the vehicle resist the influence of crowned roads that would cause it to drift "downhill" to the right gutter. Since most roads are crowned, cross-camber and cross-caster are helpful the majority of the time, however they will cause a vehicle to drift to the left on a perfectly flat road or a road that leans to the left.
    Using cross-camber and cross-caster is not necessary for track-only cars.
    Toe
    The toe angle identifies the exact direction the tires are pointed compared to the centerline of the vehicle when viewed from directly above. Toe is expressed in either degrees or fractions-of-an-inch, and an axle is said to have positive toe-in when imaginary lines running through the centerlines of the tires intersect in front of the vehicle and have negative toe-out when they diverge. The toe setting is typically used to help compensate for the suspension bushings compliance to enhance tire wear. Toe can also be used to adjust vehicle handling.
    A rear-wheel drive vehicle "pushes" the front axle's tires as they roll along the road. Tire rolling resistance causes a little drag resulting in rearward movement of the suspension arms against their bushings. Because of this, most rear-wheel drive vehicles use some positive toe-in to compensate for the movement, enabling the tires to run parallel to each other at speed.
    Conversely, a front-wheel drive vehicle "pulls" the vehicle through the front axle, resulting in forward movement of the suspension arms against their bushings. Therefore most front-wheel drive vehicles use some negative toe-out to compensate for the movement, again enabling the tires to run parallel to each other at speed.
    Toe can also be used to alter a vehicle's handling traits. Increased toe-in will typically result in reduced oversteer, help steady the car and enhance high-speed stability. Increased toe-out will typically result in reduced understeer, helping free up the car, especially during initial turn-in while entering a corner.
    Before adjusting toe outside the vehicle manufacturer's recommended settings to manipulate handling, be aware that toe settings will influence wet weather handling and tire wear as well.
    Excessive toe settings often bring with them drivability problems, especially during heavy rain. This is because the daily pounding of tractor trailers on many highways leave ruts that fill with water. Since excessive toe means that each tire is pointed in a direction other than straight ahead, when the vehicle encounters a puddle that causes only one tire to lose some of its grip, the other tire's toe setting will push (excessive toe-in) or pull (excessive toe-out) the vehicle to the side. This may make the vehicle feel unsettled and very "nervous."
    Additionally the vehicle's toe is one of the most critical alignment settings relative to tire wear. A toe setting that is just a little off its appropriate setting can make a huge difference in their wear. Consider that if the toe setting is just 1/16-inch off of its appropriate setting, each tire on that axle will scrub almost seven feet sideways every mile! Extend it out and you'll discover that rather than running parallel to each other, the front tires will scrub over 1/4-mile sideways during every 100 miles of driving! Incorrect toe will rob you of tire life.
    Thrust Angle
    The thrust angle is an imaginary line drawn perpendicular to the rear axle's centerline. It compares the direction that the rear axle is aimed with the centerline of the vehicle. It also confirms if the rear axle is parallel to its front axle and that the wheelbase on both sides of the vehicle is the same.
    If the thrust angle is not correct on a vehicle with a solid rear axle, it often requires a trip to the frame straightening shop to correctly reposition the rear axle.
    A vehicle with independent rear axles may have incorrect toe-in or toe-out on both sides of the axle, or may have toe-in on one side and toe-out on the other. The suspension on each side of the vehicle must be adjusted individually until it has reached the appropriate toe setting for its side of the vehicle.
    An incorrect thrust angle is often caused by an out-of-position axle or incorrect toe settings. So in addition to the handling quirks that are the result of incorrect toe settings, thrust angles can also cause the vehicle to handle differently when turning one direction vs. the other.
    Alignment Ranges
    The vehicle manufacturers' alignment specifications usually identify a "preferred" angle for camber, caster and toe (with preferred thrust angle always being zero). The manufacturers also provide the acceptable "minimum" and "maximum" angles for each specification. The minimum and maximum camber and caster specifications typically result in a range that remains within plus or minus 1-degree of the preferred angle.
    If for whatever reason your vehicle can't reach within the acceptable range, replacing bent parts or an aftermarket alignment kit will be required. Fortunately there is a kit for almost every popular vehicle due to the needs of body and frame shops doing crash repairs and driving enthusiasts tuning the suspensions on their cars.
    Recommendations
    An accurate wheel alignment is critical to balance the treadwear and performance a vehicle's tires deliver. Regular wheel alignments will usually save you as much in tire wear as they cost, and should be considered routine, preventative maintenance. Since there are "acceptable" ranges provided in the manufacturer's recommendations, the technician should be encouraged to align the vehicle to the preferred settings and not just within the range.
    If you are a reserved driver, aligning your vehicle to the vehicle manufacturer's preferred settings is appropriate.
    If you are an assertive driver who enjoys driving hard through the corners and expressway ramps, a performance alignment is appropriate for your car. A performance alignment consists of using the vehicle manufacturer's range of alignment specifications to maximize the tires' performance. A performance alignment calls for the manufacturer's maximum negative camber, maximum positive caster, and preferred toe settings. While remaining within the vehicle manufacturer's recommendations, these alignment settings will maximize tire performance.
    If you are a competition driver who frequently runs autocross, track or road race events, you'll typically want the maximum negative camber, maximum positive caster and most aggressive toe settings available from the car and permitted by the competition rules. If the rules permit, aftermarket camber plates and caster adjustments are good investments.
    Many of today's alignment machines are equipped with printouts that compare the "before" and "after" alignment angles with the manufacturers' specifications. Requesting a post alignment printout can help you confirm the thoroughness of the alignment technician and preserve a record of your vehicle's intended settings in the case of an encounter with a suspension damaging road hazard.
  17. Jul 20, 2012 at 9:13 PM
    #297
    EWhitman11
    EWhitman11 Member
    Eli
    Washington
    03 Tacoma 4x4
    Hey guys I have a similar problem. I just bought a 2003 Tacoma 4wd and want to lift it.
    I am looking at the Bilstein 5100's in the front and a Add a Leaf in the rear. Is this all I need to lift it? About how much of a lift will I get? Is it easy to install these on my own? And will this set the truck at level, front higher, or rear higher? Thanks guys, I am new to this whole thing haha. Here my truck
  18. Jul 21, 2012 at 8:13 AM
    #298
    Bounty
    Bounty Member
    T2R3
    Sport
    Very useful thread. Thanks for taking the time to explain it all. Are there any "long add-a-leafs" available? I was planning on going with the Bilstein 5100's and a 1/2" spacer in the front keeping my stock coils.
    I hope to find a long add-a-leaf for the back, re-arch the existing leafs and end up with almost a three inch lift. I often have my bed freighted and would like to beef it up for trips North. Is a four wheel alignment then necessary or is that just bunk?
    I then plan on the BFG KM2 MT 255/80-17. Will this work? Doing it this month. Thanks for the input!
  19. Aug 10, 2012 at 7:47 PM
    #299
    justinitsuj
    justinitsuj Well-Known Member
    Justin
    Mills illest
    Debadged//blacked out//6" fabtech//stubby//spintech//thule//wet okoles//weathertech floor mats//
    currently running the fabtech 6 inch basic kit. Is there any way of improving the ride quality in terms of removing the blocks in the back and adding something else or is the ride naturally stiff with that kit?
  20. Aug 20, 2012 at 4:38 PM
    #300
    piercedtiger
    piercedtiger Devout Atheist
    Jon
    Southern Tier, NY
    2015 F150 3.5EB SCEW 6.5ft
    Apparently it's time for me to replace the shocks and struts. If I go with 5100's in the front does that mean I can remove my Toytec spacers from the OEM coils? I had thought about getting OME 886's since I have a plate steel bumper now. Would I need those with the 5100's? I would think not based on the comment in the OP about not recommending after market coils with the 5100's. So confused now, and I don't want to pay $600-$1100 for Monro to replace all 4 corners.
