Tacoma Load sensing brake proportioning valve
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ricky876, Sep 15, 2016.
  1. Sep 15, 2016 at 12:14 PM
    Ricky876
    Ricky876 [OP] Well-Known Member
    2002 Toyota Space Cab
    Under construction
    Quick question ive been searching the forums and cant seem to find any suitable suggestions...
    my rear load sensing valve on my tacoma has stopped working there is now no fluid being sent to the rear wheels at all... to replace the valve is around 200us but im looking for a cheaper alternative...
    has anyone tried using an aftermarket proportion valve around the back and how much modification did you have to do to get it to work?
  2. Sep 15, 2016 at 12:22 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I don`t have any valve at all
    None of the Trucks when I learned to drive had valves or ABS.
    If you never haul any weight you can get one of those single stage valves
    adjust it where you like and your good to go
    A simple matter to install it in the rear brake line by the Master cylinder
    Plug the lines going to the LSPV in case you ever want to return to stock
  3. Sep 15, 2016 at 12:24 PM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
  4. Sep 15, 2016 at 1:48 PM
    magog45
    magog45 Well-Known Member
    Canada, just south of Santa
    98 tacoma 4x4 extended cab
    5100's all around, 2.75 inch lift, polyurethane body mounts, gibson exhaust, variation of the deckplate mod, intake resonators removed 285-75-16 goodyear AT
    I just did this as I had to replace a rusted out rear brake line. I plugged up the spot where the line returns from the proportioning valve into the front brakes (3way connector on the frame drivers side). Then I ripped out the 2 lines going to the proportioning valve and tossed the valve as well. Where the valve was I put one of those adjustable aftermarket valves so that the rear brakes get about 60% of the available beaking power. With the front brakes now isolated from the rear I find braking is better and if another line rots out I won't lose brakes completely which is what happened to me when the rear line rotted away.
  5. Sep 16, 2016 at 8:02 AM
    Ricky876
    Under construction
    Ohhh ok thanks for the response guys....
    any one have pics of what the set up looks like after taking out the valve.... just want to have a visual aid of how to rig mine up
